I would like to show a footer on each dashboard page.
I bet it could be done with the template control but I can't imagine how?!
Could anybody please give me some help?
BR
Jochen
BR
Jochen
Yes it can but as you probably know, a template node puts a card onto the dashboard (meaning if you add a ui template node, you will have an extra card in the layout)
If you already have a template node on your "home" page, then you can simply add the below to that template.
<style>
.footer {
position: fixed;
left: 0;
bottom: 0;
width: 100%;
background-color: red;
color: white;
text-align: center;
</style>
<script>
$("#nr-dashboard-footer").append('<div class="footer"><p>My Footer</p></div>');
</script>
Alternatively, if you have to add a ui-template node (because you dont have one on your home page) then you could hide the card ...
<style>
.footer {
position: fixed;
left: 0;
bottom: 0;
width: 100%;
color: white;
text-align: center;
</style>
<script>
//append a custom footer into #nr-dashboard-footer
//hide this card. NOTE: a960b1e5.8aec is the Node id as seen in the INFO panel on the sidebar
$('[node-id="a960b1e5.8aec"]').hide();
</script>
NOTE: both of these work but I would consider them hacks.
As there is an element named nr-dashboard-footer (check your browsers devtools) I suspect there might be a better solution.
That element is there "to be hacked" for exactly this purpose - so yes - appending something to it is the way to go.
good to know
Sounds like someone should create a custom ui node
Bart isn't coding at the moment Julian ![]()
Thank you gentlemen. That was handy... Thanks for leaving it out there to hack.
if you want the footer color to match the title bar color just use:
background-color: var(--nr-dashboard-widgetColor);
