Hi I am trying to use the row.getCell(column) in my nodered-ui-Table so that when a user edited a specific cells or rows it will send a callbacks.
However, it seems like this function is not functioning well.
I have columns set via msg.ui_control to be something like this:
What I want is, when I edited tha column "Tagname", I want to get it's oldValue.
Before I can do this by using the
"cell.getOldValue()" function on cell component. However, due to I need to switch my function to be on "Row component" instead of cell. I change my code to be "row.getCell('measurement').getOldValue()"
However this function does not return the anything. As per document on tabulator:
The function returns the cell component of the specific column. So from what I understand, it is still the same as
cell.getOldValue()
here is my code where I put my function, it is under the msg.ui_control:
"title": "Tagname",
"field": "measurement",
"headerTooltip": "Tagname",
"editor": true,
"hozAlign": "center",
"headerFilter": "input",
"frozen": true,
"width": 200,
"validator": [
"required",
"unique"
"cellEdited": "function(row) {var new_data = {rowdata: row.getData(), passTagname:row.getCell(measurement).getOldValue(), callBack: 'editedTagname' }; this.send(new_data);}"
Again, I wanna tag my friend @Christian-Me. Hoping hope can suggest.
Thank you.
Regards,
Henjoe
