As promised - really simple way to read / write a JSON file for storing settings.
flow...
[{"id":"e5b9b9cccb321429","type":"tab","label":"settings file","disabled":false,"info":"","env":[]},{"id":"5bbab672f47f2bb2","type":"group","z":"e5b9b9cccb321429","name":"Read / write settings file \\n NOTE: this never needs to change!","style":{"label":true},"nodes":["abf0187e5c7ba3b3","6b74559a71f0b8e5","1d1a84e30f8f4bd0","cf1762cb6ad612ab","d1d4813a680d91bd","4a642877f344eabb","6829ecc8b2541d99","f506ddd488525490"],"x":34,"y":23,"w":752,"h":138},{"id":"d09213df05084c64","type":"inject","z":"e5b9b9cccb321429","name":"","props":[{"p":"payload"},{"p":"topic","vt":"str"}],"repeat":"","crontab":"","once":false,"onceDelay":0.1,"topic":"","payload":"","payloadType":"date","x":340,"y":260,"wires":[["81e7864349c4ad50"]]},{"id":"81e7864349c4ad50","type":"change","z":"e5b9b9cccb321429","name":"update settings.v1","rules":[{"t":"set","p":"settings.v1","pt":"global","to":"payload","tot":"msg"}],"action":"","property":"","from":"","to":"","reg":false,"x":550,"y":260,"wires":[[]]},{"id":"57369f189b61f0c4","type":"inject","z":"e5b9b9cccb321429","name":"","props":[{"p":"payload"},{"p":"topic","vt":"str"}],"repeat":"","crontab":"","once":false,"onceDelay":0.1,"topic":"","payload":"","payloadType":"date","x":340,"y":300,"wires":[["a8df0beb9c703763"]]},{"id":"a8df0beb9c703763","type":"change","z":"e5b9b9cccb321429","name":"update settings.another_setting","rules":[{"t":"set","p":"settings.another_setting","pt":"global","to":"payload","tot":"msg"}],"action":"","property":"","from":"","to":"","reg":false,"x":590,"y":300,"wires":[[]]},{"id":"7f1f141a17f65bd2","type":"inject","z":"e5b9b9cccb321429","name":"","props":[{"p":"payload"},{"p":"topic","vt":"str"}],"repeat":"","crontab":"","once":false,"onceDelay":0.1,"topic":"","payload":"settings.v1","payloadType":"global","x":360,"y":400,"wires":[["1211ec5315eab82a"]]},{"id":"1211ec5315eab82a","type":"debug","z":"e5b9b9cccb321429","name":"v1","active":true,"tosidebar":true,"console":false,"tostatus":true,"complete":"payload","targetType":"msg","statusVal":"payload","statusType":"auto","x":630,"y":380,"wires":[]},{"id":"0afc3a38b6ba4ebd","type":"inject","z":"e5b9b9cccb321429","name":"","props":[{"p":"payload"},{"p":"topic","vt":"str"}],"repeat":"","crontab":"","once":false,"onceDelay":0.1,"topic":"","payload":"settings.another_setting","payloadType":"global","x":400,"y":440,"wires":[["8484b83e5af9649d"]]},{"id":"8484b83e5af9649d","type":"debug","z":"e5b9b9cccb321429","name":"v1","active":true,"tosidebar":true,"console":false,"tostatus":true,"complete":"payload","targetType":"msg","statusVal":"payload","statusType":"auto","x":630,"y":440,"wires":[]},{"id":"d7acbc4fd35e1f24","type":"comment","z":"e5b9b9cccb321429","name":"Store values in settings","info":"","x":380,"y":220,"wires":[]},{"id":"d74c36636fb865af","type":"comment","z":"e5b9b9cccb321429","name":"Get values from settings","info":"","x":390,"y":360,"wires":[]},{"id":"abf0187e5c7ba3b3","type":"inject","z":"e5b9b9cccb321429","g":"5bbab672f47f2bb2","name":"Save to file","props":[],"repeat":"","crontab":"","once":false,"onceDelay":0.1,"topic":"","x":140,"y":80,"wires":[["1d1a84e30f8f4bd0"]]},{"id":"6b74559a71f0b8e5","type":"inject","z":"e5b9b9cccb321429","g":"5bbab672f47f2bb2","name":"Read from file","props":[],"repeat":"","crontab":"","once":false,"onceDelay":0.1,"topic":"","x":150,"y":120,"wires":[["4a642877f344eabb"]]},{"id":"1d1a84e30f8f4bd0","type":"function","z":"e5b9b9cccb321429","g":"5bbab672f47f2bb2","name":"get settings","func":"msg.payload = global.get(\"settings\") || {}\nreturn msg;","outputs":1,"noerr":0,"initialize":"","finalize":"","libs":[],"x":310,"y":80,"wires":[["cf1762cb6ad612ab"]]},{"id":"cf1762cb6ad612ab","type":"json","z":"e5b9b9cccb321429","g":"5bbab672f47f2bb2","name":"","property":"payload","action":"","pretty":false,"x":450,"y":80,"wires":[["d1d4813a680d91bd"]]},{"id":"d1d4813a680d91bd","type":"file","z":"e5b9b9cccb321429","g":"5bbab672f47f2bb2","name":"","filename":"user_settings.json","filenameType":"str","appendNewline":true,"createDir":false,"overwriteFile":"true","encoding":"none","x":640,"y":80,"wires":[[]]},{"id":"4a642877f344eabb","type":"file in","z":"e5b9b9cccb321429","g":"5bbab672f47f2bb2","name":"","filename":"user_settings.json","filenameType":"str","format":"utf8","chunk":false,"sendError":false,"encoding":"none","allProps":false,"x":330,"y":120,"wires":[["6829ecc8b2541d99"]]},{"id":"6829ecc8b2541d99","type":"json","z":"e5b9b9cccb321429","g":"5bbab672f47f2bb2","name":"","property":"payload","action":"","pretty":false,"x":490,"y":120,"wires":[["f506ddd488525490"]]},{"id":"f506ddd488525490","type":"function","z":"e5b9b9cccb321429","g":"5bbab672f47f2bb2","name":"store loaded settings","func":"global.set(\"settings\", msg.payload || {})\nreturn msg;","outputs":1,"noerr":0,"initialize":"","finalize":"","libs":[],"x":660,"y":120,"wires":[[]]}]
NOTE: this becomes pretty much redundant if all you need it to persist values between node-red restarts. As pointed out in previous post - look into persistent context (aka file based context)
