Request node with ca certificate
Hi all!
I'm doing some request to an API that has SSL certificate. The output says the follwing:
RequestError: unable to verify the first certificate : https://urlfromtheclient.com
and also UNABLE_TO_VERIFY_LEAF_SIGNATURE
So, the client sent me the CA certificate which it has "client -- chain -- root) in CRT format. I put that in the following section:
But it doesn't work. I have the same error as above.
Anyone worked this issue before?.
Thanks!
The CA cert should not include the client certificate.
You could try to copy the content including the BEGIN/END CERTIFICATE of the root certificate and save it in a .crt and retry?
ok, and how could i know which is the root part?. The client sent me everything in the same CRT file which include the "client + chain + root".
Thanks!
