Sending msg.payload after Countdown
Hi, I am not good at Angular JS.
I am trying to send an msg.payload after an countdown, see the code below.
 <script>
    var myTimer;
    function clock()
       var myTimer = setInterval(myClock, 1000);
        var c = 20;
        function myClock()
            document.getElementById("demo").innerHTML = --c;
            if (c == 0)
                    (function(scope)
                        scope.send({payload: "something"});
                (scope);
</script>
<p id="demo" align="center">{{msg}}</p>
<br><br>
<button onclick="clock();">>Start counter</button>
[{"id":"1af6dff0.69f998","type":"debug","z":"eb0da159.829678","name":"","active":true,"tosidebar":true,"console":false,"tostatus":false,"complete":"false","x":910,"y":60,"wires":[]},{"id":"c659cd6c.0564c","type":"ui_template","z":"eb0da159.829678","group":"d8ee9c1c.4e4748","name":"","order":3,"width":"12","height":"8","format":" <script>  \n    var myTimer;\n    function clock() \n    {\n       var myTimer = setInterval(myClock, 1000);\n        var c = 20;\n\n        function myClock() \n        {\n            document.getElementById(\"demo\").innerHTML = --c;\n\n            if (c == 0) \n            {\n                \n                    (function(scope)\n                    {\n                        scope.send({payload: \"something\"});\n                    })\n                \n                (scope); \n              \n\n            }\n        }\n    }\n\n</script>\n\n<p id=\"demo\" align=\"center\">{{msg}}</p>\n<br><br>\n<button onclick=\"clock();\">>Start counter</button>\n","storeOutMessages":true,"fwdInMessages":false,"resendOnRefresh":true,"templateScope":"local","x":120,"y":60,"wires":[["9d6cd887.ff10a8","1af6dff0.69f998"]]},{"id":"d8ee9c1c.4e4748","type":"ui_group","z":"","name":"FRAMATECH Fight Light","tab":"421e8764.5d6f7","order":1,"disp":true,"width":"12","collapse":false},{"id":"421e8764.5d6f7","type":"ui_tab","z":"","name":"FRAMATECH Fight Light","icon":"dashboard","disabled":false,"hidden":false}]
But it doesnt work because "19:17:36.597 Uncaught ReferenceError: scope is not defined
myClock line 20 > scriptElement:20
ui:20:1
Could you help me please?
Thx :slight_smile:
Have you tried using a javascript console in your browser to see what might be happening?
From the message scope is not defined we both know its obvious whats wrong but should we point out the elephant in the room?
This will only work if a browser is open (i.e. this will be client side) - do we think the OP wants this to run when the browser is closed (server/no-red side)? :thinking:
Hi Steve, yes it only should run if the Browser is open.
@zenofmud I saw the error in the javascript console :wink:
The error is because of the line with "(scope);"
Look at the examples in the built in help on the sidebar. If I remember right, you need to access scope via this (however since you will be inside a timer callback, you will likely need to bind this or store this in that before you setup the timer & access that.scope)
Hi @Steve-Mcl,
I dont get it. I dont know where to set this and that. Could you help me pls?
Off the top of my head (untested)...
<script>
    var that = this; //save a ref to this in that
    var c = 20;
    function myClock() {
        if (c <= 0) {
            that.scope.send({payload: "something"}); // this is not that :) (this is the timers instance, that is original scope)
            clearInterval(myTimer);
</script>
thx, but same Issue again :"Uncaught TypeError: that.scope is undefined"
You havent posted enough of the ui_template for me to see where you have integrated it
oh sry
 <script>
 var myTimer;
function Clock()
    var c = 20;
        if (c <= 0) {
</script>
<p id="demo" align="center">20</p>
<br><br>
<button onclick="Clock();">>Start counter</button>
Try this...
<script>
(function(scope) {
    window.$scope = scope; //save a ref in window/global
    //create startClock function
    $scope.startClock = function() {
        $scope.countDown = 20;
        if($scope.myTimer) clearInterval($scope.myTimer);
        $scope.myTimer = setInterval($scope.clockTick, 1000);
    //create clockTick function
    $scope.clockTick = function() {
        document.getElementById("demo").innerHTML = --$scope.countDown;
        if ($scope.countDown <= 0) {
            $scope.myTimer = null;
            $scope.send({payload: "something"});
})(scope);
</script>
<p id="demo" align="center">-</p>
<br><br>
<button onclick="$scope.startClock();">>Start counter</button>
Thx it works great, and know I try to understand this script xD
