What do you mean with "just stops" ? Are you outputting into the debug window ? because there is only a limited amount of data it will display - which could make it appear that it just stops.
Yeah i am checking with debug and chart node. I mean no data is received from the node after 4-5 minutes. I checked with other serial terminal, it is coming.
Why are you building an array for the data when it is live data coming in ? - Why not just send the numeric payload from the serial input as a payload direct to the chart - the chart will add the timestamp - and you can set it to limit it to 50 reading etc.
How do i limit it to 50 at a time. I have data coming around 50 per sec. Shall i limit using delay node or is there something in the chart node itself ?
Why is serial node stopping and not receiving any data ?
I would use either the delay node in rate limit mode - set to drop intermediate messages - or use the smooth node (to create an average) and tick the reduce option to only emit the value every x samples.
Sorry - not sure what you mean - in what way doesn't it work ?
If you aren't receiving anything from the serial node then indeed nothing further will work.
Add a debug directly to the output and see what it is receiving.
I mean the serial node stops showing anything after 4-5 minutes in the debug node.
I could see the data coming with other serial terminal software (to see whether data is coming on the COM port or not)
Select the serial node and Export it, then paste it here. Use the </> button at the top of the forum entry window when pasting it.
Also what version of node-red, node.js and the serial node are you using?
No Colin. After sometime, the serial in node shows no data. It has something to do with NodeRED. I disabled the serial node and checked with putty, got the data.
