Ui-template <button> fails to send message including {{msg.property}} content
Fellow ui-template pro's,
I'm using ui-template to setup a table displaying the content of an incoming message containing an array of objects. With ng-repeat I can create the html table, add and label buttons and checkboxes. I want the buttons to work as a toggle, therefore need it to send the current state and an ID info like:
<button name="activate"
    ng-click="send({'schedule':{{msg.schedules[$index].ID}}, 'active': {{msg.schedules[$index].active}}, 'once': {{msg.schedules[$index].once}} })"
 >{{msg.schedules[$index].button}}</button>
Now, while the labelling works with the {{}} notation, the button fails to send anything. At the same time, an sends the exact same message correctly on ng-change:
<input
type="checkbox"
id="once"
name="activate"
ng-checked="{{msg.schedules[$index].once}}"
ng-model="check1"
ng-change="send({'schedule':{{msg.schedules[$index].ID}}, 'active': {{msg.schedules[$index].active}}, 'once': {{msg.schedules[$index].once}} })"
> once
Any ideas as to why that's not working or why the is, would be extremely appreciated.
Clemens
example flow:
        "id": "ad7a80fa64d29e50",
        "type": "tab",
        "label": "Flow 1",
        "disabled": false,
        "info": "",
        "env": []
        "id": "dbbf35627f50c7fe",
        "type": "inject",
        "z": "ad7a80fa64d29e50",
        "props": [
                "p": "schedules",
                "v": "[{\"ID\":1,\"Name\":\"morning\",\"lastRun\":null,\"repetition\":1,\"nextRun\":null,\"active\":0,\"once\":1,\"button\":\"once\"},{\"ID\":2,\"Name\":\"early\",\"lastRun\":null,\"repetition\":1,\"nextRun\":null,\"active\":0,\"once\":1,\"button\":\"once\"},{\"ID\":3,\"Name\":\"late\",\"lastRun\":null,\"repetition\":1,\"nextRun\":null,\"active\":0,\"once\":0,\"button\":\"off\"}]",
                "vt": "json"
                "p": "schedulesArray",
                "v": "[[{\"slot\":\"05:00:00\",\"displayText\":\" 05:00:00\"},{\"Relay\":\"Relay1\",\"displayText\":\" Relay1\",\"backgroundcolor\":\"LightSkyBlue\"},{\"Relay\":\"\",\"displayText\":\"...\",\"backgroundcolor\":\"white\"},{\"Relay\":\"\",\"displayText\":\"...\",\"backgroundcolor\":\"white\"}],[{\"slot\":\"05:30:00\",\"displayText\":\" 05:30:00\"},{\"Relay\":\"Relay2\",\"displayText\":\" Relay2\",\"backgroundcolor\":\"LightSkyBlue\"},{\"Relay\":\"\",\"displayText\":\"...\",\"backgroundcolor\":\"white\"},{\"Relay\":\"\",\"displayText\":\"...\",\"backgroundcolor\":\"white\"}],[{\"slot\":\"06:00:00\",\"displayText\":\" 06:00:00\"},{\"Relay\":\"Relay5\",\"displayText\":\" Relay5\",\"backgroundcolor\":\"LightSkyBlue\"},{\"Relay\":\"\",\"displayText\":\"...\",\"backgroundcolor\":\"white\"},{\"Relay\":\"\",\"displayText\":\"...\",\"backgroundcolor\":\"white\"}],[{\"slot\":\"06:30:00\",\"displayText\":\" 06:30:00\"},{\"Relay\":\"Relay6\",\"displayText\":\" Relay6\",\"backgroundcolor\":\"LightSkyBlue\"},{\"Relay\":\"\",\"displayText\":\"...\",\"backgroundcolor\":\"white\"},{\"Relay\":\"\",\"displayText\":\"...\",\"backgroundcolor\":\"white\"}],[{\"slot\":\"07:00:00\",\"displayText\":\" 07:00:00\"},{\"Relay\":\"Relay4\",\"displayText\":\" Relay4\",\"backgroundcolor\":\"LightSkyBlue\"},{\"Relay\":\"\",\"displayText\":\"...\",\"backgroundcolor\":\"white\"},{\"Relay\":\"\",\"displayText\":\"...\",\"backgroundcolor\":\"white\"}],[{\"slot\":\"07:30:00\",\"displayText\":\" 07:30:00\"},{\"Relay\":\"Relay3\",\"displayText\":\" Relay3\",\"backgroundcolor\":\"LightSkyBlue\"},{\"Relay\":\"\",\"displayText\":\"...\",\"backgroundcolor\":\"white\"},{\"Relay\":\"\",\"displayText\":\"...\",\"backgroundcolor\":\"white\"}],[{\"slot\":\"08:00:00\",\"displayText\":\" 08:00:00\"},{\"Relay\":\"Relay3\",\"displayText\":\" Relay3\",\"backgroundcolor\":\"LightSkyBlue\"},{\"Relay\":\"\",\"displayText\":\"...\",\"backgroundcolor\":\"white\"},{\"Relay\":\"\",\"displayText\":\"...\",\"backgroundcolor\":\"white\"}],[{\"slot\":\"08:30:00\",\"displayText\":\" 08:30:00\"},{\"Relay\":\"\",\"displayText\":\"...\",\"backgroundcolor\":\"white\"},{\"Relay\":\"Relay2\",\"displayText\":\" Relay2\",\"backgroundcolor\":\"LightSkyBlue\"},{\"Relay\":\"\",\"displayText\":\"...\",\"backgroundcolor\":\"white\"}],[{\"slot\":\"09:00:00\",\"displayText\":\" 09:00:00\"},{\"Relay\":\"\",\"displayText\":\"...\",\"backgroundcolor\":\"white\"},{\"Relay\":\"Relay4\",\"displayText\":\" Relay4\",\"backgroundcolor\":\"LightSkyBlue\"},{\"Relay\":\"\",\"displayText\":\"...\",\"backgroundcolor\":\"white\"}],[{\"slot\":\"09:30:00\",\"displayText\":\" 09:30:00\"},{\"Relay\":\"\",\"displayText\":\"...\",\"backgroundcolor\":\"white\"},{\"Relay\":\"Relay1\",\"displayText\":\" Relay1\",\"backgroundcolor\":\"LightSkyBlue\"},{\"Relay\":\"\",\"displayText\":\"...\",\"backgroundcolor\":\"white\"}],[{\"slot\":\"10:00:00\",\"displayText\":\" 10:00:00\"},{\"Relay\":\"\",\"displayText\":\"...\",\"backgroundcolor\":\"white\"},{\"Relay\":\"Relay5\",\"displayText\":\" Relay5\",\"backgroundcolor\":\"LightSkyBlue\"},{\"Relay\":\"\",\"displayText\":\"...\",\"backgroundcolor\":\"white\"}],[{\"slot\":\"10:30:00\",\"displayText\":\" 10:30:00\"},{\"Relay\":\"\",\"displayText\":\"...\",\"backgroundcolor\":\"white\"},{\"Relay\":\"Relay6\",\"displayText\":\" Relay6\",\"backgroundcolor\":\"LightSkyBlue\"},{\"Relay\":\"\",\"displayText\":\"...\",\"backgroundcolor\":\"white\"}],[{\"slot\":\"11:00:00\",\"displayText\":\" 11:00:00\"},{\"Relay\":\"\",\"displayText\":\"...\",\"backgroundcolor\":\"white\"},{\"Relay\":\"Relay3\",\"displayText\":\" Relay3\",\"backgroundcolor\":\"LightSkyBlue\"},{\"Relay\":\"\",\"displayText\":\"...\",\"backgroundcolor\":\"white\"}],[{\"slot\":\"11:30:00\",\"displayText\":\" 11:30:00\"},{\"Relay\":\"\",\"displayText\":\"...\",\"backgroundcolor\":\"white\"},{\"Relay\":\"Relay3\",\"displayText\":\" Relay3\",\"backgroundcolor\":\"LightSkyBlue\"},{\"Relay\":\"\",\"displayText\":\"...\",\"backgroundcolor\":\"white\"}],[{\"slot\":\"12:00:00\",\"displayText\":\" 12:00:00\"},{\"Relay\":\"\",\"displayText\":\"...\",\"backgroundcolor\":\"white\"},{\"Relay\":\"\",\"displayText\":\"...\",\"backgroundcolor\":\"white\"},{\"Relay\":\"\",\"displayText\":\"...\",\"backgroundcolor\":\"white\"}],[{\"slot\":\"12:30:00\",\"displayText\":\" 12:30:00\"},{\"Relay\":\"\",\"displayText\":\"...\",\"backgroundcolor\":\"white\"},{\"Relay\":\"\",\"displayText\":\"...\",\"backgroundcolor\":\"white\"},{\"Relay\":\"\",\"displayText\":\"...\",\"backgroundcolor\":\"white\"}],[{\"slot\":\"13:00:00\",\"displayText\":\" 13:00:00\"},{\"Relay\":\"\",\"displayText\":\"...\",\"backgroundcolor\":\"white\"},{\"Relay\":\"\",\"displayText\":\"...\",\"backgroundcolor\":\"white\"},{\"Relay\":\"\",\"displayText\":\"...\",\"backgroundcolor\":\"white\"}],[{\"slot\":\"13:30:00\",\"displayText\":\" 13:30:00\"},{\"Relay\":\"\",\"displayText\":\"...\",\"backgroundcolor\":\"white\"},{\"Relay\":\"\",\"displayText\":\"...\",\"backgroundcolor\":\"white\"},{\"Relay\":\"\",\"displayText\":\"...\",\"backgroundcolor\":\"white\"}],[{\"slot\":\"14:00:00\",\"displayText\":\" 14:00:00\"},{\"Relay\":\"\",\"displayText\":\"...\",\"backgroundcolor\":\"white\"},{\"Relay\":\"\",\"displayText\":\"...\",\"backgroundcolor\":\"white\"},{\"Relay\":\"\",\"displayText\":\"...\",\"backgroundcolor\":\"white\"}],[{\"slot\":\"14:30:00\",\"displayText\":\" 14:30:00\"},{\"Relay\":\"\",\"displayText\":\"...\",\"backgroundcolor\":\"white\"},{\"Relay\":\"\",\"displayText\":\"...\",\"backgroundcolor\":\"white\"},{\"Relay\":\"\",\"displayText\":\"...\",\"backgroundcolor\":\"white\"}],[{\"slot\":\"15:00:00\",\"displayText\":\" 15:00:00\"},{\"Relay\":\"\",\"displayText\":\"...\",\"backgroundcolor\":\"white\"},{\"Relay\":\"\",\"displayText\":\"...\",\"backgroundcolor\":\"white\"},{\"Relay\":\"\",\"displayText\":\"...\",\"backgroundcolor\":\"white\"}],[{\"slot\":\"15:30:00\",\"displayText\":\" 15:30:00\"},{\"Relay\":\"\",\"displayText\":\"...\",\"backgroundcolor\":\"white\"},{\"Relay\":\"\",\"displayText\":\"...\",\"backgroundcolor\":\"white\"},{\"Relay\":\"Relay4\",\"displayText\":\" Relay4\",\"backgroundcolor\":\"LightGray\"}],[{\"slot\":\"16:00:00\",\"displayText\":\" 16:00:00\"},{\"Relay\":\"\",\"displayText\":\"...\",\"backgroundcolor\":\"white\"},{\"Relay\":\"\",\"displayText\":\"...\",\"backgroundcolor\":\"white\"},{\"Relay\":\"Relay3\",\"displayText\":\" Relay3\",\"backgroundcolor\":\"LightGray\"}],[{\"slot\":\"16:30:00\",\"displayText\":\" 16:30:00\"},{\"Relay\":\"\",\"displayText\":\"...\",\"backgroundcolor\":\"white\"},{\"Relay\":\"\",\"displayText\":\"...\",\"backgroundcolor\":\"white\"},{\"Relay\":\"Relay3\",\"displayText\":\" Relay3\",\"backgroundcolor\":\"LightGray\"}],[{\"slot\":\"17:00:00\",\"displayText\":\" 17:00:00\"},{\"Relay\":\"\",\"displayText\":\"...\",\"backgroundcolor\":\"white\"},{\"Relay\":\"\",\"displayText\":\"...\",\"backgroundcolor\":\"white\"},{\"Relay\":\"\",\"displayText\":\"...\",\"backgroundcolor\":\"white\"}],[{\"slot\":\"17:30:00\",\"displayText\":\" 17:30:00\"},{\"Relay\":\"\",\"displayText\":\"...\",\"backgroundcolor\":\"white\"},{\"Relay\":\"\",\"displayText\":\"...\",\"backgroundcolor\":\"white\"},{\"Relay\":\"\",\"displayText\":\"...\",\"backgroundcolor\":\"white\"}],[{\"slot\":\"18:00:00\",\"displayText\":\" 18:00:00\"},{\"Relay\":\"\",\"displayText\":\"...\",\"backgroundcolor\":\"white\"},{\"Relay\":\"\",\"displayText\":\"...\",\"backgroundcolor\":\"white\"},{\"Relay\":\"\",\"displayText\":\"...\",\"backgroundcolor\":\"white\"}],[{\"slot\":\"18:30:00\",\"displayText\":\" 18:30:00\"},{\"Relay\":\"\",\"displayText\":\"...\",\"backgroundcolor\":\"white\"},{\"Relay\":\"\",\"displayText\":\"...\",\"backgroundcolor\":\"white\"},{\"Relay\":\"\",\"displayText\":\"...\",\"backgroundcolor\":\"white\"}],[{\"slot\":\"19:00:00\",\"displayText\":\" 19:00:00\"},{\"Relay\":\"\",\"displayText\":\"...\",\"backgroundcolor\":\"white\"},{\"Relay\":\"\",\"displayText\":\"...\",\"backgroundcolor\":\"white\"},{\"Relay\":\"\",\"displayText\":\"...\",\"backgroundcolor\":\"white\"}],[{\"slot\":\"19:30:00\",\"displayText\":\" 19:30:00\"},{\"Relay\":\"\",\"displayText\":\"...\",\"backgroundcolor\":\"white\"},{\"Relay\":\"\",\"displayText\":\"...\",\"backgroundcolor\":\"white\"},{\"Relay\":\"\",\"displayText\":\"...\",\"backgroundcolor\":\"white\"}]]",
                "vt": "json"
        "repeat": "",
        "crontab": "",
        "once": true,
        "onceDelay": 0.1,
        "topic": "",
        "x": 270,
        "y": 300,
                "628af32b557d2b10"
        "id": "628af32b557d2b10",
        "type": "ui_template",
        "group": "641b924c56253216",
        "order": 1,
        "width": 16,
        "height": 9,
        "format": "<style>\n    table, th, td {\n        border: 1px solid black;\n        border-collapse: collapse;\n    }\n    td {\n        text-align: center;\n        width: 300px;\n        \n    }\n}\n</style>\n\n<table class=\"table\" style=\"height:500px\">\n    <tr style=\"height:50px\">\n        <td></td>\n        <td ng-repeat=\"sched in msg.schedules\">\n            <p>{{msg.schedules[$index].Name}}</p>\n            <p>repeats every: {{msg.schedules[$index].repetition}} d</p>\n            <button\n                name=\"activate\" \n                ng-click=\"send({'schedule':{{msg.schedules[$index].ID}}, 'active': {{msg.schedules[$index].active}}, 'once': {{msg.schedules[$index].once}} })\"\n            >{{msg.schedules[$index].button}}</button>\n            <input \n                type=\"checkbox\"\n                id=\"once\"\n                name=\"activate\" \n                ng-checked=\"{{msg.schedules[$index].once}}\" \n                ng-model=\"check1\" \n                ng-change=\"send({'schedule':{{msg.schedules[$index].ID}}, 'active': {{msg.schedules[$index].active}}, 'once': {{msg.schedules[$index].once}} })\"\n            > once\n\n        </td>\n    </tr>\n\n    <tr style=\"height:30px\" ng-repeat=\"tableRow in msg.schedulesArray\">\n        <td ng-repeat=\"cell in tableRow\" style=\"background-color:{{msg.schedulesArray[$parent.$index][$index].backgroundcolor }}\">\n            {{ msg.schedulesArray[$parent.$index][$index].displayText }}\n        </td>\n    </tr>\n\n</table>\n",
        "storeOutMessages": true,
        "fwdInMessages": false,
        "resendOnRefresh": false,
        "templateScope": "local",
        "className": "",
        "x": 420,
        "y": 300,
                "f6189e4141467829"
        "id": "f6189e4141467829",
        "type": "debug",
        "active": true,
        "tosidebar": true,
        "console": false,
        "tostatus": false,
        "complete": "true",
        "targetType": "full",
        "statusVal": "",
        "statusType": "auto",
        "x": 570,
        "y": 300,
        "id": "641b924c56253216",
        "type": "ui_group",
        "name": "Default",
        "tab": "6e645f72d3aaf94d",
        "order": 1,
        "disp": true,
        "width": "21",
        "collapse": false,
        "className": ""
        "id": "6e645f72d3aaf94d",
        "type": "ui_tab",
        "name": "Home",
        "icon": "dashboard",
        "disabled": false,
        "hidden": false
Hello ..
I dont have any experience with AngularJS but after a bit of reading, i have some recommendation for your code
  1. for the ng-click to work with dynamic values .. you dont need the inner double curly brackets
    ng-click="send({'schedule':sched.ID, 'active': sched.active, 'once': sched.once })"
    the above seems to work
  2. is it necessary in your loop to use the $index from the msg.schedules ?
    you could simply use sched.ID, sched.once that makes the code shorter and easier to read
  3. there was a problem with the checkbox .. it would only send a msg when ckecked ?
    possibly because in your data the once property was 0 or 1 instead of true / false that could cause the issue with its ng-model (which in the ng-repeat loop should be dynamically set to
    ng-model="sched.once")
Flow changes :
[{"id":"dbbf35627f50c7fe","type":"inject","z":"ad7a80fa64d29e50","name":"","props":[{"p":"schedules","v":"[{\"ID\":1,\"Name\":\"morning\",\"lastRun\":null,\"repetition\":1,\"nextRun\":null,\"active\":0,\"once\":true,\"button\":\"once\"},{\"ID\":2,\"Name\":\"early\",\"lastRun\":null,\"repetition\":1,\"nextRun\":null,\"active\":0,\"once\":true,\"button\":\"once\"},{\"ID\":3,\"Name\":\"late\",\"lastRun\":null,\"repetition\":1,\"nextRun\":null,\"active\":0,\"once\":false,\"button\":\"off\"}]","vt":"json"},{"p":"schedulesArray","v":"[[{\"slot\":\"05:00:00\",\"displayText\":\" 05:00:00\"},{\"Relay\":\"Relay1\",\"displayText\":\" Relay1\",\"backgroundcolor\":\"LightSkyBlue\"},{\"Relay\":\"\",\"displayText\":\"...\",\"backgroundcolor\":\"white\"},{\"Relay\":\"\",\"displayText\":\"...\",\"backgroundcolor\":\"white\"}],[{\"slot\":\"05:30:00\",\"displayText\":\" 05:30:00\"},{\"Relay\":\"Relay2\",\"displayText\":\" Relay2\",\"backgroundcolor\":\"LightSkyBlue\"},{\"Relay\":\"\",\"displayText\":\"...\",\"backgroundcolor\":\"white\"},{\"Relay\":\"\",\"displayText\":\"...\",\"backgroundcolor\":\"white\"}],[{\"slot\":\"06:00:00\",\"displayText\":\" 06:00:00\"},{\"Relay\":\"Relay5\",\"displayText\":\" Relay5\",\"backgroundcolor\":\"LightSkyBlue\"},{\"Relay\":\"\",\"displayText\":\"...\",\"backgroundcolor\":\"white\"},{\"Relay\":\"\",\"displayText\":\"...\",\"backgroundcolor\":\"white\"}],[{\"slot\":\"06:30:00\",\"displayText\":\" 06:30:00\"},{\"Relay\":\"Relay6\",\"displayText\":\" Relay6\",\"backgroundcolor\":\"LightSkyBlue\"},{\"Relay\":\"\",\"displayText\":\"...\",\"backgroundcolor\":\"white\"},{\"Relay\":\"\",\"displayText\":\"...\",\"backgroundcolor\":\"white\"}],[{\"slot\":\"07:00:00\",\"displayText\":\" 07:00:00\"},{\"Relay\":\"Relay4\",\"displayText\":\" Relay4\",\"backgroundcolor\":\"LightSkyBlue\"},{\"Relay\":\"\",\"displayText\":\"...\",\"backgroundcolor\":\"white\"},{\"Relay\":\"\",\"displayText\":\"...\",\"backgroundcolor\":\"white\"}],[{\"slot\":\"07:30:00\",\"displayText\":\" 07:30:00\"},{\"Relay\":\"Relay3\",\"displayText\":\" Relay3\",\"backgroundcolor\":\"LightSkyBlue\"},{\"Relay\":\"\",\"displayText\":\"...\",\"backgroundcolor\":\"white\"},{\"Relay\":\"\",\"displayText\":\"...\",\"backgroundcolor\":\"white\"}],[{\"slot\":\"08:00:00\",\"displayText\":\" 08:00:00\"},{\"Relay\":\"Relay3\",\"displayText\":\" Relay3\",\"backgroundcolor\":\"LightSkyBlue\"},{\"Relay\":\"\",\"displayText\":\"...\",\"backgroundcolor\":\"white\"},{\"Relay\":\"\",\"displayText\":\"...\",\"backgroundcolor\":\"white\"}],[{\"slot\":\"08:30:00\",\"displayText\":\" 08:30:00\"},{\"Relay\":\"\",\"displayText\":\"...\",\"backgroundcolor\":\"white\"},{\"Relay\":\"Relay2\",\"displayText\":\" Relay2\",\"backgroundcolor\":\"LightSkyBlue\"},{\"Relay\":\"\",\"displayText\":\"...\",\"backgroundcolor\":\"white\"}],[{\"slot\":\"09:00:00\",\"displayText\":\" 09:00:00\"},{\"Relay\":\"\",\"displayText\":\"...\",\"backgroundcolor\":\"white\"},{\"Relay\":\"Relay4\",\"displayText\":\" Relay4\",\"backgroundcolor\":\"LightSkyBlue\"},{\"Relay\":\"\",\"displayText\":\"...\",\"backgroundcolor\":\"white\"}],[{\"slot\":\"09:30:00\",\"displayText\":\" 09:30:00\"},{\"Relay\":\"\",\"displayText\":\"...\",\"backgroundcolor\":\"white\"},{\"Relay\":\"Relay1\",\"displayText\":\" Relay1\",\"backgroundcolor\":\"LightSkyBlue\"},{\"Relay\":\"\",\"displayText\":\"...\",\"backgroundcolor\":\"white\"}],[{\"slot\":\"10:00:00\",\"displayText\":\" 10:00:00\"},{\"Relay\":\"\",\"displayText\":\"...\",\"backgroundcolor\":\"white\"},{\"Relay\":\"Relay5\",\"displayText\":\" Relay5\",\"backgroundcolor\":\"LightSkyBlue\"},{\"Relay\":\"\",\"displayText\":\"...\",\"backgroundcolor\":\"white\"}],[{\"slot\":\"10:30:00\",\"displayText\":\" 10:30:00\"},{\"Relay\":\"\",\"displayText\":\"...\",\"backgroundcolor\":\"white\"},{\"Relay\":\"Relay6\",\"displayText\":\" Relay6\",\"backgroundcolor\":\"LightSkyBlue\"},{\"Relay\":\"\",\"displayText\":\"...\",\"backgroundcolor\":\"white\"}],[{\"slot\":\"11:00:00\",\"displayText\":\" 11:00:00\"},{\"Relay\":\"\",\"displayText\":\"...\",\"backgroundcolor\":\"white\"},{\"Relay\":\"Relay3\",\"displayText\":\" Relay3\",\"backgroundcolor\":\"LightSkyBlue\"},{\"Relay\":\"\",\"displayText\":\"...\",\"backgroundcolor\":\"white\"}],[{\"slot\":\"11:30:00\",\"displayText\":\" 11:30:00\"},{\"Relay\":\"\",\"displayText\":\"...\",\"backgroundcolor\":\"white\"},{\"Relay\":\"Relay3\",\"displayText\":\" Relay3\",\"backgroundcolor\":\"LightSkyBlue\"},{\"Relay\":\"\",\"displayText\":\"...\",\"backgroundcolor\":\"white\"}],[{\"slot\":\"12:00:00\",\"displayText\":\" 12:00:00\"},{\"Relay\":\"\",\"displayText\":\"...\",\"backgroundcolor\":\"white\"},{\"Relay\":\"\",\"displayText\":\"...\",\"backgroundcolor\":\"white\"},{\"Relay\":\"\",\"displayText\":\"...\",\"backgroundcolor\":\"white\"}],[{\"slot\":\"12:30:00\",\"displayText\":\" 12:30:00\"},{\"Relay\":\"\",\"displayText\":\"...\",\"backgroundcolor\":\"white\"},{\"Relay\":\"\",\"displayText\":\"...\",\"backgroundcolor\":\"white\"},{\"Relay\":\"\",\"displayText\":\"...\",\"backgroundcolor\":\"white\"}],[{\"slot\":\"13:00:00\",\"displayText\":\" 13:00:00\"},{\"Relay\":\"\",\"displayText\":\"...\",\"backgroundcolor\":\"white\"},{\"Relay\":\"\",\"displayText\":\"...\",\"backgroundcolor\":\"white\"},{\"Relay\":\"\",\"displayText\":\"...\",\"backgroundcolor\":\"white\"}],[{\"slot\":\"13:30:00\",\"displayText\":\" 13:30:00\"},{\"Relay\":\"\",\"displayText\":\"...\",\"backgroundcolor\":\"white\"},{\"Relay\":\"\",\"displayText\":\"...\",\"backgroundcolor\":\"white\"},{\"Relay\":\"\",\"displayText\":\"...\",\"backgroundcolor\":\"white\"}],[{\"slot\":\"14:00:00\",\"displayText\":\" 14:00:00\"},{\"Relay\":\"\",\"displayText\":\"...\",\"backgroundcolor\":\"white\"},{\"Relay\":\"\",\"displayText\":\"...\",\"backgroundcolor\":\"white\"},{\"Relay\":\"\",\"displayText\":\"...\",\"backgroundcolor\":\"white\"}],[{\"slot\":\"14:30:00\",\"displayText\":\" 14:30:00\"},{\"Relay\":\"\",\"displayText\":\"...\",\"backgroundcolor\":\"white\"},{\"Relay\":\"\",\"displayText\":\"...\",\"backgroundcolor\":\"white\"},{\"Relay\":\"\",\"displayText\":\"...\",\"backgroundcolor\":\"white\"}],[{\"slot\":\"15:00:00\",\"displayText\":\" 15:00:00\"},{\"Relay\":\"\",\"displayText\":\"...\",\"backgroundcolor\":\"white\"},{\"Relay\":\"\",\"displayText\":\"...\",\"backgroundcolor\":\"white\"},{\"Relay\":\"\",\"displayText\":\"...\",\"backgroundcolor\":\"white\"}],[{\"slot\":\"15:30:00\",\"displayText\":\" 15:30:00\"},{\"Relay\":\"\",\"displayText\":\"...\",\"backgroundcolor\":\"white\"},{\"Relay\":\"\",\"displayText\":\"...\",\"backgroundcolor\":\"white\"},{\"Relay\":\"Relay4\",\"displayText\":\" Relay4\",\"backgroundcolor\":\"LightGray\"}],[{\"slot\":\"16:00:00\",\"displayText\":\" 16:00:00\"},{\"Relay\":\"\",\"displayText\":\"...\",\"backgroundcolor\":\"white\"},{\"Relay\":\"\",\"displayText\":\"...\",\"backgroundcolor\":\"white\"},{\"Relay\":\"Relay3\",\"displayText\":\" Relay3\",\"backgroundcolor\":\"LightGray\"}],[{\"slot\":\"16:30:00\",\"displayText\":\" 16:30:00\"},{\"Relay\":\"\",\"displayText\":\"...\",\"backgroundcolor\":\"white\"},{\"Relay\":\"\",\"displayText\":\"...\",\"backgroundcolor\":\"white\"},{\"Relay\":\"Relay3\",\"displayText\":\" Relay3\",\"backgroundcolor\":\"LightGray\"}],[{\"slot\":\"17:00:00\",\"displayText\":\" 17:00:00\"},{\"Relay\":\"\",\"displayText\":\"...\",\"backgroundcolor\":\"white\"},{\"Relay\":\"\",\"displayText\":\"...\",\"backgroundcolor\":\"white\"},{\"Relay\":\"\",\"displayText\":\"...\",\"backgroundcolor\":\"white\"}],[{\"slot\":\"17:30:00\",\"displayText\":\" 17:30:00\"},{\"Relay\":\"\",\"displayText\":\"...\",\"backgroundcolor\":\"white\"},{\"Relay\":\"\",\"displayText\":\"...\",\"backgroundcolor\":\"white\"},{\"Relay\":\"\",\"displayText\":\"...\",\"backgroundcolor\":\"white\"}],[{\"slot\":\"18:00:00\",\"displayText\":\" 18:00:00\"},{\"Relay\":\"\",\"displayText\":\"...\",\"backgroundcolor\":\"white\"},{\"Relay\":\"\",\"displayText\":\"...\",\"backgroundcolor\":\"white\"},{\"Relay\":\"\",\"displayText\":\"...\",\"backgroundcolor\":\"white\"}],[{\"slot\":\"18:30:00\",\"displayText\":\" 18:30:00\"},{\"Relay\":\"\",\"displayText\":\"...\",\"backgroundcolor\":\"white\"},{\"Relay\":\"\",\"displayText\":\"...\",\"backgroundcolor\":\"white\"},{\"Relay\":\"\",\"displayText\":\"...\",\"backgroundcolor\":\"white\"}],[{\"slot\":\"19:00:00\",\"displayText\":\" 19:00:00\"},{\"Relay\":\"\",\"displayText\":\"...\",\"backgroundcolor\":\"white\"},{\"Relay\":\"\",\"displayText\":\"...\",\"backgroundcolor\":\"white\"},{\"Relay\":\"\",\"displayText\":\"...\",\"backgroundcolor\":\"white\"}],[{\"slot\":\"19:30:00\",\"displayText\":\" 19:30:00\"},{\"Relay\":\"\",\"displayText\":\"...\",\"backgroundcolor\":\"white\"},{\"Relay\":\"\",\"displayText\":\"...\",\"backgroundcolor\":\"white\"},{\"Relay\":\"\",\"displayText\":\"...\",\"backgroundcolor\":\"white\"}]]","vt":"json"}],"repeat":"","crontab":"","once":true,"onceDelay":0.1,"topic":"","x":270,"y":300,"wires":[["628af32b557d2b10","fbe658d7e46272c5"]]},{"id":"628af32b557d2b10","type":"ui_template","z":"ad7a80fa64d29e50","group":"641b924c56253216","name":"","order":1,"width":16,"height":9,"format":"<style>\n    table,\n    th,\n    td {\n        border: 1px solid black;\n        border-collapse: collapse;\n    }\n\n    td {\n        text-align: center;\n        width: 300px;\n\n    }\n    }\n</style>\n\n<table class=\"table\" style=\"height:500px\">\n    <tr style=\"height:50px\">\n        <td></td>\n        <td ng-repeat=\"sched in msg.schedules\">\n            <p>{{sched.Name}}</p>\n            <p>repeats every: {{sched.repetition}} d</p>\n            <button\n                name=\"activate\"\n                ng-click=\"send({'schedule':sched.ID, 'active': sched.active, 'once': sched.once })\"\n            >{{sched.button}}</button>\n            <input\n                type=\"checkbox\"\n                id=\"once\"\n                name=\"activate\"\n                ng-model=\"sched.once\"\n                ng-change=\" logme(sched.once); send({'schedule':sched.ID, 'active': sched.active, 'once': sched.once })\"\n            > once\n\n        </td>\n    </tr>\n\n    <tr style=\"height:30px\" ng-repeat=\"tableRow in msg.schedulesArray\">\n        <td ng-repeat=\"cell in tableRow\"\n            style=\"background-color:{{msg.schedulesArray[$parent.$index][$index].backgroundcolor }}\">\n            {{ msg.schedulesArray[$parent.$index][$index].displayText }}\n        </td>\n    </tr>\n\n</table>\n\n<script>\n    var theScope = scope\n    theScope.logme = function (value) {\n          console.log(value);\n  }\n</script>","storeOutMessages":false,"fwdInMessages":false,"resendOnRefresh":false,"templateScope":"local","className":"","x":460,"y":300,"wires":[["f6189e4141467829"]]},{"id":"f6189e4141467829","type":"debug","z":"ad7a80fa64d29e50","name":"","active":true,"tosidebar":true,"console":false,"tostatus":false,"complete":"true","targetType":"full","statusVal":"","statusType":"auto","x":650,"y":300,"wires":[]},{"id":"fbe658d7e46272c5","type":"debug","z":"ad7a80fa64d29e50","name":"debug 3","active":true,"tosidebar":true,"console":false,"tostatus":false,"complete":"true","targetType":"full","statusVal":"","statusType":"auto","x":380,"y":220,"wires":[]},{"id":"641b924c56253216","type":"ui_group","name":"Default","tab":"6e645f72d3aaf94d","order":1,"disp":true,"width":"21","collapse":false,"className":""},{"id":"6e645f72d3aaf94d","type":"ui_tab","name":"Home","icon":"dashboard","disabled":false,"hidden":false}]
thanks a lot, so no curly braces.
Your second point was actually related I guess. I could not find a reference how to use specific keys of arrayed objects from within ng-repeat. My code using the sched variable directly did not work for some reason, probably because of curly braces as well.
Take care!
