Hi all, I'm using html code inside ui-template node to define a "file" input which let me choose file from a folder. I would like reset chosen file when a msg. Payload arrives inside ui-template node. It is possible? Many thanks in advance
A bit vague on what you are asking but using should work
// Reset file name
