Replacing old unsupported node with newer version
I am updating an old system, created by an engineer who has left us. The system hasn't been maintained since his departure so it is my task to update it, as well as take ownership of it.
Most of this is new to me though, so i dont understand everything that's going on.
Node.js version: V10 -> V22
NodeRed version: V1.3.4 -> V4.0.9
OPCUA module: node-red-contrib-iiot-opcua -> node-red-contrib-opcua
This is the module i am attempting to change, as the latter works whilst the former does not.
However, one issue i am running in to is that i do not understand the "response" node.
I cannot find an equivalent in the latter module.
Can someone enlighten me on how it works, and wether or not this module has an equivalent i can use? And perhaps, how?
Thank you
I think the listener and response can be replaced with a subscription node? (its been a few years since I used that IIOT node set).
What is the purpose of this subflow? How is it used? What is your understanding of the intention of this part of your overall project?
PS: I never used the "response" node. As far as i was aware, all it did was print values in the status beneath it (but I could be wrong)
Thank you sir, i will look into it.
That is just the thing, i am unsure of the function of the response node and change msg block but the experienced engineers tell me it is important.
As far as i understand, it it gets a value from the VW_R2_Wisselpupiter node.
Listening if anything changes. The response node does something? Check for corruption or bad value perhaps? If i understand the node description correctly.
Then the change msg node has the following code:
var newMsg = {};
newMsg.addressSpaceItems = [];
var nodeObj = {};
newMsg.topic = "";
newMsg.nodetype = "inject";
newMsg.injectType = "inject";
newMsg.payload = "";
nodeObj.name = "Test_Read";
nodeObj.nodeId = msg.payload.nodeId;
nodeObj.datatypeName = "Boolean";
newMsg.addressSpaceItems[0]= nodeObj;
return newMsg;
The read node reads the server value after the change message node.
The New simple msg node then sets the payload to 1 if it reads anything, or 0 if not:
var new_msg = {};
if(msg.payload[0].value){
    new_msg.payload = 1;
else{
    new_msg.payload = 0;
return new_msg;
We cannot reach its creator and nobody has ever touched these nodes in 5-7 years.
All we know is that it is quite important for assuring we have information about our production system running.
Do you perhaps know someone you can tag to help with this question, sir?
I have dumbed down the nodes to the following (theres a bunch of nodes after this, but this is the confusing part):
For testing puporses, the tag checked is "Runtime", so it changes every second.
The change msg function is written as follows:
var newMsg = {};
var nodeObj = {};
newMsg.topic = "";
return newMsg;
And these are the debug node responses:
So as far as i understand it, it ditches all the values and works as a glorified "If value changes, then run this node", aka a specific inject. Which the function seems to support, but what i dont understand is why anyone might do it this way?
Is that a valid understanding? Or is "Complete msg object" in debug nodes not telling me the full story?
For anyone daring enough to attempt to understand, here's the whole flow:
[{"id":"f4b229ea.02e898","type":"tab","label":"Flow 4","disabled":false,"info":""},{"id":"438467b3.1e5f48","type":"function","z":"f4b229ea.02e898","name":"Change msg","func":"var newMsg = {};\nnewMsg.addressSpaceItems = [];\nvar nodeObj = {};\n\nnewMsg.topic = \"\";\nnewMsg.nodetype = \"inject\";\nnewMsg.injectType = \"inject\";\nnewMsg.payload = \"\";\nnodeObj.name = \"Test_Read\";\nnodeObj.nodeId = msg.payload.nodeId;\nnodeObj.datatypeName = \"Boolean\";\nnewMsg.addressSpaceItems[0]= nodeObj;\nreturn newMsg;\n","outputs":1,"noerr":0,"x":730,"y":220,"wires":[["9d8e679.cb3c298"]]},{"id":"76361182.89d29","type":"OPCUA-IIoT-Response","z":"f4b229ea.02e898","name":"","compressStructure":true,"showStatusActivities":false,"showErrors":false,"activateUnsetFilter":false,"activateFilters":false,"negateFilter":false,"filters":[],"x":530,"y":220,"wires":[["438467b3.1e5f48"]]},{"id":"9d8e679.cb3c298","type":"OPCUA-IIoT-Read","z":"f4b229ea.02e898","attributeId":"0","maxAge":1,"depth":1,"connector":"595a49ba.9ae0a8","name":"","justValue":true,"showStatusActivities":false,"showErrors":true,"parseStrings":false,"historyDays":1,"serverMaxItemsToRead":"","x":930,"y":220,"wires":[["20297ae1.a590b6"]]},{"id":"885d19ef.df46a8","type":"template","z":"f4b229ea.02e898","name":"html table","field":"payload","fieldType":"msg","format":"html","syntax":"mustache","template":"<table border=\"0\" cellspacing=\"3\" cellpadding=\"3\">\n\n    <tr>\n        <th>Name</th>\n        <th>Status</th>\n        <th>Date & Time</th>\n\n    </tr>\n    {{#payload}}\n        <tr class=\"\">\n            <td style=\"min-width:100px\">{{name}}</td>  \n            <td><font color=\"red\">{{stat}}</font></td>\n            <td>{{localTime}}</td>\n        </tr>\n    {{/payload}}\n</table>\n","output":"str","x":1200,"y":640,"wires":[[]]},{"id":"fdd05af8.adfab8","type":"function","z":"f4b229ea.02e898","name":"topic & 10","func":"var arr = msg.payload ;\n\nvar i   = 10;\nif(typeof arr === undefined) {\n    return ;\n} else {\n    msg.payload = arr.slice(0, 10);    \n    msg.topic = 'HMI recording messages :';\n    return msg;\n}","outputs":1,"noerr":0,"initialize":"","finalize":"","libs":[],"x":980,"y":640,"wires":[["885d19ef.df46a8"]]},{"id":"da2c3d5f.685d2","type":"change","z":"f4b229ea.02e898","name":"sort","rules":[{"t":"set","p":"payload","pt":"msg","to":"($sort(payload,function($l , $r){$l.timestamp < $r.timestamp }) )","tot":"jsonata"}],"action":"","property":"","from":"","to":"","reg":false,"x":770,"y":640,"wires":[["fdd05af8.adfab8"]]},{"id":"b1e0c92c.8799b8","type":"function","z":"f4b229ea.02e898","name":"Create/Update msg_events","func":"var msg_obj = msg.payload ;\nvar arr_msgs = flow.get(\"msg_events\", 'memoryOnly')\nvar debug = [];\nvar arrayObj = {};\nvar obj = {};\nvar temp = {};\nvar text=\"\";\nvar foundInArray = false;\nvar index = -1;\n\nif (arr_msgs===undefined ) {\n    arr_msgs = [];\n}\n\n//Start script\ntext+=\"Start - \";\nfor(i=0;i<arr_msgs.length;i++){\n    arrayObj = arr_msgs[i];\n    \n    if(arrayObj.name == msg_obj.name){\n        foundInArray = true;\n        index = i;\n    }\n\n}\n\nif(foundInArray){\n    if(msg.payload.value){\n        //remove from array\n        text+=\"Splice \" + i + \" - \";\n        arr_msgs.splice(index,1);\n    }\n    text+=\"Already present - \";\n}\nelse{\n    if(!msg.payload.value){\n        //add to array\n        text+=\"Push \" + i + \" - \";\n        arr_msgs.push(msg_obj);\n    }\n    text+=\"Not yet present - \";\n    text+=msg.payload.value + \" - \";\n}\n\ntext+=\"Klaar\";\n\nflow.set(\"msg_events\",arr_msgs, 'memoryOnly');\n\ntemp.payload = arr_msgs;\ntemp.debug = text;\nreturn temp;\n","outputs":1,"noerr":0,"initialize":"","finalize":"","libs":[],"x":460,"y":640,"wires":[["da2c3d5f.685d2"]]},{"id":"f0cecf36.134e4","type":"function","z":"f4b229ea.02e898","name":"Add timestamp","func":"msg_obj      = msg.payload;\n\nvar d       = new Date();\nvar jstime  = d.getTime();\nmsg_obj.utc = jstime;\n\nmsg.payload = msg_obj ;\n\nreturn msg;\n\n","outputs":1,"noerr":0,"x":820,"y":340,"wires":[["2f7220dd.889ab"]]},{"id":"2f7220dd.889ab","type":"moment","z":"f4b229ea.02e898","name":"DST","topic":"","input":"payload.utc","inputType":"msg","inTz":"Europe/Brussels","adjAmount":0,"adjType":"days","adjDir":"add","format":"DD/MM/YYYY - HH:mm:ss","locale":"","output":"payload.localTime","outputType":"msg","outTz":"Europe/Brussels","x":990,"y":340,"wires":[["5896c30e.fbef9c","ef2c71d5.8702"]]},{"id":"5896c30e.fbef9c","type":"function","z":"f4b229ea.02e898","name":"Msg logic","func":"new_msg={};\n\nnew_msg.topic=msg.payload.name;\nif(!msg.payload.value){\n    new_msg.payload=msg.payload;\n}\nelse{\n    new_msg.reset=true;\n}\nreturn new_msg;\n\n\n\n\n\n\n","outputs":1,"noerr":0,"x":940,"y":460,"wires":[["269fc8a3.cf8158","400d9246.d12c6c"]]},{"id":"269fc8a3.cf8158","type":"trigger","z":"f4b229ea.02e898","name":"","op1":"","op2":"","op1type":"nul","op2type":"payl","duration":"1","extend":true,"overrideDelay":false,"units":"min","reset":"","bytopic":"topic","topic":"topic","outputs":1,"x":1130,"y":460,"wires":[["459af677.e1eaa8"]]},{"id":"459af677.e1eaa8","type":"trigger","z":"f4b229ea.02e898","name":"","op1":"","op2":"","op1type":"pay","op2type":"pay","duration":"-1","extend":false,"overrideDelay":false,"units":"hr","reset":"","bytopic":"all","topic":"topic","outputs":1,"x":1370,"y":460,"wires":[["52a3917a.a1b3b"]]},{"id":"400d9246.d12c6c","type":"function","z":"f4b229ea.02e898","name":"ResetResend","func":"msg.reset = true;\nreturn msg;","outputs":1,"noerr":0,"x":1140,"y":520,"wires":[["459af677.e1eaa8"]]},{"id":"ef2c71d5.8702","type":"function","z":"f4b229ea.02e898","name":"Logic","func":"var msg_obj = msg.payload ;\nvar arr_msgs = flow.get(\"msg_events\")\nvar debug = [];\nvar arrayObj = {};\nvar temp = {};\nvar foundInArray = false;\n\nif (arr_msgs===undefined ) {\n    arr_msgs = [];\n}\n\n//Start script\nfor(i=0;i<arr_msgs.length;i++){\n    arrayObj = arr_msgs[i];\n    \n    if(arrayObj.node == msg_obj.node){\n        arr_msgs[i] = msg_obj;\n        foundInArray = true;\n        index = i;\n    }\n}\n\nif(!foundInArray){\n    arr_msgs.push(msg_obj);\n}\n\nflow.set(\"msg_events\",arr_msgs);\n\ntemp.payload = arr_msgs;\nreturn temp;","outputs":1,"noerr":0,"x":1150,"y":340,"wires":[["bf67fe20.cd2c3"]]},{"id":"bf67fe20.cd2c3","type":"change","z":"f4b229ea.02e898","name":"sort","rules":[{"t":"set","p":"payload","pt":"msg","to":"($sort(payload,function($l , $r){$l.stat > $r.stat }) )","tot":"jsonata"}],"action":"","property":"","from":"","to":"","reg":false,"x":1290,"y":340,"wires":[["e1eee8fd.5e5838"]]},{"id":"20297ae1.a590b6","type":"function","z":"f4b229ea.02e898","name":"New simple message","func":"var new_msg = {};\nvar new_obj = {};\nnew_obj.node = msg.payload[0].node;\nnew_obj.name = msg.payload[0].displayName.text;\nnew_obj.value = msg.payload[0].value;\nif(msg.payload[0].value){\n    new_obj.stat = \"Recording\"\n    new_obj.icon = \"fa-thumbs-up fa-1x\"\n    new_obj.color = \"green\"\n}\nelse{\n    new_obj.stat = \"Stopped\"\n    new_obj.icon = \"fa-ambulance fa-1x fa-spin\"\n    new_obj.color = \"red\"\n}\n\nnew_msg.payload = new_obj ;\n\nreturn new_msg;","outputs":1,"noerr":0,"initialize":"","finalize":"","libs":[],"x":600,"y":340,"wires":[["f0cecf36.134e4"]]},{"id":"e1eee8fd.5e5838","type":"template","z":"f4b229ea.02e898","name":"html table","field":"payload","fieldType":"msg","format":"html","syntax":"mustache","template":"<table border=\"0\" cellspacing=\"3\" cellpadding=\"3\">\n\n    <tr>\n        <th>Name</th>\n        <th></th>\n        <th>Status</th>\n        <th>Date & Time</th>\n\n    </tr>\n    {{#payload}}\n        <tr class=\"\">\n            <td style=\"min-width:100px\">{{name}}</td>  \n            <td><i class=\"fa {{icon}}\"></i></td>\n            <td>{{stat}}</td>\n            <td>{{localTime}}</td>\n        </tr>\n    {{/payload}}\n</table>\n","output":"str","x":1440,"y":340,"wires":[["44873f7.19424c"]]},{"id":"ab5d20d5.8a47","type":"comment","z":"f4b229ea.02e898","name":"Hier server instellen","info":"","x":970,"y":180,"wires":[]},{"id":"40606e16.66a62","type":"OPCUA-IIoT-Inject","z":"f4b229ea.02e898","injectType":"listen","payloadType":"json","topic":"","repeat":"","crontab":"","once":true,"startDelay":"3","name":"Tags","payload":"{\"interval\":1000,\"queueSize\":10,\"options\":{\"requestedPublishingInterval\":500,\"requestedLifetimeCount\":2400,\"requestedMaxKeepAliveCount\":10,\"maxNotificationsPerPublish\":10,\"publishingEnabled\":true,\"priority\":2}}","addressSpaceItems":[{"name":"AC","nodeId":"ns=3;s=V:0.3.505.1.15","datatypeName":"Boolean"},{"name":"E2R2_WisselCab","nodeId":"ns=3;s=V:0.3.505.1.16","datatypeName":"Boolean"},{"name":"R2_Wisselpup_Lokaal","nodeId":"ns=3;s=V:0.3.505.1.23","datatypeName":"Boolean"},{"name":"Ontlaadcabine","nodeId":"ns=3;s=V:0.3.505.1.18","datatypeName":"Boolean"}],"x":110,"y":220,"wires":[["c16ff454.e42e38"]]},{"id":"c16ff454.e42e38","type":"OPCUA-IIoT-Listener","z":"f4b229ea.02e898","connector":"595a49ba.9ae0a8","action":"subscribe","queueSize":10,"name":"","topic":"","justValue":true,"useGroupItems":false,"showStatusActivities":true,"showErrors":true,"x":340,"y":220,"wires":[["76361182.89d29"]]},{"id":"52a3917a.a1b3b","type":"function","z":"f4b229ea.02e898","name":"Mail VW","func":"msg.to = //Redacted\nmsg.from = //Redacted\nreturn msg;","outputs":1,"noerr":2,"initialize":"","finalize":"","libs":[],"x":1560,"y":460,"wires":[[]]},{"id":"44873f7.19424c","type":"ui_template","z":"f4b229ea.02e898","group":"","name":"Webpagina VW","order":0,"width":0,"height":0,"format":"<div ng-bind-html=\"msg.payload\" height=\"500\" style=\"height: 350px;\"></div>","storeOutMessages":false,"fwdInMessages":false,"resendOnRefresh":false,"templateScope":"local","x":1620,"y":340,"wires":[[]]},{"id":"595a49ba.9ae0a8","type":"OPCUA-IIoT-Connector","discoveryUrl":"","endpoint":"opc.tcp://ws71633:48080/","keepSessionAlive":true,"loginEnabled":false,"securityPolicy":"None","securityMode":"NONE","name":"WSJD","showErrors":false,"individualCerts":false,"publicCertificateFile":"","privateKeyFile":"","defaultSecureTokenLifetime":"","endpointMustExist":false,"autoSelectRightEndpoint":false,"strategyMaxRetry":"","strategyInitialDelay":"","strategyMaxDelay":"","strategyRandomisationFactor":"","requestedSessionTimeout":"","connectionStartDelay":"","reconnectDelay":"","maxBadSessionRequests":"10"}]
