So this my simple flow:
[{"id":"e4e6562f.f1a698","type":"modbus-write","z":"350f034d.94afcc","name":"Mosok_vil_write","showStatusActivities":true,"showErrors":false,"unitid":"1","dataType":"Coil","adr":"15002","quantity":"1","server":"4d5e1b27.37ea5c","x":1020,"y":80,"wires":[,]},{"id":"ec77ff58.f3d2","type":"ui_switch","z":"350f034d.94afcc","name":"","label":"Mosokonyha ","tooltip":"","group":"b7362e82.2a474","order":13,"width":"0","height":"0","passthru":true,"decouple":"false","topic":"","style":"","onvalue":"true","onvalueType":"bool","onicon":"fa-power-off","oncolor":"green","offvalue":"false","offvalueType":"bool","officon":"fa-power-off","offcolor":"red","x":700,"y":80,"wires":[["e4e6562f.f1a698"]]},{"id":"7dece348.20398c","type":"modbus-read","z":"350f034d.94afcc","name":"Mosok_vilagitas","topic":"","showStatusActivities":false,"logIOActivities":false,"showErrors":false,"unitid":"1","dataType":"Coil","adr":"15002","quantity":"1","rate":"1","rateUnit":"s","delayOnStart":false,"startDelayTime":"","server":"4d5e1b27.37ea5c","useIOFile":false,"ioFile":"","useIOForPayload":false,"x":220,"y":80,"wires":[,["d401976f.87f3b"]]},{"id":"d401976f.87f3b","type":"function","z":"350f034d.94afcc","name":" Decode array","func":"// The message returned from the read node is an\n// array as there could be multiple registers returned\n// This reads the first value in the array.\nm = msg.payload.data[0]\nreturn {payload: m};\n","outputs":1,"noerr":0,"x":420,"y":80,"wires":[["ec77ff58.f3d2"]]},{"id":"4d5e1b27.37ea5c","type":"modbus-client","z":"350f034d.94afcc","name":"Mester","clienttype":"tcp","bufferCommands":true,"stateLogEnabled":false,"tcpHost":"192.168.1.144","tcpPort":"502","tcpType":"DEFAULT","serialPort":"/dev/ttyUSB","serialType":"RTU-BUFFERD","serialBaudrate":"9600","serialDatabits":"8","serialStopbits":"1","serialParity":"none","serialConnectionDelay":"100","unit_id":1,"commandDelay":1,"clientTimeout":1000,"reconnectTimeout":2000},{"id":"b7362e82.2a474","type":"ui_group","z":"350f034d.94afcc","name":"Foldszint vilagítas","tab":"ff28c5b9.5fd548","disp":true,"width":"6","collapse":false},{"id":"ff28c5b9.5fd548","type":"ui_tab","z":"350f034d.94afcc","name":"Mester u. 1/b.","icon":"fa-home","order":1,"disabled":false,"hidden":false}]
