Rollease blinds Telnet control
Does anyone have any form of control working with rollease blinds using the Pulse 2 hub? There are other integrations with automation systems using telnet so it looks possible.
Another open source project hubatat has some code but I dont understand it well enough to move it over to node-red.
Any input or a shove in the right direction would be greatly appreciated.
Thanks all for your time.
Regards, MikeC
Well as telnet is in its basic form ASCII over TCP - absolutely yes.
If you know the IP, port and command string then give it a go.
Start small i.e. inject (enter the string) --> TCP request --> debug node.
