Reset Join Node
Hi there,
is there a way to reset a join node without sending the buffered messages?
My case:
the join node is set to manual: Send the message: After a number of message parts 5
There are 4 messages buffered and I would like to reset the node without sending any of the buffered messages out of such node.
Thanks for helping.
From the help text in the side panel
If a message is received with the msg.reset property set, the partly complete message is deleted and not sent. This resets any part counts
e.g.
[{"id":"d72d6c96.dacd","type":"inject","z":"7f59364f045fd16d","name":"","props":[{"p":"payload"},{"p":"topic","vt":"str"}],"repeat":"","crontab":"","once":false,"onceDelay":0.1,"topic":"t","payload":"","payloadType":"date","x":230,"y":580,"wires":[["2b1f7419.779bc4"]]},{"id":"2b1f7419.779bc4","type":"join","z":"7f59364f045fd16d","name":"","mode":"custom","build":"object","property":"payload","propertyType":"msg","key":"topic","joiner":"\\n","joinerType":"str","accumulate":false,"timeout":"","count":"2","reduceRight":false,"reduceExp":"","reduceInit":"","reduceInitType":"","reduceFixup":"","x":420,"y":600,"wires":[["a966cb14.c37eb"]]},{"id":"47217e33.156a5","type":"inject","z":"7f59364f045fd16d","name":"","props":[{"p":"payload"},{"p":"topic","vt":"str"}],"repeat":"","crontab":"","once":false,"onceDelay":0.1,"topic":"r","payload":"","payloadType":"date","x":250,"y":620,"wires":[["2b1f7419.779bc4"]]},{"id":"e75d2ea8.ded8b8","type":"inject","z":"7f59364f045fd16d","name":"reset","props":[{"p":"reset","v":"true","vt":"bool"},{"p":"topic","vt":"str"}],"repeat":"","crontab":"","once":false,"onceDelay":0.1,"topic":"","x":240,"y":680,"wires":[["2b1f7419.779bc4"]]},{"id":"a966cb14.c37eb","type":"debug","z":"7f59364f045fd16d","name":"","active":true,"tosidebar":true,"console":false,"tostatus":false,"complete":"false","statusVal":"","statusType":"auto","x":640,"y":600,"wires":[]}]
Thank you
