I'm using http-request node to call with api, if my api takes more than a minute to response, I'm getting error: "RequestError: socket hang up" exactly after one minute
How can I increase the request time-out to more than a minute
Is it normal that it takes so long?
You can change the timeout in the settings file
/** Timeout in milliseconds for HTTP request connections.*/
httpRequestTimeout: 120000
Checks the URL used and if it must contain a property to work.
It could happen that it is just an error of choice http/https
Without more information on this API it's hard to say
By the way, shouldn't you use the http-request node?
yeah I used http-request node
Do I have to connect setting.js file somewhere or it is automatically connected when I ran node-red locally?
No, it's global config loaded when NR starts
