if i want to find a "change" node that sets the topit to motion and the value to outside i can not do that. i have to either search for motion or outside
when i implement search i split by space and do multiple searches so both words match.
Essentially, it means splitting the whole search term by space, searching for each individually and then sorting results based on number of matches across those individual searches - as well as looking for precise matches of the terms as provided.
Entirely doable, and a well scoped feature request for someone to pick up. If you wanted to raise an issue on gh covering this feature request, that would be welcome.
I can do that.
But there is one issue when using space as a separator. When you want to find something that contains an exact string.
i have used the + sign as a " "(space) replacement before to do this.
But since we are searching for source code here i think it can cause issues.
I suggest using "AND" in upper case as a separator. And add it to the search option list.
Then we can still search for terms like "value + offset" without it beeing split.
I considered using && but that could also interfer with source code
Another option is to use "and:also" as a separator. that looks more similar to the other modifiers
The precise implementation details can be thrashed out in the issue.
Without having put much thought into it, I can see a way that searches more smartly without the user needing to know all the syntax tricks.
If they searched for red blue green, we could search the index red blue green, red, blue, green, then sort the results based on how much of a match they are.
If a user wanted more precise multi-word search, then "red blue" green would search for red blue and green separately.
I think that would lead to a more intuitive search result without needing to adopt new syntaxes.
