Shelly Plus Add-On - command to retrieve temperature status
Old Shelly addon works with command
msg.payload = msg.status.ext_temperature["1"].tC;
With the new shelly addon I would assume this command
payload.temperature100.tC
but it doesn't work. I've tried different variations but no luck.
e.g.
msg.payload = msg.status.temperature["100"].tC
msg.payload = msg.status.temperature100["100"].tC
Thanks in advance for the advice
Hi @Frantisek
In order to provide the help - please show us the incoming data and highlight what data you want from it.
Not a screen shot please , but an example payload :smiley:
Plenty of Shelly users here
    1. 2024 21:16:07node: 0bf4d6692d3bd262msg.payload : Object
object
input0: object
switch0: object
temperature100: object
tC: 21.8
tF: 71.2
temperature101: object
There is no status property.
Marcus asked for the debug value, which you can get as shown below.
There’s a great page in the docs (Working with messages : Node-RED) that will explain how to use the debug panel to find the right path/value for any data item.
BX00Cy7yHi
The path to the property value should be some thing like payload.temperature100.tc You then prefix with msg.
I really need to save that infamous gif. where is it?
flows (12).json (1.3 KB)
SnĂ­mek obrazovky 2024-09-13 215541
Maybe you should reread my post.
Still not working.
Status is the status output from the shelly node.
With old version Shelly addon works with command
Copy path old shelly temperature addon is:
payload.ext.temperature["0"].tC
Copy of path is different than a function command
Shely plus 1 + new addon + temperature snsors
Miraculously, it works today. :slight_smile:
To get the value, the command works (as we all assumed yesterday)
msg.payload = msg.payload.temperature100.tC;
Thanks E1cid and marcus-j-davies
for your support in solving this mysterious problem. Thanks Frantisek
Finally I can use these variables from the gen2 shelly.
