Setting a value to 0
I want to disable one of my inverters.
If I do, the values freeze.
I want to set them to "0".
But I don´t get a "0", always error or "undefined".
I just want to override with a "0" after disabling the inverter / last value freeze:
Can you please tell me how?
thanks
Hi!
There is a "change" node. You can use it to "set" a certain value of the msg "to" the desired value (number 0).
In german the translations for the settings are: "Festlegen" msg.property "bis" 0.
doesn´t work:
grafik
grafik
doesn´t work:
grafik
That error - PAC W: msg.payload: undefined - shows you (most likely ) have a error in the function node, but with out the flow, no one is going to be able to help you.
yes, the function node expects an object (msg.playload.PAC3)
[{"id":"b830b5d.d4fae48","type":"inject","z":"9f6752b0.b55988","name":"5s Abfrage","props":[{"p":"payload","v":"","vt":"date"},{"p":"topic","v":"","vt":"string"}],"repeat":"5","crontab":"","once":false,"onceDelay":0.1,"topic":"","payload":"","payloadType":"date","x":130,"y":1940,"wires":[[]]},{"id":"f7fa90ea.97222","type":"modbus-getter","z":"9f6752b0.b55988","name":"30843 - 30852","showStatusActivities":false,"showErrors":false,"logIOActivities":false,"unitid":"3","dataType":"InputRegister","adr":"30843","quantity":"10","server":"b6c6500c.41cc1","useIOFile":false,"ioFile":"","useIOForPayload":false,"emptyMsgOnFail":false,"keepMsgProperties":false,"x":340,"y":2180,"wires":[["91420ee9.859318"],[]]},{"id":"91420ee9.859318","type":"buffer-parser","z":"9f6752b0.b55988","name":"","data":"responseBuffer.buffer","dataType":"msg","specification":"spec","specificationType":"ui","items":[{"type":"int32be","name":"BattA","offset":0,"length":1,"offsetbit":0,"scale":"0.001","mask":""},{"type":"uint32be","name":"SoC","offset":4,"length":1,"offsetbit":0,"scale":"1","mask":""},{"type":"uint32be","name":"SoH","offset":8,"length":1,"offsetbit":0,"scale":"1","mask":""},{"type":"int32be","name":"BattT","offset":12,"length":1,"offsetbit":0,"scale":"0.1","mask":""},{"type":"uint32be","name":"BattV","offset":16,"length":1,"offsetbit":0,"scale":"0.01","mask":""}],"swap1":"","swap2":"","swap3":"","swap1Type":"swap","swap2Type":"swap","swap3Type":"swap","msgProperty":"payload","msgPropertyType":"str","resultType":"keyvalue","resultTypeType":"output","multipleResult":false,"fanOutMultipleResult":false,"setTopic":true,"outputs":1,"x":570,"y":2180,"wires":[["7682660.f4b309c","8e2027ab.ae8f58","378a23d5.78f014","5f97fb66.f015d4","7c456d28.c529c4","1037ac89.fa3043"]]},{"id":"4466b501.e31264","type":"ui_text","z":"9f6752b0.b55988","group":"84d14f5d.16a5f","order":4,"width":0,"height":0,"name":"Spannung DC","label":"Spannung DC","format":"{{msg.payload}} V","layout":"row-spread","x":1100,"y":2220,"wires":[]},{"id":"e7b1e414.14768","type":"ui_text","z":"9f6752b0.b55988","group":"84d14f5d.16a5f","order":6,"width":0,"height":0,"name":"Strom DC","label":"Strom DC","format":"{{msg.payload}} A","layout":"row-spread","x":1080,"y":2260,"wires":[]},{"id":"2327fd9c.cee492","type":"ui_text","z":"9f6752b0.b55988","group":"84d14f5d.16a5f","order":8,"width":0,"height":0,"name":"SoH","label":"Kapazität (SoH)","format":"{{msg.payload}} %","layout":"row-spread","x":1070,"y":2340,"wires":[]},{"id":"33af4d9e.445912","type":"ui_text","z":"9f6752b0.b55988","group":"84d14f5d.16a5f","order":7,"width":0,"height":0,"name":"Temperatur","label":"Temperatur","format":"{{msg.payload}} °C","layout":"row-spread","x":1090,"y":2300,"wires":[]},{"id":"cd1d4476.573438","type":"modbus-getter","z":"9f6752b0.b55988","name":"30775 - 30776","showStatusActivities":false,"showErrors":false,"logIOActivities":false,"unitid":"3","dataType":"InputRegister","adr":"30775","quantity":"2","server":"b6c6500c.41cc1","useIOFile":false,"ioFile":"","useIOForPayload":false,"emptyMsgOnFail":false,"keepMsgProperties":false,"x":340,"y":1940,"wires":[["6bf32864.15db08"],[]]},{"id":"6bf32864.15db08","type":"buffer-parser","z":"9f6752b0.b55988","name":"","data":"responseBuffer.buffer","dataType":"msg","specification":"spec","specificationType":"ui","items":[{"type":"int32be","name":"PAC3","offset":0,"length":1,"offsetbit":0,"scale":"1","mask":""}],"swap1":"","swap2":"","swap3":"","swap1Type":"swap","swap2Type":"swap","swap3Type":"swap","msgProperty":"payload","msgPropertyType":"str","resultType":"keyvalue","resultTypeType":"output","multipleResult":false,"fanOutMultipleResult":false,"setTopic":true,"outputs":1,"x":570,"y":1940,"wires":[["6b2d0577.ec1aec","52afd055.a836a8"]]},{"id":"61997a16.71aefc","type":"ui_text","z":"9f6752b0.b55988","group":"d5972738.a29c7","order":1,"width":0,"height":0,"name":"Leistung AC","label":"Leistung AC","format":"{{msg.payload}} W","layout":"row-spread","x":1090,"y":1940,"wires":[]},{"id":"7682660.f4b309c","type":"function","z":"9f6752b0.b55988","name":"SoC","func":"msg.payload = msg.payload.SoC\nmsg.topic = \"SoC\"\nreturn msg;","outputs":1,"noerr":0,"x":830,"y":2180,"wires":[["697f7a7a.e09f84","153fd585.a238c2","8cbd479.7d5ad38"]]},{"id":"8e2027ab.ae8f58","type":"function","z":"9f6752b0.b55988","name":"Batt V","func":"msg.payload = msg.payload.BattV\nmsg.topic = \"BattV\"\nreturn msg;","outputs":1,"noerr":0,"x":830,"y":2220,"wires":[["82be5179.492158","78265803.e50b1","c483bbde.882288"]]},{"id":"378a23d5.78f014","type":"function","z":"9f6752b0.b55988","name":"Batt A","func":"msg.payload = msg.payload.BattA\nmsg.topic = \"BattA\"\nreturn msg;","outputs":1,"noerr":0,"x":830,"y":2260,"wires":[["82be5179.492158","fad88ce5.8e56f8"]]},{"id":"5f97fb66.f015d4","type":"function","z":"9f6752b0.b55988","name":"Batt T","func":"msg.payload = msg.payload.BattT\nmsg.topic = \"BattT\"\nreturn msg;","outputs":1,"noerr":0,"x":830,"y":2300,"wires":[["33af4d9e.445912"]]},{"id":"7c456d28.c529c4","type":"function","z":"9f6752b0.b55988","name":"SoH","func":"msg.payload = msg.payload.SoH\nmsg.topic = \"SoH\"\nreturn msg;","outputs":1,"noerr":0,"x":830,"y":2340,"wires":[["2327fd9c.cee492"]]},{"id":"52afd055.a836a8","type":"function","z":"9f6752b0.b55988","name":"PAC3","func":"msg.payload = msg.payload.PAC3\nmsg.topic = \"PAC3\"\nreturn msg;","outputs":1,"noerr":0,"x":830,"y":1940,"wires":[["61997a16.71aefc","3ac6a532.5e5e5a","a8d64f72.66cf18","2e0cdfdb.db198","8ec4b63c.80096","bd2ba699.41f608","8f02441b.868088"]]},{"id":"82be5179.492158","type":"join","z":"9f6752b0.b55988","name":"","mode":"custom","build":"object","property":"payload","propertyType":"msg","key":"topic","joiner":"\\n","joinerType":"str","accumulate":false,"timeout":"","count":"2","reduceRight":false,"reduceExp":"","reduceInit":"","reduceInitType":"","reduceFixup":"","x":1350,"y":2240,"wires":[["659b702.13c0e9"]]},{"id":"659b702.13c0e9","type":"function","z":"9f6752b0.b55988","name":"Leistung DC","func":"var temp = (msg.payload[\"BattV\"] * msg.payload[\"BattA\"]);\nmsg.payload = parseFloat(temp.toFixed(0));\nmsg.topic = \"BattP\";\nreturn msg;","outputs":1,"noerr":0,"x":1510,"y":2240,"wires":[["c025aad1.65d008","3ac6a532.5e5e5a"]]},{"id":"c025aad1.65d008","type":"ui_text","z":"9f6752b0.b55988","group":"84d14f5d.16a5f","order":3,"width":0,"height":0,"name":"Leistung DC","label":"Leistung DC","format":"{{msg.payload}} W","layout":"row-spread","x":1730,"y":2240,"wires":[]},{"id":"3ac6a532.5e5e5a","type":"join","z":"9f6752b0.b55988","name":"","mode":"custom","build":"object","property":"payload","propertyType":"msg","key":"topic","joiner":"\\n","joinerType":"str","accumulate":false,"timeout":"","count":"2","reduceRight":false,"reduceExp":"","reduceInit":"","reduceInitType":"num","reduceFixup":"","x":1350,"y":2300,"wires":[["e8c48f28.225e5","ae93c9d0.f6827"]]},{"id":"14fe7f8b.54a538","type":"ui_text","z":"9f6752b0.b55988","group":"d5972738.a29c7","order":2,"width":0,"height":0,"name":"Wirkungsgrad","label":"Wirkungsgrad","format":"{{msg.payload}} %","layout":"row-spread","x":1740,"y":2300,"wires":[]},{"id":"1037ac89.fa3043","type":"modbus-getter","z":"9f6752b0.b55988","name":"30953 - 30954","showStatusActivities":false,"showErrors":false,"logIOActivities":false,"unitid":"3","dataType":"InputRegister","adr":"30953","quantity":"2","server":"b6c6500c.41cc1","useIOFile":false,"ioFile":"","useIOForPayload":false,"emptyMsgOnFail":false,"keepMsgProperties":false,"x":340,"y":2380,"wires":[["34071bdf.c3e8fc"],[]]},{"id":"34071bdf.c3e8fc","type":"buffer-parser","z":"9f6752b0.b55988","name":"","data":"responseBuffer.buffer","dataType":"msg","specification":"spec","specificationType":"ui","items":[{"type":"int32be","name":"T3","offset":0,"length":1,"offsetbit":0,"scale":0.1,"mask":""}],"swap1":"","swap2":"","swap3":"","swap1Type":"swap","swap2Type":"swap","swap3Type":"swap","msgProperty":"payload","msgPropertyType":"str","resultType":"keyvalue","resultTypeType":"output","multipleResult":false,"setTopic":true,"outputs":1,"x":570,"y":2380,"wires":[["5d9b0fac.586c6","52ff0616.a183d"]]},{"id":"5d9b0fac.586c6","type":"function","z":"9f6752b0.b55988","name":"T3","func":"msg.payload = msg.payload.T3\nmsg.payload = msg.payload.toFixed(1).replace('.', ',');\nmsg.topic = \"T3\"\nreturn msg;","outputs":1,"noerr":0,"x":830,"y":2380,"wires":[["38ed2268.18fcee"]]},{"id":"38ed2268.18fcee","type":"ui_text","z":"9f6752b0.b55988","group":"d5972738.a29c7","order":3,"width":0,"height":0,"name":"T3","label":"Temperatur","format":"{{msg.payload}} °C","layout":"row-spread","x":1070,"y":2380,"wires":[]},{"id":"78265803.e50b1","type":"function","z":"9f6752b0.b55988","name":". zu ,","func":"msg.payload = msg.payload.toFixed(1).replace('.', ',');\nreturn msg;","outputs":1,"noerr":0,"x":950,"y":2220,"wires":[["4466b501.e31264"]]},{"id":"fad88ce5.8e56f8","type":"function","z":"9f6752b0.b55988","name":". zu ,","func":"msg.payload = msg.payload.toFixed(2).replace('.', ',');\nreturn msg;","outputs":1,"noerr":0,"x":950,"y":2260,"wires":[["e7b1e414.14768"]]},{"id":"697f7a7a.e09f84","type":"ui_gauge","z":"9f6752b0.b55988","name":"SoC","group":"84d14f5d.16a5f","order":1,"width":0,"height":0,"gtype":"gage","title":"Ladezustand (SoC)","label":"","format":"{{value}} %","min":0,"max":"100","colors":["#b30206","#f9f900","#00f400"],"seg1":"","seg2":"","x":1070,"y":2180,"wires":[]},{"id":"e8c48f28.225e5","type":"function","z":"9f6752b0.b55988","name":"Wirkungsgrad AC/DC","func":"var BattP = msg.payload[\"BattP\"];\nvar PAC3 = msg.payload[\"PAC3\"];\nvar temp; \n\nif(BattP > 0 || PAC3 > 0) {\n    temp = ((PAC3 / BattP) * 100);\n} else {\n    temp = ((BattP / PAC3) * 100);\n}\n\nmsg.payload = parseFloat(temp.toFixed(0)); \nmsg.topic = \"W3\";\nreturn msg;","outputs":1,"noerr":0,"x":1540,"y":2300,"wires":[["14fe7f8b.54a538"]]},{"id":"c483bbde.882288","type":"function","z":"9f6752b0.b55988","name":"Zellspannung","func":"msg.payload = (msg.payload / 96);\nmsg.payload = msg.payload.toFixed(2).replace('.', ',');\nmsg.topic = \"BattZV\";\nreturn msg;","outputs":1,"noerr":0,"x":860,"y":2100,"wires":[["bfd63582.583698"]]},{"id":"bfd63582.583698","type":"ui_text","z":"9f6752b0.b55988","group":"84d14f5d.16a5f","order":5,"width":0,"height":0,"name":"Zellspannung","label":"Zellspannung","format":"{{msg.payload}} V","layout":"row-spread","x":1100,"y":2100,"wires":[]},{"id":"c09cba7.3747cc8","type":"comment","z":"9f6752b0.b55988","name":"SBS 2.5","info":"","x":120,"y":1900,"wires":[]},{"id":"8ec4b63c.80096","type":"ui_text","z":"9f6752b0.b55988","group":"a5b1ca83.42d688","order":5,"width":0,"height":0,"name":"Speicher entäd","label":"Speicher Entladung","format":"{{msg.payload}} W","layout":"row-spread","x":1100,"y":1980,"wires":[]},{"id":"c43eceea.21577","type":"comment","z":"9f6752b0.b55988","name":"Erklärung","info":"96 Zellen bei 3 Türmen\npro Turm 32","x":840,"y":2060,"wires":[]},{"id":"153fd585.a238c2","type":"function","z":"9f6752b0.b55988","name":"Kapazität","func":"msg.payload = (msg.payload / 100 * 7.68);\nmsg.payload = msg.payload.toFixed(2).replace('.', ',');\nreturn msg;","outputs":1,"noerr":0,"x":840,"y":2140,"wires":[["dfd0ba43.44426"]]},{"id":"dfd0ba43.44426","type":"ui_text","z":"9f6752b0.b55988","group":"84d14f5d.16a5f","order":2,"width":0,"height":0,"name":"aktuelle Kapazität","label":"aktuelle Kapazität","format":"{{msg.payload}} kWh","layout":"row-spread","x":1110,"y":2140,"wires":[]},{"id":"8cbd479.7d5ad38","type":"calculate","z":"9f6752b0.b55988","name":"Durchschnitt","pauseType":"timed","calculation":"average","timeout":"5","timeoutUnits":"minutes","rate":"10","x":1370,"y":2180,"wires":[["88ff1e3.62a4f6"]]},{"id":"88ff1e3.62a4f6","type":"function","z":"9f6752b0.b55988","name":"runden","func":"msg.payload = msg.payload.toFixed(0);\nreturn msg;","outputs":1,"noerr":0,"x":1540,"y":2180,"wires":[["d525807a.db6408"]]},{"id":"d525807a.db6408","type":"ui_chart","z":"9f6752b0.b55988","name":"Verlauf SoC","group":"5e2cd394.9ef8dc","order":1,"width":0,"height":0,"label":"Verlauf SoC 48h","chartType":"line","legend":"true","xformat":"HH:mm","interpolate":"linear","nodata":"","dot":false,"ymin":"0","ymax":"100","removeOlder":"48","removeOlderPoints":"","removeOlderUnit":"3600","cutout":0,"useOneColor":false,"useUTC":false,"colors":["#000000","#f90006","#ff7f0e","#2ca02c","#98df8a","#d62728","#ff9896","#9467bd","#c5b0d5"],"outputs":1,"x":1730,"y":2180,"wires":[[]]},{"id":"bd2ba699.41f608","type":"calculate","z":"9f6752b0.b55988","name":"Durchschnitt","pauseType":"timed","calculation":"average","timeout":"1","timeoutUnits":"minutes","rate":"10","x":1370,"y":1940,"wires":[["266401db.3175b6"]]},{"id":"266401db.3175b6","type":"function","z":"9f6752b0.b55988","name":"runden","func":"msg.payload = msg.payload.toFixed(0);\nreturn msg;","outputs":1,"noerr":0,"x":1520,"y":1940,"wires":[["b3a2b1c3.132e1"]]},{"id":"b3a2b1c3.132e1","type":"ui_chart","z":"9f6752b0.b55988","name":"Verlauf Leistung AC ","group":"5e2cd394.9ef8dc","order":1,"width":0,"height":0,"label":"Verlauf Leistung AC 24h","chartType":"line","legend":"true","xformat":"HH:mm","interpolate":"linear","nodata":"","dot":false,"ymin":"-2600","ymax":"2600","removeOlder":"24","removeOlderPoints":"","removeOlderUnit":"3600","cutout":0,"useOneColor":false,"useUTC":false,"colors":["#ff0000","#f90006","#ff7f0e","#2ca02c","#98df8a","#d62728","#ff9896","#9467bd","#c5b0d5"],"outputs":1,"x":1720,"y":1940,"wires":[[]]},{"id":"ae93c9d0.f6827","type":"function","z":"9f6752b0.b55988","name":"Verlustleistung SBS","func":"var temp = (msg.payload[\"BattP\"] - msg.payload[\"PAC3\"]);\nmsg.payload = parseFloat(temp.toFixed(0));\nmsg.topic = \"Verlust\";\nreturn msg;","outputs":1,"noerr":0,"x":1530,"y":2340,"wires":[["bd8defbb.2ab48"]]},{"id":"bd8defbb.2ab48","type":"ui_text","z":"9f6752b0.b55988","group":"d5972738.a29c7","order":4,"width":0,"height":0,"name":"Verlustleistung","label":"<font color=red> Verlustleistung","format":"{{msg.payload}} W","layout":"row-spread","x":1740,"y":2340,"wires":[]},{"id":"6b2d0577.ec1aec","type":"modbus-getter","z":"9f6752b0.b55988","name":"30783 - 30784","showStatusActivities":false,"showErrors":false,"logIOActivities":false,"unitid":"3","dataType":"InputRegister","adr":"30783","quantity":"2","server":"b6c6500c.41cc1","useIOFile":false,"ioFile":"","useIOForPayload":false,"emptyMsgOnFail":false,"keepMsgProperties":false,"x":340,"y":2020,"wires":[["b4044a43.9cad98"],[]]},{"id":"b4044a43.9cad98","type":"buffer-parser","z":"9f6752b0.b55988","name":"","data":"responseBuffer.buffer","dataType":"msg","specification":"spec","specificationType":"ui","items":[{"type":"uint32be","name":"UL1S","offset":0,"length":1,"offsetbit":0,"scale":"0.01","mask":""}],"swap1":"","swap2":"","swap3":"","swap1Type":"swap","swap2Type":"swap","swap3Type":"swap","msgProperty":"payload","msgPropertyType":"str","resultType":"keyvalue","resultTypeType":"output","multipleResult":false,"fanOutMultipleResult":false,"setTopic":true,"outputs":1,"x":570,"y":2020,"wires":[["f7fa90ea.97222","d38adc36.53522"]]},{"id":"d38adc36.53522","type":"function","z":"9f6752b0.b55988","name":"UL1S","func":"msg.payload = msg.payload.UL1S;\nmsg.topic = \"UL1S\";\nreturn msg;","outputs":1,"noerr":0,"x":830,"y":2020,"wires":[["39c79754.e8161","c4e85299.6fec7"]]},{"id":"a8b8bc7e.c199b","type":"function","z":"9f6752b0.b55988","name":". zu ,","func":"msg.payload = msg.payload.toFixed(2).replace('.', ',');\nreturn msg;","outputs":1,"noerr":0,"initialize":"","finalize":"","x":1650,"y":2080,"wires":[["5dcda8f1.6689b8"]]},{"id":"5dcda8f1.6689b8","type":"ui_text","z":"9f6752b0.b55988","group":"d5972738.a29c7","order":8,"width":0,"height":0,"name":"Udiff","label":"Spannungsfall","format":"{{msg.payload}} V","layout":"row-spread","x":1770,"y":2080,"wires":[]},{"id":"39c79754.e8161","type":"join","z":"9f6752b0.b55988","name":"","mode":"custom","build":"object","property":"payload","propertyType":"msg","key":"topic","joiner":"\\n","joinerType":"str","accumulate":false,"timeout":"","count":"2","reduceRight":false,"reduceExp":"","reduceInit":"","reduceInitType":"","reduceFixup":"","x":1350,"y":2080,"wires":[["5f4fd5f7.ea9dac"]]},{"id":"5f4fd5f7.ea9dac","type":"function","z":"9f6752b0.b55988","name":"Spannungsfall","func":"var temp = (msg.payload[\"UL1\"] - msg.payload[\"UL1S\"]);\nmsg.payload = parseFloat(temp.toFixed(2));\nmsg.topic = \"Udiff\";\nreturn msg;","outputs":1,"noerr":0,"x":1500,"y":2080,"wires":[["6695db3e.633cc4","a8b8bc7e.c199b"]]},{"id":"6695db3e.633cc4","type":"join","z":"9f6752b0.b55988","name":"","mode":"custom","build":"object","property":"payload","propertyType":"msg","key":"topic","joiner":"\\n","joinerType":"str","accumulate":false,"timeout":"","count":"2","reduceRight":false,"reduceExp":"","reduceInit":"","reduceInitType":"","reduceFixup":"","x":1350,"y":2400,"wires":[["9be43913.5c756"]]},{"id":"9be43913.5c756","type":"function","z":"9f6752b0.b55988","name":"Verlustleistung Leitung","func":"var temp = (msg.payload[\"I3\"] * msg.payload[\"Udiff\"]);\nmsg.payload = parseFloat(temp.toFixed(0));\nmsg.topic = \"Verlust2\";\nreturn msg;","outputs":1,"noerr":0,"x":1540,"y":2400,"wires":[["26980f09.5b0be"]]},{"id":"26980f09.5b0be","type":"ui_text","z":"9f6752b0.b55988","group":"d5972738.a29c7","order":9,"width":0,"height":0,"name":"Leitungsverlust","label":"<font color=red> Leitungsverlust","format":"{{msg.payload}} W","layout":"row-spread","x":1740,"y":2400,"wires":[]},{"id":"fb3a068f.aae408","type":"ui_text","z":"9f6752b0.b55988","group":"d5972738.a29c7","order":6,"width":0,"height":0,"name":"Spannung AC","label":"Spannung AC","format":"{{msg.payload}} V","layout":"row-spread","x":1100,"y":2020,"wires":[]},{"id":"c4e85299.6fec7","type":"function","z":"9f6752b0.b55988","name":". zu ,","func":"msg.payload = msg.payload.toFixed(2).replace('.', ',');\nreturn msg;","outputs":1,"noerr":0,"x":950,"y":2020,"wires":[["fb3a068f.aae408"]]},{"id":"ef4dc25b.b0a","type":"change","z":"9f6752b0.b55988","name":"","rules":[{"t":"set","p":"payload.PAC3","pt":"msg","to":"1","tot":"num"}],"action":"","property":"","from":"","to":"","reg":false,"x":650,"y":1860,"wires":[["52afd055.a836a8"]]},{"id":"8f02441b.868088","type":"debug","z":"9f6752b0.b55988","name":"","active":true,"tosidebar":true,"console":false,"tostatus":false,"complete":"false","statusVal":"","statusType":"auto","x":1100,"y":1860,"wires":[]},{"id":"8b27ee4c.b59d58","type":"inject","z":"9f6752b0.b55988","name":"","props":[{"p":"payload"},{"p":"topic","vt":"str"}],"repeat":"","crontab":"","once":false,"onceDelay":0.1,"topic":"","payload":"","payloadType":"date","x":430,"y":1860,"wires":[["ef4dc25b.b0a"]]},{"id":"b6c6500c.41cc1","type":"modbus-client","name":"SBS2.5","clienttype":"tcp","bufferCommands":true,"stateLogEnabled":false,"queueLogEnabled":false,"tcpHost":"192.168.168.55","tcpPort":"502","tcpType":"TPC-RTU-BUFFERED","serialPort":"/dev/ttyUSB","serialType":"RTU-BUFFERD","serialBaudrate":"9600","serialDatabits":"8","serialStopbits":"1","serialParity":"none","serialConnectionDelay":"100","unit_id":3,"commandDelay":200,"clientTimeout":1000,"reconnectOnTimeout":true,"reconnectTimeout":2000,"parallelUnitIdsAllowed":true},{"id":"84d14f5d.16a5f","type":"ui_group","name":"BYD HVS 7.7","tab":"69ee5cda.ec1a2c","order":1,"disp":true,"width":"5","collapse":false},{"id":"d5972738.a29c7","type":"ui_group","name":"SBS 2.5","tab":"69ee5cda.ec1a2c","order":2,"disp":true,"width":"5","collapse":false},{"id":"a5b1ca83.42d688","type":"ui_group","name":"Gesamt","tab":"ebd65be0.9e9c18","order":1,"disp":true,"width":"5","collapse":false},{"id":"5e2cd394.9ef8dc","type":"ui_group","name":"Verlauf","tab":"a05d944.2f68be8","order":1,"disp":true,"width":"36","collapse":false},{"id":"69ee5cda.ec1a2c","type":"ui_tab","name":"Batterie","icon":"fa-battery-half","order":2,"disabled":false,"hidden":false},{"id":"ebd65be0.9e9c18","type":"ui_tab","name":"Photovoltaik","icon":"fa-sun-o ","order":1,"disabled":false,"hidden":false},{"id":"a05d944.2f68be8","type":"ui_tab","name":"Verlauf Batterie","icon":"fa-line-chart","order":15,"disabled":false,"hidden":false}]
The inject node is setting msg.payload to a string. Then in the change node, you try to treat msg.payload as an object but since it is a string the undefined error occurs.
If you change the change node to use a set like this:
Screen Shot 2021-01-05 at 7.40.08 AM
thx !
If I turn off the inverter, I just have to change from Modbusgetter to Changer. :grinning:
