Hi
I'm saving the sensor data to csv file and I want to send the saved csv file to telegram bot
I'm getting unsupported buffer file type when i send it as document type
Hi
So what is you problem and what have you tried?
Put a debug node (set to display the Complete msg object) on the output of your function node to see what you are sending
So that is not a document it is a buffer which is why you get the error. Try exporting your spreadsheet as a csv file and sending that
have you tried the other options?
yeah tried all four, didn't succeed
Is the incoming file is CSV format?? The CSV node
csv
Converts between a CSV formatted string and its JavaScript object representation, in either direction.
So if you are reading in a excel file it won't work. The file coming in has to be is CSV format (which is why I told you:
Once you've fixed the buffer issue, what makes you think that Telegram understands CSV format? What are you wanting to achieve?
If you want to upload it as a file that can be downloaded by a Telegram user, you need to format the payload correctly: Uploading and Downloading Files (telegram.org)
Thanks for the information,
I just needed the log file which can send me regularly
so, now I'm sticking to email
