Shelly bluetooth low energy sensores to MQTT
shelly has released some very nice bluetooth low energy sensors which work together with gen 2 shellies.
In order to use these ble devices you have to run a script on the shelly 2 device, which can for example drive the switch of it. But in order to use these sensors with node-red it is very convinient to use mqtt.
currently I have 3 sensors working: door-window sensor, motion Sensor and button.
Please find attached my scripts: (don't forget to change the mac address!)
DW-sensor:
/******************* START CHANGE HERE *******************/
let CONFIG = {
  // When set to true, debug messages will be logged to the console
  debug: false,
  // When set to true and the script ownes the scanner, the scan will be active.
  // Active scan means the scanner will ping back the Bluetooth device to receive all its data, but it will drain the battery faster
  active: false,
  // When `allowedMacAddresses` is set to null, evets from every bluetooth device are accepted.
  // allowedMacAddresses: null,
  allowedMacAddresses: [     // events only from these mac addresses are allowed.
    "60:ef:ab:42:d4:a1",
	"8c:6f:b9:0b:29:cd",
	"60:ef:ab:0e:0f:e6",
	"60:ef:ab:42:e6:b2"
   * Called when window is reported from the filtered Shelly BLU Motion devices.
   * @param {Boolean} window true, when there is a open window, false otherwise.
   * @param {Object} eventData Object, containing all parameters received from the Shelly BLU Motion device. Example:  {encryption":false,"BTHome_version":2,"pid":63,"battery":100,"illuminance":0,"window":0,"rotation":0,"rssi":-48,"address":"60:ef:ab:42:d4:a1"}
  windowHandler: function (window, eventData) {
    if (window === 1){
	  window = "open");
	else{
	  window = "closed");
    let topic = "shellies/ble/dw/" + eventData.address + "/window";
    // Publish the data.
    MQTT.publish(topic, String(window));
    console.log("Window", window);
   * Called when illuminance is reported from the filtered Shelly BLU Motion devices.
   * @param {Number} illuminance Current illuminance value.
   * @param {Object} eventData Object, containing all parameters received from the Shelly BLU Motion device. Example: {"encryption":false,"BTHome_version":2,"pid":16,"battery":100,"illuminance":109,"motion":1,"button":1,"rssi":-53,"address":"aa:bc:12:34:56:78"}
  illuminanceHandler: function (illuminance, eventData) {
    // Compile the topic based on the mac address of the reporter.
    let topic = "shellies/ble/dw/" + eventData.address + "/illuminance";
    MQTT.publish(topic, String(illuminance));
  rotationHandler: function (rotation, eventData) {
    let topic = "shellies/ble/dw/" + eventData.address + "/rotation";
    MQTT.publish(topic, String(rotation));
   * Called when packet from filtered Shelly BLU Motion devices is received.
  onStatusUpdate: function (eventData) {
    // send complete sensor record
    logger(JSON.stringify(eventData), "info");
    let topic = "shellies/ble/dw/" + eventData.address + "/status";
    MQTT.publish(topic, JSON.stringify(eventData));
/******************* STOP CHANGE HERE *******************/
let ALLTERCO_MFD_ID_STR = "0ba9";
let BTHOME_SVC_ID_STR = "fcd2";
let uint8 = 0;
let int8 = 1;
let uint16 = 2;
let int16 = 3;
let uint24 = 4;
let int24 = 5;
//Logs the provided message with an optional prefix to the console.
function logger(message, prefix) {
  //exit if the debug isn't enabled
  if (!CONFIG.debug) {
    return;
  let finalText = "";
  //if the message is list loop over it
  if (Array.isArray(message)) {
    for (let i = 0; i < message.length; i++) {
      finalText = finalText + " " + JSON.stringify(message[i]);
  } else {
    finalText = JSON.stringify(message);
  //the prefix must be string
  if (typeof prefix !== "string") {
    prefix = "";
  } else {
    prefix = prefix + ":";
  //log the result
  console.log(prefix, finalText);
// The BTH object defines the structure of the BTHome data
let BTH = {};
BTH[0x00] = { n: "pid", t: uint8 };
BTH[0x01] = { n: "battery", t: uint8, u: "%" };
BTH[0x02] = { n: "temperature", t: int16, f: 0.01, u: "tC" };
BTH[0x03] = { n: "humidity", t: uint16, f: 0.01, u: "%" };
BTH[0x05] = { n: "illuminance", t: uint24, f: 0.01 };
BTH[0x21] = { n: "motion", t: uint8 };
BTH[0x2d] = { n: "window", t: uint8 };
BTH[0x3a] = { n: "button", t: uint8 };
BTH[0x3f] = { n: "rotation", t: int16, f: 0.1 };
function getByteSize(type) {
  if (type === uint8 || type === int8) return 1;
  if (type === uint16 || type === int16) return 2;
  if (type === uint24 || type === int24) return 3;
  //impossible as advertisements are much smaller;
  return 255;
// functions for decoding and unpacking the service data from Shelly BLU devices
let BTHomeDecoder = {
  utoi: function (num, bitsz) {
    let mask = 1 << (bitsz - 1);
    return num & mask ? num - (1 << bitsz) : num;
  getUInt8: function (buffer) {
    return buffer.at(0);
  getInt8: function (buffer) {
    return this.utoi(this.getUInt8(buffer), 8);
  getUInt16LE: function (buffer) {
    return 0xffff & ((buffer.at(1) << 8) | buffer.at(0));
  getInt16LE: function (buffer) {
    return this.utoi(this.getUInt16LE(buffer), 16);
  getUInt24LE: function (buffer) {
    return (
      0x00ffffff & ((buffer.at(2) << 16) | (buffer.at(1) << 8) | buffer.at(0))
  getInt24LE: function (buffer) {
    return this.utoi(this.getUInt24LE(buffer), 24);
  getBufValue: function (type, buffer) {
    if (buffer.length < getByteSize(type)) return null;
    let res = null;
    if (type === uint8) res = this.getUInt8(buffer);
    if (type === int8) res = this.getInt8(buffer);
    if (type === uint16) res = this.getUInt16LE(buffer);
    if (type === int16) res = this.getInt16LE(buffer);
    if (type === uint24) res = this.getUInt24LE(buffer);
    if (type === int24) res = this.getInt24LE(buffer);
    return res;
  // Unpacks the service data buffer from a Shelly BLU device
  unpack: function (buffer) {
    //beacons might not provide BTH service data
    if (typeof buffer !== "string" || buffer.length === 0) return null;
    let result = {};
    let _dib = buffer.at(0);
    result["encryption"] = _dib & 0x1 ? true : false;
    result["BTHome_version"] = _dib >> 5;
    if (result["BTHome_version"] !== 2) return null;
    //can not handle encrypted data
    if (result["encryption"]) return result;
    buffer = buffer.slice(1);
    let _bth;
    let _value;
    while (buffer.length > 0) {
      _bth = BTH[buffer.at(0)];
      if (typeof _bth === "undefined") {
        logger("unknown type", "BTH");
        break;
      _value = this.getBufValue(_bth.t, buffer);
      if (_value === null) break;
      if (typeof _bth.f !== "undefined") _value = _value * _bth.f;
      result[_bth.n] = _value;
      buffer = buffer.slice(getByteSize(_bth.t));
    return result;
function onReceivedPacket (data) {
  if(CONFIG._processedMacAddresses !== null) {
    if(CONFIG._processedMacAddresses.indexOf(data.address) < 0) {
      logger(["Received event from", data.address, "outside of the allowed addresses"], "Info");
      return;
  if (
    typeof CONFIG.windowHandler === "function" &&
    typeof data.window !== "undefined"
    CONFIG.windowHandler(data.window, data);
    logger("Window handler called", "Info");
  if (
    typeof CONFIG.illuminanceHandler === "function" &&
    typeof data.illuminance !== "undefined"
    CONFIG.illuminanceHandler(data.illuminance, data);
    logger("Illuminance handler called", "Info");
  if (
    typeof CONFIG.rotationHandler === "function" &&
    typeof data.rotation !== "undefined"
    CONFIG.rotationHandler(data.rotation, data);
    logger("Rotation handler called", "Info");
  if (typeof CONFIG.onStatusUpdate === "function") {
    CONFIG.onStatusUpdate(data);
    logger("New status update", "Info");
//saving the id of the last packet, this is used to filter the duplicated packets
let lastPacketId = 0x100;
// Callback for the BLE scanner object
function BLEScanCallback(event, result) {
  //exit if not a result of a scan
  if (event !== BLE.Scanner.SCAN_RESULT) {
    return;
  //exit if service_data member is missing
  if (
    typeof result.service_data === "undefined" ||
    typeof result.service_data[BTHOME_SVC_ID_STR] === "undefined"
    return;
  let unpackedData = BTHomeDecoder.unpack(
  //exit if unpacked data is null or the device is encrypted
  if (
    unpackedData === null ||
    typeof unpackedData === "undefined" ||
    unpackedData["encryption"]
    logger("Encrypted devices are not supported", "Error");
    return;
  //exit if the event is duplicated
  if (lastPacketId === unpackedData.pid) {
    return;
  lastPacketId = unpackedData.pid;
  unpackedData.rssi = result.rssi;
  unpackedData.address = result.addr;
  onReceivedPacket(unpackedData);
// Initializes the script and performs the necessary checks and configurations
function init() {
  //exit if can't find the config
  if (typeof CONFIG === "undefined") {
    console.log("Error: Undefined config");
    return;
  //get the config of ble component
  let BLEConfig = Shelly.getComponentConfig("ble");
  //exit if the BLE isn't enabled
  if (!BLEConfig.enable) {
    console.log(
      "Error: The Bluetooth is not enabled, please enable it from settings"
    return;
  //check if the scanner is already running
  if (BLE.Scanner.isRunning()) {
    console.log("Info: The BLE gateway is running, the BLE scan configuration is managed by the device");
  else {
    //start the scanner
    let bleScanner = BLE.Scanner.Start({
        duration_ms: BLE.Scanner.INFINITE_SCAN,
        active: CONFIG.active
    if(!bleScanner) {
      console.log("Error: Can not start new scanner");
  if (
    typeof CONFIG.allowedMacAddresses !== "undefined"
    if(CONFIG.allowedMacAddresses !== null) {
      // Process configured mac addresses all to lower case and remove duplicates.
      CONFIG._processedMacAddresses =
        CONFIG
          .map(function (mac) { return mac.toLowerCase(); })
          .filter(function (value, index, array) { return array.indexOf(value) === index; })
    else {
      CONFIG._processedMacAddresses = null;
  //subscribe a callback to BLE scanner
  BLE.Scanner.Subscribe(BLEScanCallback);
Shelly.call("Mqtt.GetConfig", "", function (res, err_code, err_msg, ud) {
  SHELLY_ID = res["topic_prefix"];
init();
Motion sensor:
let CONFIG = {
  debug: false,
  active: false,
    "3C:2E:F5:BB:71:F3"         // events only from these mac addresses are allowed.
   * Called when motion is reported from the filtered Shelly BLU Motion devices.
   * @param {Boolean} motion true, when there is a motion, false otherwise.
  motionHandler: function (motion, eventData) {
    // Toggle the first replay ON/OFF based on the motion value.
    Shelly.call("Switch.Set", { id: 0, on: motion });
    console.log("Motion", motion);
    let topic = "shellies/ble/motion/" + eventData.address + "/illuminance";
    // Do nothing at the moment.
    console.log("Received Status " + JSON.stringify(eventData));
    let topic = "shellies/ble/motion/" + eventData.address + "/status";
let uint8 = 0;
let int8 = 1;
let uint16 = 2;
let int16 = 3;
let uint24 = 4;
let int24 = 5;
    return;
  let finalText = "";
  } else {
    prefix = "";
  } else {
  //log the result
let BTH = {};
  return 255;
    return (
    let res = null;
    return res;
    let result = {};
    let _bth;
    let _value;
        break;
    return result;
      return;
  if (
    typeof CONFIG.motionHandler === "function" &&
    typeof data.motion !== "undefined"
    CONFIG.motionHandler(data.motion === 1, data);
    logger("Motion handler called", "Info");
  if (
    return;
  if (
    return;
  if (
    return;
    return;
function init() {
    return;
    console.log(
    return;
  else {
    //start the scanner
    if(!bleScanner) {
  if (
        CONFIG
    else {
init();
Button:
let CONFIG = {
  debug: false,
  active: false,
    "60:ef:ab:4a:ee:73"
  buttonHandler: function (button, eventData) {
    let topic = "shellies/ble/button/" + eventData.address + "/button";
    MQTT.publish(topic, String(button));
    console.log("Button", button);
    let topic = "shellies/ble/button/" + eventData.address + "/status";
let uint8 = 0;
let int8 = 1;
let uint16 = 2;
let int16 = 3;
let uint24 = 4;
let int24 = 5;
    return;
  let finalText = "";
  } else {
    prefix = "";
  } else {
  //log the result
let BTH = {};
  return 255;
    return (
    let res = null;
    return res;
    let result = {};
    let _bth;
    let _value;
        break;
    return result;
      return;
  if (
    typeof CONFIG.buttonHandler === "function" &&
    typeof data.button !== "undefined"
    CONFIG.buttonHandler(data.button, data);
    logger("Button handler called", "Info");
    return;
  if (
    return;
  if (
    return;
    return;
function init() {
    return;
    console.log(
    return;
  else {
    //start the scanner
    if(!bleScanner) {
  if (
        CONFIG
    else {
init();
Good info for others could you maybe add a little readme explaining how to apply the scripts, for the less tech savy.
have a look at this video.
shelly motion sensor
It helped me a lot to start with the shelly ble devices.
Unfortunately this video uses German language. I hope this is not a problem.
Actually my scripts are a little differrent to the one in the video and are better suited to nod-red and mqtt.
