Send data to vuetify element
Hi there!!!
I have this node, a vuetify switch element:
        "id": "57b22788516ec087",
        "type": "ui-template",
        "z": "7a3b4795ea906904",
        "group": "",
        "page": "",
        "ui": "fb4659d6be89de62",
        "name": "Data Entry dialog",
        "order": 0,
        "width": 0,
        "height": 0,
        "head": "",
        "format": "<template>\n  <div class=\"pa-4 text-center\">\n    <v-dialog\n      width=\"auto\"\n      scrollable\n    >\n      <template v-slot:activator=\"{ props: activatorProps }\">\n        <v-btn\n          color=\"brown\"\n          prepend-icon=\"mdi-earth\"\n          text=\"Selezione singola\"\n          variant=\"outlined\"\n          v-bind=\"activatorProps\"\n        ></v-btn>\n      </template>\n\n      <template v-slot:default=\"{ isActive }\">\n        \n        <v-card fluid>\n           <v-card-text class=\"px-5\" style=\"height: 300px;\">\n            \n    <p>{{ people }}</p>\n    <v-switch\n      v-model=\"people\"\n      color=\"primary\"\n      label=\"Mark\"\n      value=\"Mark\"\n      hide-details\n    ></v-switch>\n    <v-switch\n      v-model=\"people\"\n      color=\"primary\"\n      label=\"Karl\"\n      value=\"Karl\"\n      hide-details\n    ></v-switch>\n     <v-switch\n      v-model=\"people\"\n      color=\"primary\"\n      label=\"Frank\"\n      value=\"Frank\"\n      hide-details\n    ></v-switch>\n    <v-divider></v-divider>\n\n          <v-card-actions>\n            <v-btn\n              text=\"Close\"\n              @click=\"isActive.value = false\"\n            ></v-btn>\n\n            <v-spacer></v-spacer>\n\n            <v-btn\n              color=\"surface-variant\"\n              text=\"Save\"\n              variant=\"flat\"\n              @click=\"isActive.value = false\"\n            ></v-btn>\n  </v-card>\n</template>\n</template>\n<script>\n  export default { data () {\n      return {\n         people: \"\",\n      }\n    },\n   watch: {\n           \n        people: function () {\n                \n                    this.send({payload: this.people})\n                }\n   }\n  }\n</script>\n\n",
        "storeOutMessages": true,
        "passthru": true,
        "resendOnRefresh": true,
        "templateScope": "widget:ui",
        "className": "",
        "x": 170,
        "y": 540,
                "ad2f9c244e91400e"
        "id": "fb4659d6be89de62",
        "type": "ui-base",
        "name": "test _2",
        "path": "/dashboard",
        "includeClientData": true,
        "acceptsClientConfig": [
            "ui-notification",
            "ui-control"
        "showPathInSidebar": true,
        "navigationStyle": "default"
now i have created a csv file with the names (John, Sean, etc.) and i want send it to the Vuetify switch element and change them.
How can i do it?
Emilio
Interesting usecase. Adding details below to see if someone can assist.
UI Template Node:
<template>
  <div class="pa-4 text-center">
    <v-dialog
      width="auto"
      scrollable
      <template v-slot:activator="{ props: activatorProps }">
        <v-btn
          color="brown"
          prepend-icon="mdi-earth"
          text="Selezione singola"
          variant="outlined"
          v-bind="activatorProps"
        ></v-btn>
      </template>
      <template v-slot:default="{ isActive }">
        <v-card fluid>
           <v-card-text class="px-5" style="height: 300px;">
    <p>{{ people }}</p>
    <v-switch
      v-model="people"
      color="primary"
      label="Mark"
      value="Mark"
      hide-details
    ></v-switch>
    <v-switch
      v-model="people"
      color="primary"
      label="Karl"
      value="Karl"
      hide-details
    ></v-switch>
     <v-switch
      v-model="people"
      color="primary"
      label="Frank"
      value="Frank"
      hide-details
    ></v-switch>
          <v-card-actions>
            <v-btn
              text="Close"
              @click="isActive.value = false"
            ></v-btn>
            <v-btn
              color="surface-variant"
              text="Save"
              variant="flat"
            ></v-btn>
  </v-card>
</template>
</template>
<script>
      return {
         people: "",
   watch: {
</script>
At the time of writing this, the Vuetify website is down. I will take a look when it is back up. Maybe @joepavitt has some thoughts.
