Hi Everyone,
I need to know if we can send email to another domain in outlook from node red.
for ex: firstname.lastname@global.mydomain
kindly share some ideas
Hi Everyone,
you would need access to an SMTP server, but seems this node could help
SMTP is typically for sending emails. You probably need POP3 or IMAP (look up outlook connectivity options) - I believe outlook.com supports both (IMAP is better option)
You are using the wrong node - see below
you have dropped the wrong node on your flow.
let me check. Thanks for reply
