Trying to create Angular Form inside UI template
Hello everyone!
  • I am trying to use the ui_template to use reactive Angular form.
  • My goal for now is to have 2 required inputs and disable / enable button depending on if they are filled.
I managed to make together easy example of the form:
<script>
var value = "hello world";
// or overwrite value in your callback function ...
this.scope.action = function() { return value; }
</script>
<md-content layout-padding>
<form name="form" [formGroup]="form">
    <md-input-container class="md-block" flex-gt-sm>
      <label> Numeric </label>
      <input type="number" required name="number"/>
    </md-input-container>
      <label> Text </label>
      <input type="text" required name="number"/>
    <md-button type="submit" ng-click="send({payload:action()})" class="btn btn-primary" [disabled]="!form.valid">
        Submit
    </md-button>
</form>
</md-content>
I want to disable the submit button with this code: [disabled]="!form.valid" but the button is always enabled:
And weird thing is that when I click the submit button my message in the script is send + also the inputs notify me they are no filled:
Can anyone help me with this?
I don't wanna use the form node because I want to set limits to the numeric values. And as suggested in this post it cant be done.
Maybe you dont need to disable the Submit button because if you do the re-validation will not trigger and you will not get the new validation error msgs.
Try this (blocking the send command if the form validation fails ? )
  <form name="form" ng-submit="sendMsg(form)">
      <input type="number" ng-model="input1" required name="number"/>
      <input type="text" ng-model="input2" required name="number"/>
    <md-button type="submit" class="btn btn-primary">
      Submit
    </md-button>
  </form>
</md-content>
<script>
var theScope = scope;
//theScope.action = function() { return value; }
theScope.sendMsg = function(form) {
  if (form.$valid) {
  theScope.send({ payload: {
    input1: theScope.input1,
    input2: theScope.input2
</script>
ps. see the code of the second example of the AngularJS Material web site
