Run update configuration node via shell command
is there a way to update a configuration node via a shell command?
Reason:
I have some configuation nodes like FRITZ!Box which sometimes lose connection and they need to get restarted/update manually before working again.
Therefore I would like to restart/update the configuration node from outside node red.
I am not aware of how you can do that other than restarting node-red.
Have you submitted bug reports against the nodes?
no, not so far. I was looking for some way to restart node red e.g. from a browser but failed so far with this approach.
Since I am working with a CCU3 the browser access to the node red console to run a restart only works through the ccu3 GUI (as far as I know) - but since I am in this situation on my Mobile this is not the way I would like to go.
I am still testing some things.
Thanks for help!
Do you mean that node red is running in the ccu3?
Is that CCU3 Rain & Remote Window Control - Teal Products
yes, node red is running as plugin inside a homematic CCU3.
Thanks for the link. I will look into it in more detail later.
Anyhow: The issue can be closed. I found out I always have to do a full deployment insted only to deploy the changed flows. This is listed as a hint in some nodes I use. That was the reason why sometimes it worked and sometime lost connection.
