Hi all,
I started a few months ago with Node red. Now I'm using Dashboard 2.0.
my starting point was, use switch element from Vuetify with the name of the operator, and it works:
"id": "49c3160479f04b6c",
"type": "ui-template",
"z": "7a3b4795ea906904",
"group": "",
"page": "",
"ui": "fb4659d6be89de62",
"name": "Data Entry dialog",
"order": 0,
"width": 0,
"height": 0,
"head": "",
"format": "<template>\n <div class=\"pa-4 text-center\">\n \n <v-dialog\n width=600px\n scrollable\n \n >\n <template v-slot:activator=\"{ props: activatorProps }\">\n <v-btn\n color=\"brown\"\n prepend-icon=\"mdi-earth\"\n text=\"Selezione multipla\"\n variant=\"outlined\"\n v-bind=\"activatorProps\"\n ></v-btn>\n </template>\n\n <template v-slot:default=\"{ isActive }\">\n \n <v-card fluid>\n <v-card-text class=\"px-4\" style=\"height: 300px;\">\n \n <p>{{ people }}</p>\n <v-switch\n v-model=\"people\"\n color=\"primary\"\n label=\"Matteo\"\n value=\"Matteo\"\n hide-details\n ></v-switch>\n <v-switch\n v-model=\"people\"\n color=\"primary\"\n label=\"Mario\"\n value=\"Mario\"\n hide-details\n ></v-switch>\n <v-switch\n v-model=\"people\"\n color=\"primary\"\n label=\"Franco\"\n value=\"Franco\"\n hide-details\n ></v-switch>\n <v-divider></v-divider>\n\n <v-card-actions>\n <v-btn\n text=\"Close\"\n @click=\"isActive.value = false\"\n ></v-btn>\n\n <v-spacer></v-spacer>\n\n <v-btn\n color=\"surface-variant\"\n text=\"Save\"\n variant=\"flat\"\n @click=\"isActive.value = false\"\n ></v-btn>\n </v-card>\n</template>\n</template>\n<script>\n export default { data () {\n return {\n people: [],\n }\n },\n watch: {\n \n people: function () {\n \n this.send({payload: this.people})\n }\n }\n }\n</script>\n\n",
"storeOutMessages": true,
"passthru": true,
"resendOnRefresh": true,
"templateScope": "widget:ui",
"className": "",
"x": 210,
"y": 620,
"aaff62236bcf200e"
"id": "fb4659d6be89de62",
"type": "ui-base",
"name": "test _2",
"path": "/dashboard",
"includeClientData": true,
"acceptsClientConfig": [
"ui-notification",
"ui-control"
"showPathInSidebar": true,
"navigationStyle": "default"
But i want load the operator name from a csv file, but I can't get it to work
below what i have done (but it doesn't work
"id": "ffce0710a655267d",
"type": "inject",
"props": [
"p": "payload"
"p": "topic",
"vt": "str"
"repeat": "",
"crontab": "",
"once": false,
"onceDelay": 0.1,
"topic": "",
"payload": "",
"payloadType": "date",
"x": 360,
"y": 1080,
"b84afeccebde798a"
"id": "b84afeccebde798a",
"type": "file in",
"name": "Read CSV",
"filename": "your csv file",
"filenameType": "str",
"format": "utf8",
"allProps": false,
"x": 550,
"y": 1080,
"bba130a584d68c83",
"e81a8ccafd106bfa"
"id": "bba130a584d68c83",
"type": "debug",
"name": "debug 395",
"active": true,
"tosidebar": true,
"console": false,
"tostatus": false,
"complete": "payload",
"targetType": "msg",
"statusVal": "",
"statusType": "auto",
"x": 810,
"y": 1000,
"id": "e81a8ccafd106bfa",
"type": "csv",
"name": "Parse CSV",
"sep": ",",
"hdrin": true,
"hdrout": "none",
"multi": "mult",
"temp": "",
"skip": 0,
"strings": true,
"include_empty_strings": false,
"include_null_values": false,
"x": 690,
"y": 1180,
"223e29b6390d746d",
"07aad9509142be12"
"id": "223e29b6390d746d",
"type": "function",
"name": "Process Data",
"func": "node.send({ topic: 'updatePeople', payload: msg.payload }); // Ensure msg.payload is the array of objects from CSV",
"outputs": 1,
"timeout": "",
"noerr": 0,
"initialize": "",
"finalize": "",
"libs": [],
"x": 950,
"y": 1080,
"247357969cba7be9",
"2ae101cceb16574b"
"id": "07aad9509142be12",
"type": "debug",
"name": "debug 396",
"active": true,
"tosidebar": true,
"console": false,
"tostatus": false,
"statusVal": "",
"x": 930,
"y": 1180,
"id": "247357969cba7be9",
"type": "debug",
"name": "debug 397",
"active": true,
"tosidebar": true,
"console": false,
"tostatus": false,
"statusVal": "",
"x": 1150,
"y": 1120,
"id": "2ae101cceb16574b",
"group": "",
"page": "",
"order": 0,
"width": 0,
"height": 0,
"head": "",
"format": "\n<template>\n <div class=\"pa-4 text-center\">\n <v-dialog width=\"600px\" scrollable>\n <template v-slot:activator=\"{ props: activatorProps }\">\n <v-btn color=\"brown\" prepend-icon=\"mdi-earth\" text=\"Select Names\" variant=\"outlined\" v-bind=\"activatorProps\">\n </v-btn>\n </template>\n\n <template v-slot:default=\"{ isActive }\">\n <v-card fluid>\n <v-card-text class=\"px-4\" style=\"height: 300px;\">\n <div v-for=\"person in people\" :key=\"person.name\">\n <v-switch\n v-model=\"selectedPeople\"\n color=\"primary\"\n :label=\"person.name\"\n :value=\"person.name\"\n hide-details\n ></v-switch>\n </div>\n </v-card-text>\n <v-card-actions>\n <v-btn text=\"Close\" @click=\"isActive = false\"></v-btn>\n <v-spacer></v-spacer>\n <v-btn color=\"surface-variant\" text=\"Save\" variant=\"flat\" @click=\"sendData\"></v-btn>\n </v-card-actions>\n </v-card>\n </template>\n </v-dialog>\n </div>\n</template>\n\n<script>\nexport default {\n data() {\n return {\n people: [],\n selectedPeople: []\n };\n },\n methods: {\n sendData() {\n this.$emit('input', this.selectedPeople);\n this.isActive = false;\n }\n },\n mounted() {\n this.$root.$on('updatePeople', (newPeople) => {\n this.people = newPeople;\n this.$forceUpdate(); // Force the component to re-render with new data\n });\n }\n}\n</script>\n",
"passthru": true,
"className": "",
"x": 1170,
"y": 1000,
"eeab9c04ec763ad2"
"id": "eeab9c04ec763ad2",
"type": "debug",
"name": "debug 394",
"active": true,
"tosidebar": true,
"console": false,
"tostatus": false,
"complete": "true",
"targetType": "full",
"statusVal": "",
"x": 1350,
"y": 1000,
"type": "ui-base",
"name": "test _2",
"ui-notification",
"ui-control"
what i made wrong?
Thank you all!
Emilio
