Retrieving data from a server via an https link
I would like to know how to retrieve data from a server and send it to Node-Red. I previously tested the URL on Postman, to see the data sent:
In order to get the correct values ​​I had to add headers.
I would like to retrieve the values ​​in this same form but on Node-Red
I have previously tested something, like this helper:
https://cookbook.nodered.org/http/set-request-header
Doing it on Node-Red gave me this:
Code located in the function block.
Recuperation_donne_https_GET
Result obtained, I do not know how to interpret.
Thank you for your answers.
Well it looks more like a binary file - which given the accept-encoding says gzip deflate then maybe needs to be unzipped. Maybe it will allow a different encoding ?
Additionally, try "application/json" for the "Accept" header.
