Retrieving filtered values jsgrid from a template node
hello, I work on a CRUD, i use js-grid, and mongodb for data base,here is my flow, all works properly, inserting, updating, deleting, and filtering. My question is whether I can retrieve the results of a filtering, for example to perform statistical calculations, to transmit these values ​​to the following node.
In what form should these data be, global variable etc ...
thank you for your help
Nicolas
myflow.txt (13.7 KB)
i can close , i find a way by myself.
see you
Nico
Hi nico,
can you create the solution?
hi webheberge,
for extract data fron jsgrid, i must generate a csv file, it's enough for my need, if you want i can send you the code to do that.
Nico
