Hi my friends, I need to rotate a gear when a signal of PLC come.
Welcome.
Can you provide more information, we have nothing to go on with this.
Example flow, code etc. Make sure to use the correct code formatting when posting.
Hi @jelor1985,
Here`s a flow that has a switch that controls the spinning of the image of a gear (from font-awesome). Hope that works for you!
"id": "36b3321b.76331e",
"type": "ui_template",
"z": "119b139b.df98ac",
"group": "a9b59c6a.acaa5",
"name": "Gear logo",
"order": 3,
"width": 0,
"height": 0,
"format": "<div ng-bind-html=\"msg.payload\"></div>",
"storeOutMessages": true,
"fwdInMessages": true,
"templateScope": "local",
"x": 840,
"y": 320,
"id": "4de4744e.fee76c",
"type": "change",
"rules": [
"t": "set",
"p": "payload",
"pt": "msg",
"to": "<i class=\"fa fa-cog fa-spin fa-3x fa-fw\"></i>",
"tot": "str"
"action": "",
"property": "",
"from": "",
"to": "",
"reg": false,
"x": 640,
"y": 300,
"36b3321b.76331e"
"id": "a68f42b7.dd77",
"type": "ui_switch",
"label": "switch",
"tooltip": "",
"order": 4,
"width": 0,
"height": 0,
"passthru": true,
"decouple": "false",
"topic": "",
"style": "",
"onvalue": "true",
"onvalueType": "bool",
"onicon": "",
"oncolor": "",
"offvalue": "false",
"offvalueType": "bool",
"officon": "",
"offcolor": "",
"x": 320,
"y": 320,
"cc12b07e.1ca1"
"id": "cc12b07e.1ca1",
"type": "switch",
"property": "payload",
"propertyType": "msg",
"rules": [
"t": "true"
"t": "false"
"checkall": "true",
"repair": false,
"outputs": 2,
"x": 470,
"y": 320,
"4de4744e.fee76c"
"95bf89e7.747fa8"
"id": "95bf89e7.747fa8",
"type": "change",
"rules": [
"t": "set",
"p": "payload",
"pt": "msg",
"to": "<i class=\"fa fa-cog fa-3x fa-fw\"></i>",
"tot": "str"
"action": "",
"property": "",
"from": "",
"to": "",
"reg": false,
"x": 640,
"y": 340,
"36b3321b.76331e"
"id": "d46ba4c4.151668",
"type": "inject",
"name": "Init",
"topic": "",
"payload": "false",
"payloadType": "bool",
"repeat": "",
"crontab": "",
"once": true,
"onceDelay": 0.1,
"x": 190,
"y": 320,
"a68f42b7.dd77"
"id": "a9b59c6a.acaa5",
"type": "ui_group",
"z": "",
"name": "TEMP",
"tab": "cc16d42c.cb9c08",
"order": 3,
"disp": true,
"width": "6",
"collapse": false
"id": "cc16d42c.cb9c08",
"type": "ui_tab",
"z": "",
"name": "Tab",
"icon": "wifi",
"order": 1
