Serial message structure
Bonjour
If someone can tell me what I'm missing to have the same format of the message that I want to send by an rf433 frame
the first is OK and the second is NOK
thanks in advance
Capture d’écran du 2022-07-26 18-52-49
It looks like there is a CR/LF at the end of the first message that is missing from the second one.
You can add / control the contents of a STRING using the 'node-red-contrib-string' node.
This can be installed from the 'Manage Palette' option.
Cheers,
Paul
Just try adding
/n
to the end of the second string.
I ghayne
I ad: /n but now
Capture d’écran du 2022-07-26 20-02-06
I ghayne and paulkeates
I installed node-red-contrib-string and put \r\n and it's OK now
thank you for everything
Remy
