Restart loop 4 times per minute
node-red[3353]: ../src/base_object-inl.h:140:static void node::BaseObject::InternalFieldSet(v8::Localv8::String, v8::Localv8::Value, const v8::PropertyCallbackInfo&) [with int Field = 2; bool (v8::Value::* typecheck)() const = &v8::Value::IsFunction]: Assertion `((*value)->*typecheck)()' failed.
nodered.service: Main process exited, code=killed, status=6/ABRT
nodered.service: Failed with result 'signal'.
I can't figure out what's wrong. My flows were working fine yesterday evening, and when I opened the Dashboard this morning, this started happening, and I can't stop it (without stopping Node-RED).
I've tried restarting the Raspberry Pi and disabling all of my own triggers, but it seems to be happening on a deeper level.
There is not much to go on from here.
Could you post the output of node-red-start (use the </> icon before pasting the output).
Can you also specify the versions of node-red, node and npm ?
I finally narrowed it down. It was the node-red-contrib-neato-botvac node that was suddenly sending a null msg.payload, possibly due to an external server error.
I put in a switch node checking the payload for null before passing it on, and everything is fine now.
Was it that node that was crashing Âż or the one after ? If so what was that node. Either way, one of them needs to be fixed if possible. Thanks
Good question!
I dug even deeper after you asked this, and discovered that it is in fact the Trigger node that doesn't handle a null msg.payload. So perhaps this bug is in Node-RED core after all, and not the Neato module.
Confirmed on 1.0.4
thanks for finding and confirming.
Happy to have an issue raised against the project so we can track/fix it - thanks
Done
Oops - I was actually runing 1.0.3 on my Win10 - didn't actually check version :grimacing:
Sorry for wasting everyones time
I'm running 1.0.5 on Raspberry Pi 4, 4GB. Upgraded all packages and nodes a couple of days ago.
Works fine for me now that I'm on 1.0.5
so @osvedman - hmm any clues how can we re-create ? How is your trigger configured ?
(Edit - aha - think I have one mode -- if payload is null (object) rather than missing completely.
I can confirm this one :slight_smile:
#honestguv
I also managed to reproduce with the Debug node. So there might be more nodes that are affected.
Please share any examples you can. Thanks
