When sharing flows on the forum, it is now possible to get a visual render of the flows to be automatically generated.
By adding the flows type to the code block, it will now get rendered as a flow, making it easier to see at a glance what the flow looks like.
```flows
[{"id":"45b09c2541029b05","type":"inject","z":"9f9e32404549681c","name":"test","props":[{"p":"payload"},{"p":"topic","vt":"str"}],"repeat":"","crontab":"","once":false,"onceDelay":0.1,"topic":"","payload":"","payloadType":"date","x":180,"y":80,"wires":[["c983a304e0ac7655"]]},{"id":"c983a304e0ac7655","type":"debug","z":"9f9e32404549681c","name":"debug 7","active":true,"tosidebar":true,"console":false,"tostatus":false,"complete":"false","statusVal":"","statusType":"auto","x":370,"y":80,"wires":[]}]
This is built using the FlowFuse Flow Renderer, which itself was based on the work @gregorius did originally that he kindly allowed us to reuse.
If you hit any problems, do let me know.
