Greetings, guru! I could not solve the problem of controlling the RGBW LED strip from Node-Red.
Hardware: - controller "MagicHome" (Philips Hue) flashed from ESPHOME. (Method GPIO>transistors)
The LED stripe is perfectly controlled from Lovelace, but ... I just can’t figure out how to manage it from the Node-Red.
Basically, the question is:
Is it possible to manage it directly from a Node-Red?
if not, is it possible to create some kind of scene, automation (color, brightness) in Home Assistant and run them from the Node-Red?
