Separate Two MQTT Temperature Payloads?
How do I separate these two MQTT temp payloads so that I can work with them. I have tried using a function node but, I'm really lost.
I have a nodemcu running tasmota with two DS18B20 sensors attached and returning 2 separate temperature readings using MQTT.
This is the debug I get from my MQTT input on Nodered.
nodered
object
topic: "tele/relaystack/SENSOR"
payload: "{"Time":"2021-09-22T16:10:36","DS18B20-1":{"Id":"0516A37095FF","Temperature":23.6},"DS18B20-2":{"Id":"3C01F095CECB","Temperature":23.7},"TempUnit":"C"}"
qos: 0
retain: false
_msgid: "4cb28f7c.a6be3"
Tasmota output
16:09:46.424 MQT: tele/relaystack/SENSOR = {"Time":"2021-09-22T16:09:46","DS18B20-1":{"Id":"0516A37095FF","Temperature":23.6},"DS18B20-2":{"Id":"3C01F095CECB","Temperature":23.7},"TempUnit":"C"}
firstly, set the MQTT in node to parse JSON
Next, you can use the "copy path" button in the debug to get the path to any item - then use 2 change nodes to move the values around
There’s a great page in the docs that will explain how to use the debug panel to find the right path to any data item.
BX00Cy7yHi
https://nodered.org/docs/user-guide/messages
PS, please use the "copy value" button when posting values / code on the forum. Also, use the </> code button so that code is formatted correctly
Thanks for the help.
I have switched it as you said to JSON object.
I'm not sure what to put in the change node.
[{"id":"2451fec2.edb1b2","type":"mqtt in","z":"c74b932.e47c17","name":"DS18B20 Temp Sensors","topic":"tele/relaystack/SENSOR","qos":"0","datatype":"json","broker":"389dd264.7716de","nl":false,"rap":true,"rh":0,"x":390,"y":1820,"wires":[["6fb9b1fa.e3e9a","7f1002d3.21145c","7d2b290.61cfcd8"]]},{"id":"698c33fb.3193cc","type":"debug","z":"c74b932.e47c17","name":"","active":true,"tosidebar":true,"console":false,"tostatus":false,"complete":"true","targetType":"full","statusVal":"","statusType":"auto","x":1050,"y":1860,"wires":[]},{"id":"682f8968.4c2698","type":"debug","z":"c74b932.e47c17","name":"","active":true,"tosidebar":true,"console":false,"tostatus":false,"complete":"true","targetType":"full","statusVal":"","statusType":"auto","x":1050,"y":1800,"wires":[]},{"id":"7f1002d3.21145c","type":"change","z":"c74b932.e47c17","name":"","rules":[{"t":"set","p":"payload[\"DS18B20-1\"].Temperature","pt":"msg","to":"","tot":"num"}],"action":"","property":"","from":"","to":"","reg":false,"x":750,"y":1800,"wires":[["682f8968.4c2698"]]},{"id":"7d2b290.61cfcd8","type":"change","z":"c74b932.e47c17","name":"","rules":[{"t":"set","p":"payload[\"DS18B20-2\"].Temperature","pt":"msg","to":"","tot":"num"}],"action":"","property":"","from":"","to":"","reg":false,"x":750,"y":1860,"wires":[["698c33fb.3193cc"]]},{"id":"389dd264.7716de","type":"mqtt-broker","z":"c74b932.e47c17","name":"","broker":"192.168.10.65","port":"1883","clientid":"Node-Red","usetls":false,"protocolVersion":"4","keepalive":"60","cleansession":true,"birthTopic":"","birthQos":"0","birthPayload":"","birthMsg":{},"closeTopic":"","closePayload":"","closeMsg":{},"willTopic":"","willQos":"0","willPayload":"","willMsg":{},"sessionExpiry":""}]
Set msg.payload to the path (from Copy Path button) of the element you want.
For example
Untitled 8
Or, if you prefer, which I generally do as it seems more intuitive, is use Move rather than Set. Then it is Move msg.payload.whatever To msg.payload.
I couldn't figure out the "set msg.payload"
But the "move msg.payload" worked.
Here is the flow.
[{"id":"2451fec2.edb1b2","type":"mqtt in","z":"c74b932.e47c17","name":"DS18B20 Temp Sensors","topic":"tele/relaystack/SENSOR","qos":"0","datatype":"json","broker":"389dd264.7716de","nl":false,"rap":true,"rh":0,"x":350,"y":1860,"wires":[["6fb9b1fa.e3e9a","7f1002d3.21145c","7d2b290.61cfcd8"]]},{"id":"698c33fb.3193cc","type":"debug","z":"c74b932.e47c17","name":"","active":true,"tosidebar":true,"console":false,"tostatus":false,"complete":"true","targetType":"full","statusVal":"","statusType":"auto","x":770,"y":1880,"wires":[]},{"id":"682f8968.4c2698","type":"debug","z":"c74b932.e47c17","name":"","active":true,"tosidebar":true,"console":false,"tostatus":false,"complete":"true","targetType":"full","statusVal":"","statusType":"auto","x":770,"y":1840,"wires":[]},{"id":"7f1002d3.21145c","type":"change","z":"c74b932.e47c17","name":"Prob 1","rules":[{"t":"move","p":"payload[\"DS18B20-1\"].Temperature","pt":"msg","to":"payload","tot":"msg"}],"action":"","property":"","from":"","to":"","reg":false,"x":590,"y":1840,"wires":[["682f8968.4c2698","864641df.89983"]]},{"id":"7d2b290.61cfcd8","type":"change","z":"c74b932.e47c17","name":"Prob 2","rules":[{"t":"move","p":"payload[\"DS18B20-2\"].Temperature","pt":"msg","to":"payload","tot":"msg"}],"action":"","property":"","from":"","to":"","reg":false,"x":590,"y":1880,"wires":[["698c33fb.3193cc"]]},{"id":"389dd264.7716de","type":"mqtt-broker","z":"c74b932.e47c17","name":"","broker":"192.168.10.65","port":"1883","clientid":"Node-Red","usetls":false,"protocolVersion":"4","keepalive":"60","cleansession":true,"birthTopic":"","birthQos":"0","birthPayload":"","birthMsg":{},"closeTopic":"","closePayload":"","closeMsg":{},"willTopic":"","willQos":"0","willPayload":"","willMsg":{},"sessionExpiry":""}]
I am building a pool controller with an Arduino for the sensors and relays inside the steel control panel and a raspberry pie with a built in 5 inch touch screen placed on the patio, to replace my old dated goldline pool controller.
I don't know why the Set syntax is confusing. It is perfectly logical. If I said Set the volume control To 50% you would know exactly what I meant, and it would be obviously incorrect if I said Set 50% To the volume control. But if I put, in the Change node, Set msg.payload To msg.payload.some_property then for some unfathomable reason it isn't immediately obvious and I have to think about what it means. That is why I almost always use Move.
