Hi, With the help of node red tutorial. I was able to install the node red.
Could It be possible to send the Data of sensor through ESP8266 by using the public IP (alotted by AWS server) to be defined as MQTT server in MQTT node as well as in code?
Is it possible to send the sensor data using WebSockets?
Suggestion on this will be really helpful.
