Running NR on a Mikrotik (docker container)
Hi, I need to create some automations and I would love to use NR for them, running inside a MIkrotik will give me the chance to don't add external hardware.
Yesterday I've created my first CHR Mikrotik on an ubuntu 22 server (VPS), and I've plant of space, CPU and RAM for experimenting. SInce I've running an image I don't have chance to ru NR on parallel on the same server, so please let's focus only on docker, thanks.
I've read there is a container named PI-hole for Mikrotik, but I don't know if it supports SSH to and make me able to install there NodeJs then NR, I also don't know if it can support python too, in case the modules may need it. Do you know any other compatible Docker? What you recomend? Thank you very much for suggestiing!
I've found NR docker, bu I have no clue if I can load it on Mikrotik and how..
https://hub.docker.com/r/nodered/node-red
