Sending email with other servers instead of gmail
I'm trying to send mail using mail node ..can i send to a mail that's not in gmail domain for example:xxxxxxxx@delta.me
Thanks in advance
Do you mean you want to send an email to that email address, but using the gmail email server to send it, or do you mean you want to use a different email server?
use different mail server instead of smtp.gmail.com
Yes, just set the details in the node config.
can you tell me what should i change cause when im trying to change server to "smtp.delta.me" my mail domain it gives me error
Check with your host as to what the settings should be to send mail. You might find it on their webpage/tech-support page.
Are you able to use the server using a desktop email client? If so then the settings should be the same as you use for that.
