How or where do I search a array? Using the Unifi Node looking for RogueAPs mac and signal strength.
Use a function node and the filter function
Example: javascript - Filter array of objects with another array of objects - Stack Overflow
Or an equivalent using a change node and JSONata
thanks how do I find the name of the array? In the example its myArray , my output not sure suspect I need to put this into x to name it?
The name of the array, according to your screenshot is msg.payload
There’s a great page in the docs that will explain how to use the debug panel to find the right path to any data item.
Thanks and yes got that and can filter with a change node. What I want to figure out is searching the combined output for new bssid or oui for example from the combined output of the array (msg.payload). Looking for new bssid or oui not seen before. So this means I want to search the array for new unknown devices? Hopefully this makes sense.
So from what you say you want to identify any device not yet seen. The example Steve-Mcl pointed at provides the answer. You have to keep an array of known devices and compare the two arrays. From Stack Overflow (plus a bit),
const filterObjectArray = (arr, filterArr, filterProperty) => (
arr.filter(el =>
filterArr.every(f =>
f[filterProperty] !== el[filterProperty]
Then
let knownDevices = context.get('knownDevices', 'file') || []
let deviceArray = msg.payload
let unknownDevices = filterObjectArray(deviceArray, knownDevices, 'bssid')
.... do what ever you want with array of unknown devices
// Add unknown devices to known devices
knownDevices.push(...unknownDevices)
context.set('knownDevices', knownDevices, 'file')
The bssid should be unique so this should cover new oui properties also, but if you want to identify new oui properties as a separate check, rinse and repeat above using 'oui' as the filterProperty
You can do something similar to find non optimum signal strength
const minSignal = -40
const maxSignal = 30
const result = deviceArray.filter(device => device.signal < minSignal || device.signal > maxSignal)
Google is your friend but check the nodered docs for Node-RED and something like MDN Docs for javascript
Thanks Buckskin so I have added to a function node on message.
So this adds the knowdevices to unknown and does it compare?
Tried to review each portion of the code added // expressions/operators
So this should only return results between 30 to -40
device.signal less than minSignal || device.signal more than maxSignal
So the out out looks the same prior to the function node / javascript, what am I misunderstanding?
The use of the functions were examples and provide different results. You haven't added the results to the msg.
If you are after both unknown devices and bad signals then try
let msg.unknownDevices = unknownDevices
to get an array of unknownDevices, and after
const result = deviceArray.filter(device => device.signal < minSignal || device.signal > maxSignal)`
use
let msg.badSignal = result
return msg
You will then have to monitor msg.unknownDevices and msg.badSignal instead of msg.payload. Use a debug node set to 'complete message object'
If you just want devices with a bad signal just use
let msg.payload = deviceArray.filter(device => device.signal < minSignal || device.signal > maxSignal)
Note: change minSignal & maxSignal values to whatever values you are actually defining as bad
Thanks but still not understanding, could you give me a complete example of any device with its bssid, a signal of say 30 max, -40 min to then give a msg output (will use (MQTT). What I am trying to do is detect any device not on the wireless ie not connected and beaconing that has a signal between 30-40 with its BSSID to say that there is a unknown device close by? TIA.
Thanks Buckskin
