RESOLVED: Convert HTML to Array of Objects
I have an html response containing item element tags and subelement tags within. I want to convert this to an array of item objects containing the item elements. Here is a very simplified version of the HTML:
<rss>
  <item>
    <title>Alert Number 1</title>
    <description>Description Number 1</description>
  </item>
  <item>
  </item>
</rss>
Here is the desired JSON output:
        "title": "Alert Number 1",
        "description": "Description Number 1"
        "title": "Alert Number 2",
        "description": "Description Number 2"
I thought I'd be able to do this easily with the Edit html node but that gets me item objects with the elements combined in a string or html, rather than object elements. The simple flow below shows what I want and what I get with the html option in the Edit html node.
[{"id":"bdbbd45b058fddfe","type":"tab","label":"Flow 1","disabled":false,"info":"","env":[]},{"id":"69d37d2a1234967a","type":"debug","z":"bdbbd45b058fddfe","name":"Output JSON","active":true,"tosidebar":true,"console":false,"tostatus":false,"complete":"output","targetType":"msg","statusVal":"","statusType":"auto","x":540,"y":200,"wires":[]},{"id":"99da6278232eb673","type":"html","z":"bdbbd45b058fddfe","name":"Get Items - HTML","property":"payload","outproperty":"output","tag":"item","ret":"html","as":"single","x":330,"y":200,"wires":[["54533185b06f155b","69d37d2a1234967a","ecf7b8348d823484"]]},{"id":"ecf7b8348d823484","type":"debug","z":"bdbbd45b058fddfe","name":"Desired JSON","active":true,"tosidebar":true,"console":false,"tostatus":false,"complete":"desired","targetType":"msg","statusVal":"","statusType":"auto","x":540,"y":240,"wires":[]},{"id":"eee8c7a43f66f6b1","type":"inject","z":"bdbbd45b058fddfe","name":"Setup","props":[{"p":"payload"},{"p":"desired","v":"[{\"title\":\"Alert Number 1\",\"description\":\"Description Number 1\"},{\"title\":\"Alert Number 2\",\"description\":\"Description Number 2\"}]","vt":"json"}],"repeat":"","crontab":"","once":false,"onceDelay":0.1,"topic":"","payload":"<rss>   <item>     <title>Alert Number 1</title>     <description>Description Number 1</description>   </item>   <item>     <title>Alert Number 1</title>     <description>Description Number 1</description>   </item> </rss>","payloadType":"str","x":150,"y":200,"wires":[["99da6278232eb673"]]},{"id":"54533185b06f155b","type":"debug","z":"bdbbd45b058fddfe","name":"HTML Source","active":true,"tosidebar":true,"console":false,"tostatus":false,"complete":"payload","targetType":"msg","statusVal":"","statusType":"auto","x":540,"y":160,"wires":[]}]
So what is the best/easiest/proper method to achieve this?
[For those who notice this is actually an RSS parser, the feedparser node does not contain the initialization and timing control that I need. The user contrib versions with input could work but are overkill for what I am doing.]
Peter
Try feeding it through an xml node.
DOH! Yeah, that works fine. Thanks!
Peter
Excellent. Glad to be of help.
