Reset global (or) flow counter values when session is closed
i am looking for an approach where my counter values are reset when the session of my flow is closed (or) node red server is turned off.
in my current implementation i am using-
global.set("counter",1);
and then i increment the counter value based on a condition. When i relaunch the node-red server - i see that the last saved value of the counter is still saved.
Is there a way i can reset the value when the session is closed?
i also tried
flow.get();
same results
You can use a change node to set or delete a context variable. It could be triggered by an inject node set to fire at startup.
How many global context variables are you using?
