Resetting Gauge node
Since this is sort of related to the question:
I'm messing around with multiple pointers.
I've kind of got it ok, but how do I think clear the gauge?
Do I have to inject multiple payloads of with the relevant topics set?
(Kinda guess that is what is needed.)
Brain failure detected.
That would deppened on which gauge node.
There was a resent question similar to this on classic gauge Reset ui gauge classic
ITMT: I set the topic and connected all them back to one inject node injecting a and that seems to work.
Now I'm stuck with a blank/empty topic. But I think I know what to do.
(Standby for more questions)
:wink:
Sorry, stuck now with a rogue needle.
[{"id":"5392bba75ecdbeb4","type":"function","z":"d6026c14350dea74","name":"Move to payload","func":"let msg1 = {};\nlet power = msg.payload.ENERGY.Today;\nmsg1.payload = power;\nmsg1.topic = \"A1\";\nreturn msg1;","outputs":1,"timeout":0,"noerr":0,"initialize":"","finalize":"","libs":[],"x":670,"y":150,"wires":[["a733610f066c935d"]]},{"id":"3e1fcc438fed5ff8","type":"mqtt in","z":"d6026c14350dea74","name":"","topic":"A1/tele/SENSOR","qos":"2","datatype":"auto-detect","broker":"4178d9f.f883728","nl":false,"rap":true,"rh":0,"inputs":0,"x":450,"y":150,"wires":[["aeff4bdae00c4e3f","5392bba75ecdbeb4"]]},{"id":"a733610f066c935d","type":"change","z":"d6026c14350dea74","name":"","rules":[{"t":"set","p":"topic","pt":"msg","to":"A1","tot":"str"}],"action":"","property":"","from":"","to":"","reg":false,"x":785,"y":150,"wires":[["8fb20ae72d0d7e0f"]],"l":false},{"id":"aeff4bdae00c4e3f","type":"debug","z":"d6026c14350dea74","name":"A1","active":true,"tosidebar":true,"console":false,"tostatus":false,"complete":"true","targetType":"full","statusVal":"","statusType":"auto","x":640,"y":180,"wires":[]},{"id":"ac0d932f0e48cf6c","type":"inject","z":"d6026c14350dea74","name":"Wipe","props":[{"p":"payload"},{"p":"topic","vt":"str"}],"repeat":"","crontab":"","once":false,"onceDelay":0.1,"topic":"","payload":" ","payloadType":"str","x":680,"y":100,"wires":[["a733610f066c935d","2662e1f0c33e58fb","17be4774931ab231","c5af06e77fe26629","027db0045e511521"]]},{"id":"8fb20ae72d0d7e0f","type":"junction","z":"d6026c14350dea74","x":940,"y":150,"wires":[["6926509cac9da0bb"]]},{"id":"2662e1f0c33e58fb","type":"change","z":"d6026c14350dea74","name":"","rules":[{"t":"set","p":"topic","pt":"msg","to":"A2","tot":"str"}],"action":"","property":"","from":"","to":"","reg":false,"x":785,"y":220,"wires":[["8fb20ae72d0d7e0f"]],"l":false},{"id":"17be4774931ab231","type":"change","z":"d6026c14350dea74","name":"","rules":[{"t":"set","p":"topic","pt":"msg","to":"A3","tot":"str"}],"action":"","property":"","from":"","to":"","reg":false,"x":785,"y":290,"wires":[["8fb20ae72d0d7e0f"]],"l":false},{"id":"c5af06e77fe26629","type":"change","z":"d6026c14350dea74","name":"","rules":[{"t":"set","p":"topic","pt":"msg","to":"A4","tot":"str"}],"action":"","property":"","from":"","to":"","reg":false,"x":785,"y":360,"wires":[["8fb20ae72d0d7e0f"]],"l":false},{"id":"027db0045e511521","type":"change","z":"d6026c14350dea74","name":"","rules":[{"t":"set","p":"topic","pt":"msg","to":"A5","tot":"str"}],"action":"","property":"","from":"","to":"","reg":false,"x":785,"y":430,"wires":[["8fb20ae72d0d7e0f"]],"l":false},{"id":"6926509cac9da0bb","type":"junction","z":"d6026c14350dea74","x":1000,"y":150,"wires":[["aa774e2285d75616","4d4a4c32f711a182","0f47080ef1c017d5"]]},{"id":"fa4127f220e09bea","type":"function","z":"d6026c14350dea74","name":"Move to payload","func":"let msg1 = {};\nlet power = msg.payload.ENERGY.Today;\nmsg1.payload = power;\nmsg1.topic = \"A2\";\nreturn msg1;","outputs":1,"timeout":0,"noerr":0,"initialize":"","finalize":"","libs":[],"x":670,"y":220,"wires":[["2662e1f0c33e58fb"]]},{"id":"45fa51a010276816","type":"function","z":"d6026c14350dea74","name":"Move to payload","func":"let msg1 = {};\nlet power = msg.payload.ENERGY.Today;\nmsg1.payload = power;\nmsg1.topic = \"A3\";\nreturn msg1;","outputs":1,"timeout":0,"noerr":0,"initialize":"","finalize":"","libs":[],"x":670,"y":290,"wires":[["17be4774931ab231"]]},{"id":"3aa12236c755b6f8","type":"function","z":"d6026c14350dea74","name":"Move to payload","func":"let msg1 = {};\nlet power = msg.payload.ENERGY.Today;\nmsg1.payload = power;\nmsg1.topic = \"A4\";\nreturn msg1;","outputs":1,"timeout":0,"noerr":0,"initialize":"","finalize":"","libs":[],"x":670,"y":360,"wires":[["c5af06e77fe26629","72c98d3060450d48"]]},{"id":"72c98d3060450d48","type":"q-gate","z":"d6026c14350dea74","name":"","controlTopic":"control","defaultState":"queueing","openCmd":"open","closeCmd":"close","toggleCmd":"toggle","queueCmd":"queue","defaultCmd":"default","triggerCmd":"trigger","flushCmd":"flush","resetCmd":"reset","peekCmd":"peek","dropCmd":"drop","statusCmd":"status","maxQueueLength":"1","keepNewest":false,"qToggle":false,"persist":false,"storeName":"memory","x":770,"y":510,"wires":[["c5af06e77fe26629"]]},{"id":"3a2a6894c704884d","type":"function","z":"d6026c14350dea74","name":"Move to payload","func":"let msg1 = {};\nlet power = msg.payload.ENERGY.Today;\nmsg1.payload = power;\nmsg1.topic = \"A5\";\nreturn msg1;","outputs":1,"timeout":0,"noerr":0,"initialize":"","finalize":"","libs":[],"x":670,"y":430,"wires":[["027db0045e511521"]]},{"id":"afd12ab3197588de","type":"inject","z":"d6026c14350dea74","name":"A1","props":[{"p":"payload"},{"p":"topic","vt":"str"}],"repeat":"","crontab":"","once":false,"onceDelay":0.1,"topic":"A1","payload":"0.003","payloadType":"num","x":940,"y":370,"wires":[["6926509cac9da0bb"]]},{"id":"946937cf7dde2287","type":"function","z":"d6026c14350dea74","name":"function 3","func":"msg.payload = \"\"\nmsg.ui_update = {units:'-'}\nreturn msg","outputs":1,"timeout":0,"noerr":0,"initialize":"","finalize":"","libs":[],"x":970,"y":60,"wires":[["6926509cac9da0bb"]]},{"id":"aa774e2285d75616","type":"ui-gauge-classic","z":"d6026c14350dea74","name":"Classic","group":"9d0aa235d37c5289","order":4,"width":"3","height":"3","min":0,"max":"0.1","sectors":[],"major_division":"0.1","minor_division":"0.01","value_decimal_places":1,"scale_decimal_places":0,"label":"","measurement":"milliWatts","units":"milliWatts","needles":[{"topic":"A1","color":"green","lengthPercent":"100"},{"topic":"A2","color":"yellow","lengthPercent":"100"},{"topic":"A3","color":"orange","lengthPercent":"100"},{"topic":"A4","color":"black","lengthPercent":"100"},{"topic":"A5","color":"brown","lengthPercent":"100"}],"sweep_angle":"180","myclass":"","x":1190,"y":190,"wires":[]},{"id":"4d4a4c32f711a182","type":"ui-gauge","z":"d6026c14350dea74","name":"Gauge","group":"9d0aa235d37c5289","order":2,"width":3,"height":"2","gtype":"gauge-battery","gstyle":"needle","title":"gauge","units":"units","icon":"","prefix":"","suffix":"","segments":[{"from":"0","color":"#ea5353"},{"from":"40","color":"#ffc800"},{"from":"70","color":"#5cd65c"}],"min":0,"max":"100","sizeThickness":16,"sizeGap":4,"sizeKeyThickness":8,"styleRounded":true,"styleGlow":false,"className":"","x":1180,"y":150,"wires":[]},{"id":"0f47080ef1c017d5","type":"debug","z":"d6026c14350dea74","name":"To gauge","active":true,"tosidebar":true,"console":false,"tostatus":false,"complete":"payload","targetType":"msg","statusVal":"","statusType":"auto","x":1190,"y":100,"wires":[]},{"id":"efa4923d349d3299","type":"mqtt in","z":"d6026c14350dea74","name":"","topic":"A2/tele/SENSOR","qos":"2","datatype":"auto-detect","broker":"4178d9f.f883728","nl":false,"rap":true,"rh":0,"inputs":0,"x":450,"y":220,"wires":[["951b4184cbf8de11","fa4127f220e09bea"]]},{"id":"3a67f99798cf8111","type":"mqtt in","z":"d6026c14350dea74","name":"","topic":"A3/tele/SENSOR","qos":"2","datatype":"auto-detect","broker":"4178d9f.f883728","nl":false,"rap":true,"rh":0,"inputs":0,"x":450,"y":290,"wires":[["dc08c5f98fa021e6","45fa51a010276816"]]},{"id":"af11fc823595f51f","type":"mqtt in","z":"d6026c14350dea74","name":"","topic":"A4/tele/SENSOR","qos":"2","datatype":"auto-detect","broker":"4178d9f.f883728","nl":false,"rap":true,"rh":0,"inputs":0,"x":450,"y":360,"wires":[["cf5a29ee76a46ba9","3aa12236c755b6f8"]]},{"id":"c4e2f1c945cf0860","type":"inject","z":"d6026c14350dea74","name":"Resend","props":[{"p":"payload"},{"p":"topic","vt":"str"}],"repeat":"","crontab":"","once":false,"onceDelay":0.1,"topic":"control","payload":"peek","payloadType":"str","x":770,"y":560,"wires":[["72c98d3060450d48"]]},{"id":"9ee45062ba3c8cb5","type":"mqtt in","z":"d6026c14350dea74","name":"","topic":"A5/tele/SENSOR","qos":"2","datatype":"auto-detect","broker":"4178d9f.f883728","nl":false,"rap":true,"rh":0,"inputs":0,"x":450,"y":430,"wires":[["3958009ac6c49b50","3a2a6894c704884d"]]},{"id":"b13003d4f6362b3c","type":"inject","z":"d6026c14350dea74","name":"","props":[{"p":"payload"},{"p":"topic","vt":"str"}],"repeat":"","crontab":"","once":false,"onceDelay":0.1,"topic":"","payload":"","payloadType":"date","x":830,"y":60,"wires":[["946937cf7dde2287"]]},{"id":"951b4184cbf8de11","type":"debug","z":"d6026c14350dea74","name":"A2","active":true,"tosidebar":true,"console":false,"tostatus":false,"complete":"true","targetType":"full","statusVal":"","statusType":"auto","x":640,"y":250,"wires":[]},{"id":"dc08c5f98fa021e6","type":"debug","z":"d6026c14350dea74","name":"A3","active":true,"tosidebar":true,"console":false,"tostatus":false,"complete":"true","targetType":"full","statusVal":"","statusType":"auto","x":640,"y":320,"wires":[]},{"id":"cf5a29ee76a46ba9","type":"debug","z":"d6026c14350dea74","name":"A4","active":true,"tosidebar":true,"console":false,"tostatus":false,"complete":"true","targetType":"full","statusVal":"","statusType":"auto","x":640,"y":390,"wires":[]},{"id":"3958009ac6c49b50","type":"debug","z":"d6026c14350dea74","name":"A5","active":true,"tosidebar":true,"console":false,"tostatus":false,"complete":"true","targetType":"full","statusVal":"","statusType":"auto","x":640,"y":460,"wires":[]},{"id":"4178d9f.f883728","type":"mqtt-broker","name":"TimePi","broker":"192.168.17.39","port":"1883","clientid":"","autoConnect":true,"usetls":false,"protocolVersion":"4","keepalive":"20","cleansession":true,"autoUnsubscribe":true,"birthTopic":"","birthQos":"2","birthPayload":"'Nas-T-Nuc online'","birthMsg":{},"closeTopic":"","closePayload":"'Nas-T-Nuc shutting down'","closeMsg":{},"willTopic":"EOM","willQos":"0","willPayload":"'Nas-T-Nuc telemetry failure'","willMsg":{},"userProps":"","sessionExpiry":""},{"id":"9d0aa235d37c5289","type":"ui-group","name":"My Group","page":"0aef6b45c70fc7e6","width":6,"height":1,"order":1,"showTitle":true,"className":"","visible":true,"disabled":false},{"id":"0aef6b45c70fc7e6","type":"ui-page","name":"Power Gauges","ui":"81d0a76c830e3379","path":"/page1","icon":"home","layout":"grid","theme":"b608c93778d60f83","order":2,"className":"","visible":"true","disabled":"false"},{"id":"81d0a76c830e3379","type":"ui-base","name":"My Dashboard","path":"/dashboard","includeClientData":true,"acceptsClientConfig":["ui-notification","ui-control"],"showPathInSidebar":false,"showPageTitle":true,"navigationStyle":"default","titleBarStyle":"default"},{"id":"b608c93778d60f83","type":"ui-theme","name":"Default Theme","colors":{"surface":"#ffffff","primary":"#0094CE","bgPage":"#eeeeee","groupBg":"#ffffff","groupOutline":"#cccccc"},"sizes":{"density":"default","pagePadding":"12px","groupGap":"12px","groupBorderRadius":"4px","widgetGap":"12px"}}]
The green is from the test inject node.
The red one isn't defined.
I'm not sure how/why it is there.
Thoughts?
(Ignore the q-gate node that is just for testing the gauge node)
It's brown.
Ooops.
Ok, I'll look into that then.
Ah!
Ok, problem kinda identified.
I'll have to work on that problem as I now see what it is and how to deal with it.
UPDATE:
For the sake of not annoying you all with these silly problems, I'll close it and work on what I have learnt ITMT and see if that is a real solution or if I need more help.
