Set Bounds on Form Number Inputs
Is there a way to set an expected input value range on the form item? e.g. A user should input an angle that is between 0 and 90 degrees. Values outside of this range would be rejected when submit is chosen similar to a non-value in a required field.
Zach
Sorry - this is not available within a form node.
You can do this using the normal numeric picker.
You can use a join node set to manual create key value object to wait for several widgets and to create a single msg like a form if you like.
Thanks dceejay. That's helpful. I'll investigate the join node and see what I can come up with.
Has this been put up as a suggested improvement as would have thought basic expectation for a form along with the ability set a default value. Simple addition to handle all data types would be the ability to give a regex expression for validations
It has been suggested above... Just waiting for someone to write the code and submit the pull request.
Has been this option added?
Or is there any other way how to do this?
no - still waiting for volunteers.
There is always another option
example
[{"id":"98d7fb26.26d25","type":"ui_form","z":"c791cbc0.84f648","name":"","label":"","group":"2d4fe667.28f8ba","order":23,"width":0,"height":0,"options":[{"label":"input","value":"input","type":"number","required":true,"rows":null},{"label":"name","value":"name","type":"text","required":true,"rows":null}],"formValue":{"input":"","name":""},"payload":"","submit":"submit","cancel":"cancel","topic":"topic","topicType":"msg","splitLayout":"","className":"","x":210,"y":4080,"wires":[["30579684.62f662"]]},{"id":"30579684.62f662","type":"switch","z":"c791cbc0.84f648","name":"","property":"payload.input","propertyType":"msg","rules":[{"t":"btwn","v":"0","vt":"num","v2":"10","v2t":"num"},{"t":"regex","v":"[^A-Za-z ]","vt":"str","case":false},{"t":"else"}],"checkall":"false","repair":false,"outputs":3,"x":380,"y":4080,"wires":[["d7873c61.99e668"],["d51abdca.88ee18"],["a5648c52.d01338","605acf77.c5b598"]]},{"id":"d7873c61.99e668","type":"change","z":"c791cbc0.84f648","name":"","rules":[{"t":"set","p":"error","pt":"msg","to":"Error name a-z and space only","tot":"str"}],"action":"","property":"","from":"","to":"","reg":false,"x":570,"y":4180,"wires":[["f11e6c50.61f3d8","98d7fb26.26d25"]]},{"id":"d51abdca.88ee18","type":"change","z":"c791cbc0.84f648","name":"","rules":[{"t":"set","p":"error","pt":"msg","to":"Error input not between 0 and 10","tot":"str"}],"action":"","property":"","from":"","to":"","reg":false,"x":570,"y":4220,"wires":[["f11e6c50.61f3d8","98d7fb26.26d25"]]},{"id":"a5648c52.d01338","type":"change","z":"c791cbc0.84f648","name":"","rules":[{"t":"set","p":"error","pt":"msg","to":"","tot":"str"}],"action":"","property":"","from":"","to":"","reg":false,"x":570,"y":4020,"wires":[["f11e6c50.61f3d8"]]},{"id":"605acf77.c5b598","type":"debug","z":"c791cbc0.84f648","name":"","active":true,"tosidebar":true,"console":false,"tostatus":false,"complete":"false","statusVal":"","statusType":"auto","x":750,"y":4100,"wires":[]},{"id":"f11e6c50.61f3d8","type":"ui_text","z":"c791cbc0.84f648","group":"2d4fe667.28f8ba","order":24,"width":0,"height":0,"name":"","label":"","format":"{{msg.error}}","layout":"row-spread","className":"","x":810,"y":4200,"wires":[]},{"id":"2d4fe667.28f8ba","type":"ui_group","name":"demo","tab":"1caa8458.b17814","order":1,"disp":true,"width":"12","collapse":false},{"id":"1caa8458.b17814","type":"ui_tab","name":"Demo","icon":"dashboard","order":1,"disabled":false,"hidden":false}]
Thx for your reply. I found out I need more complicated inputs in the form then the standard (dropdown menu etc.) so I choose to use UI_template node.
But I can't get the form working in there ... I started an issue: Trying to create Angular Form inside UI template
