Normally, Tab key can be used to jump to the next widget or input. Can this be changed to also bind the same functionality to the Return key?
This has been discussed before on the forum. E.g. Dashboard Template next field on enter - #2 by Steve-Mcl
Have a look at that post. It might point you in the right direction.
Thanks for the hint. Looks as it can solve my issue. I‘ll try it later today
