s1nbad
1
Is there a way to reset the status of an HTTP node ?
After a flow of POST requests if there is an error then this is shown in red under the HTTP node (eg: EHOSTUNREACH) - how to remove ?
I have tried sending a blank message and a blank object in msg.status
This is purely aesthetic and is not impacting the flow as i am catching the errors
@s1nbad Welcome to the forum Peter!
- What version of Node-RED and node.js are you running? (you can get these from the start up log)
- Can you export* and attach a small sample flow showing the issue? That will make it easier for people to help you.
* In order to make code readable and usable it is necessary to surround your code with three backticks (also known as a left quote or backquote ```)
code goes here
You can edit and correct your post by clicking the pencil
icon.
Short answer: no there isn't.
