Show how much time is left in a delay
I have some long delays in a flow and I wanted to know how much time is remaining in them (one is 30 secs - the other is 5 minutes) when I'm sitting around debugging it.
Using Blockly, I've come up with this combination of a Blockly (or JS function) node and a standard delay node
The Blockly node defaults to counting down in 10 sec intervals from 60 seconds (these seemed like a reasonable defaults for a long running delay) but you can override the number of steps and the overall delay by inserting msg.steps and/or msg.delay (which is in seconds not milliseconds) into the flow along with the actual real msg
The flow here contains both the Blocky version and a copy/paste of the JS code it generates to be used in a function node if you want to use it that way
[{"id":"cc99e4f4.578408","type":"Blockly","z":"3bfd8455.6e864c","language":"en","func":"var oldMsg;\n\n/**\n * Describe this function...\n */\nfunction deleteAllContextProperties() {\n  context.set('steps');\n  context.set('delay');\n  context.set('oldMsg');\n  context.set('delayInterval');\n  node.status({});\n}\n\n\nif ('reset' in msg) {\n  msg['reset'] = true;\n  node.send([msg, null]);\n  deleteAllContextProperties();\n  return;\n}\nif (!(context.keys().includes('steps'))) {\n  // Either set the count and delay here or set them with\n  // via msg.delay (in secs) and msg.steps\n  context.set('steps', 6);\n  context.set('delay', 60);\n  if ('steps' in msg) {\n    context.set('steps', (msg['steps']));\n    delete msg['steps'];\n  }\n  if ('delay' in msg) {\n    context.set('delayInterval', ((msg['delay']) / (context.get('steps'))));\n    delete msg['delay'];\n  } else {\n    context.set('delayInterval', ((context.get('delay')) / (context.get('steps'))));\n  }\n  context.set('oldMsg', RED.util.cloneMessage(msg));\n}\nif ((context.get('steps')) > 0) {\n  msg['payload'] = (context.get('steps'));\n  msg['delay'] = ((context.get('delayInterval')) * 1000);\n  node.status({fill:\"blue\", shape:\"ring\", text:(String((context.get('steps')) * (context.get('delayInterval'))) + String('s'))});\n  node.send([msg, null]);\n  context.set('steps', ((context.get('steps')) - 1));\n} else {\n  oldMsg = (context.get('oldMsg'));\n  deleteAllContextProperties();\n  return [null, oldMsg];\n}\nreturn;\n","workspaceXml":"<xml xmlns=\"http://www.w3.org/1999/xhtml\"><variables><variable type=\"\" id=\"HKO%Q}Y-f%,]dF#E9bEq\">oldMsg</variable></variables><block type=\"controls_if\" id=\"ut);{+7j.yo8f*.vB~]t\" x=\"-12\" y=\"-187\"><value name=\"IF0\"><block type=\"node_object_get\" id=\"5H=si~S2q~?^GfW?2-2)\"><mutation action=\"HAS\"></mutation><field name=\"action\">HAS</field><value name=\"object\"><shadow type=\"node_msg\" id=\"FKJx:cJ.`+PXU-X)P+CJ\"></shadow></value><value name=\"field_name\"><shadow type=\"text\" id=\"hO5Nnw4/v:oMIT%]QW-:\"><field name=\"TEXT\">reset</field></shadow></value></block></value><statement name=\"DO0\"><block type=\"node_object_set\" id=\"9ezUQ3V%FKGlEn^RP*(:\"><value name=\"object_field\"><shadow type=\"node_msg\" id=\"ENNAl@y`4=8J2vC/11Fq\"></shadow></value><value name=\"field_name\"><shadow type=\"text\" id=\"2?,hMUh!=Uo4`Qwt1CR-\"><field name=\"TEXT\">reset</field></shadow></value><value name=\"value_field\"><shadow type=\"text\" id=\"AwrmYmp}iJX9vDf{CP%7\"><field name=\"TEXT\"></field></shadow><block type=\"logic_boolean\" id=\"QVpQ6;d}3_;v?kBMvOJx\"><field name=\"BOOL\">TRUE</field></block></value><next><block type=\"node_send\" id=\"Xci;AqSB)XnZu/s73Ne@\"><field name=\"OUTPUT_NR\">1</field><value name=\"MESSAGE_INPUT\"><shadow type=\"node_msg\" id=\"PCV,M8p5T1[.UUnbHJe5\"></shadow></value><next><block type=\"procedures_callnoreturn\" id=\"6?p2zRb{qXyq+J+@5Ev3\"><mutation name=\"deleteAllContextProperties\"></mutation><next><block type=\"node_return\" id=\"?Pep(`:lgYf=|^5x)5{f\"></block></next></block></next></block></next></block></statement><next><block type=\"controls_if\" id=\"+bF0gT(c/Dw61BZ%[=n/\"><value name=\"IF0\"><block type=\"logic_negate\" id=\"8f8y6tTeb+`:d=e4^{F1\"><value name=\"BOOL\"><block type=\"node_object_get\" id=\"a},naI(G*{@b-o9.0Id8\"><mutation action=\"HAS\"></mutation><field name=\"action\">HAS</field><value name=\"object\"><shadow type=\"node_msg\" id=\"FKJx:cJ.`+PXU-X)P+CJ\"></shadow><block type=\"node_context_memory\" id=\"fO0.WL3BRWpyuPT}1w5Z\"></block></value><value name=\"field_name\"><shadow type=\"text\" id=\"8jiWdo-gp%f3M8]Jm9PS\"><field name=\"TEXT\">steps</field></shadow></value></block></value></block></value><statement name=\"DO0\"><block type=\"misc_comment\" id=\"MudZ(G6+@I4ri!SY30A]\"><value name=\"TEXT\"><shadow type=\"text\" id=\";=gJs-V(`uWm0?Yxb{#c\"><field name=\"TEXT\">Either set the count and delay here or set them with </field></shadow></value><next><block type=\"misc_comment\" id=\"oHbC4k6_9CLb/k8~KK0j\"><value name=\"TEXT\"><shadow type=\"text\" id=\"AgE|HE$:5F[7gvXP/fty\"><field name=\"TEXT\">via msg.delay (in secs) and msg.steps </field></shadow></value><next><block type=\"node_object_set\" id=\"1Bw|VX*,Y#P_Mw*LWXnv\" inline=\"true\"><value name=\"object_field\"><shadow type=\"node_msg\" id=\"Mk.GB0YwJODq$bt/UxRO\"></shadow><block type=\"node_context_memory\" id=\"U)Y]i/(nmEgyWj=!V2Ti\"></block></value><value name=\"field_name\"><shadow type=\"text\" id=\"9C}bdC_Ji(KQkDt%}4*)\"><field name=\"TEXT\">steps</field></shadow></value><value name=\"value_field\"><shadow type=\"text\" id=\"po_V@D10s;ziqUpwNq4B\"><field name=\"TEXT\">30</field></shadow><block type=\"math_number\" id=\":OgQ%DddOB*D?26p4A=o\"><field name=\"NUM\">6</field></block></value><next><block type=\"node_object_set\" id=\"gisD*?OmT_`fP#NfeOX#\" inline=\"true\"><value name=\"object_field\"><shadow type=\"node_msg\" id=\"Mk.GB0YwJODq$bt/UxRO\"></shadow><block type=\"node_context_memory\" id=\"V/8IOA}T1fV7QVDN()e;\"></block></value><value name=\"field_name\"><shadow type=\"text\" id=\"/62l0FX^*ivj?#w8}H%T\"><field name=\"TEXT\">delay</field></shadow></value><value name=\"value_field\"><shadow type=\"text\" id=\"po_V@D10s;ziqUpwNq4B\"><field name=\"TEXT\">10</field></shadow><block type=\"math_number\" id=\"ZF)ShK??zet!TtmGuA-U\"><field name=\"NUM\">60</field></block></value><next><block type=\"controls_if\" id=\"wzegmAGE|qLk%SIF@z:M\"><value name=\"IF0\"><block type=\"node_object_get\" id=\"13V+t(Tm/e2:0%kI^FU=\"><mutation action=\"HAS\"></mutation><field name=\"action\">HAS</field><value name=\"object\"><shadow type=\"node_msg\" id=\"^6z,).W|LRPHJ(mv,N8,\"></shadow></value><value name=\"field_name\"><shadow type=\"text\" id=\"_mYulzCx|$^a#+(@JIu}\"><field name=\"TEXT\">steps</field></shadow></value></block></value><statement name=\"DO0\"><block type=\"node_object_set\" id=\"kRyQ2-[In5:0YzLXl)H.\" inline=\"true\"><value name=\"object_field\"><shadow type=\"node_msg\" id=\"Mk.GB0YwJODq$bt/UxRO\"></shadow><block type=\"node_context_memory\" id=\"HEoA?5wu)?5+E*j9@Wj8\"></block></value><value name=\"field_name\"><shadow type=\"text\" id=\"9BJjCc+_zgjrS-,q;OiC\"><field name=\"TEXT\">steps</field></shadow></value><value name=\"value_field\"><shadow type=\"text\" id=\"po_V@D10s;ziqUpwNq4B\"><field name=\"TEXT\">10</field></shadow><block type=\"node_object_get\" id=\"gh]IE8JRp+0S-s)q@=i]\"><mutation action=\"GET\"></mutation><field name=\"action\">GET</field><value name=\"object\"><shadow type=\"node_msg\" id=\"OIx%.lXT~3k9Xo5BDuVZ\"></shadow></value><value name=\"field_name\"><shadow type=\"text\" id=\"Xwvw8u0rceAF46B,A]e4\"><field name=\"TEXT\">steps</field></shadow></value></block></value><next><block type=\"node_object_get\" id=\"myJiSmFeDe71~Ueb79;z\"><mutation action=\"REMOVE\"></mutation><field name=\"action\">REMOVE</field><value name=\"object\"><shadow type=\"node_msg\" id=\"1+BTaV%1kq,siZ+$iXiX\"></shadow></value><value name=\"field_name\"><shadow type=\"text\" id=\"CfXm]9;||f077Jtw.VEO\"><field name=\"TEXT\">steps</field></shadow></value></block></next></block></statement><next><block type=\"controls_if\" id=\",}#Dt:0L0^{m@.gW/!f6\"><mutation else=\"1\"></mutation><value name=\"IF0\"><block type=\"node_object_get\" id=\",zL^sDw?Xed@=!c*]o[A\"><mutation action=\"HAS\"></mutation><field name=\"action\">HAS</field><value name=\"object\"><shadow type=\"node_msg\" id=\"!Xa,u*o)E,X;|Zn@lvr,\"></shadow></value><value name=\"field_name\"><shadow type=\"text\" id=\"$0@!#+_3J}KYWaG{yyq=\"><field name=\"TEXT\">delay</field></shadow></value></block></value><statement name=\"DO0\"><block type=\"node_object_set\" id=\"H%NC$KyKz:oy+{aQ6`DN\" inline=\"true\"><value name=\"object_field\"><shadow type=\"node_msg\" id=\"Mk.GB0YwJODq$bt/UxRO\"></shadow><block type=\"node_context_memory\" id=\"EsS%qmdvu$!.#+QoA$rM\"></block></value><value name=\"field_name\"><shadow type=\"text\" id=\"qC_%!qFhl;WXS:W%J_bf\"><field name=\"TEXT\">delayInterval</field></shadow></value><value name=\"value_field\"><shadow type=\"text\" id=\"po_V@D10s;ziqUpwNq4B\"><field name=\"TEXT\">10</field></shadow><block type=\"math_arithmetic\" id=\"cx0%oNLoOV)GR],3Im_9\" inline=\"false\"><field name=\"OP\">DIVIDE</field><value name=\"A\"><shadow type=\"math_number\" id=\"ANd8Zx[K,#1/b:`R:IC,\"><field name=\"NUM\">1</field></shadow><block type=\"node_object_get\" id=\"Ut0d3F6Upy7*:YYoDz_`\"><mutation action=\"GET\"></mutation><field name=\"action\">GET</field><value name=\"object\"><shadow type=\"node_msg\" id=\"=n]Y^fUv|dVYPTHzSN;6\"></shadow></value><value name=\"field_name\"><shadow type=\"text\" id=\")I8dP=OBg*YTAcW.j~tF\"><field name=\"TEXT\">delay</field></shadow></value></block></value><value name=\"B\"><shadow type=\"math_number\" id=\"/`hJ5.h@mk*sx*$y=-5e\"><field name=\"NUM\">1</field></shadow><block type=\"node_object_get\" id=\"8Hx41]aB^#]6-ujjfd)T\"><mutation action=\"GET\"></mutation><field name=\"action\">GET</field><value name=\"object\"><shadow type=\"node_msg\" id=\"`=MhXcRM0i*tFsP{.UWr\"></shadow><block type=\"node_context_memory\" id=\"+j7R=~H#/Y#!|OAzJoe%\"></block></value><value name=\"field_name\"><shadow type=\"text\" id=\"(}_jP@LSP_wOY{xS24r1\"><field name=\"TEXT\">steps</field></shadow></value></block></value></block></value><next><block type=\"node_object_get\" id=\"p7K8~?lsUq8hPdi,%-uZ\"><mutation action=\"REMOVE\"></mutation><field name=\"action\">REMOVE</field><value name=\"object\"><shadow type=\"node_msg\" id=\"0IfAm;.pBK|9p6;14{TW\"></shadow></value><value name=\"field_name\"><shadow type=\"text\" id=\"T_5HXMw:Mx}zp~.=#.jl\"><field name=\"TEXT\">delay</field></shadow></value></block></next></block></statement><statement name=\"ELSE\"><block type=\"node_object_set\" id=\"`^O7CyHvtH./.B2tyOWI\" inline=\"true\"><value name=\"object_field\"><shadow type=\"node_msg\" id=\"Mk.GB0YwJODq$bt/UxRO\"></shadow><block type=\"node_context_memory\" id=\"+-NDzjU[fyw`zk^xs^FD\"></block></value><value name=\"field_name\"><shadow type=\"text\" id=\"sNxDH!$9Jy!PqX]}SYwG\"><field name=\"TEXT\">delayInterval</field></shadow></value><value name=\"value_field\"><shadow type=\"text\" id=\"po_V@D10s;ziqUpwNq4B\"><field name=\"TEXT\">10</field></shadow><block type=\"math_arithmetic\" id=\"9R!7ScUodK=x1bI0Gsxj\" inline=\"false\"><field name=\"OP\">DIVIDE</field><value name=\"A\"><shadow type=\"math_number\" id=\"ANd8Zx[K,#1/b:`R:IC,\"><field name=\"NUM\">1</field></shadow><block type=\"node_object_get\" id=\"$%_T1]M8G}kHMnQhUTR@\"><mutation action=\"GET\"></mutation><field name=\"action\">GET</field><value name=\"object\"><shadow type=\"node_msg\" id=\"k$rX3,tMC)#h47CGaO$g\"></shadow><block type=\"node_context_memory\" id=\"BsIdxNlz}8^I]1RSp[.{\"></block></value><value name=\"field_name\"><shadow type=\"text\" id=\"+l/nPpG|U!)R,(nddW6*\"><field name=\"TEXT\">delay</field></shadow></value></block></value><value name=\"B\"><shadow type=\"math_number\" id=\"/`hJ5.h@mk*sx*$y=-5e\"><field name=\"NUM\">1</field></shadow><block type=\"node_object_get\" id=\"/{|Dj-|CB280R.F*OG/!\"><mutation action=\"GET\"></mutation><field name=\"action\">GET</field><value name=\"object\"><shadow type=\"node_msg\" id=\"`=MhXcRM0i*tFsP{.UWr\"></shadow><block type=\"node_context_memory\" id=\"#ilO-WXSn+5I[-fyC(=_\"></block></value><value name=\"field_name\"><shadow type=\"text\" id=\"K-`|^!so~{_l-^M`mIh?\"><field name=\"TEXT\">steps</field></shadow></value></block></value></block></value></block></statement><next><block type=\"node_object_set\" id=\"H)c[zXr5r*3+)O.e+jGj\" inline=\"true\"><value name=\"object_field\"><shadow type=\"node_msg\" id=\"Mk.GB0YwJODq$bt/UxRO\"></shadow><block type=\"node_context_memory\" id=\"Y)mRVV#dVYsuW0[XX?p8\"></block></value><value name=\"field_name\"><shadow type=\"text\" id=\"@d7toD:j1wzcH4GNxC@v\"><field name=\"TEXT\">oldMsg</field></shadow></value><value name=\"value_field\"><shadow type=\"text\" id=\"po_V@D10s;ziqUpwNq4B\"><field name=\"TEXT\">10</field></shadow><block type=\"node_clone\" id=\"nODzwIzht)g;/-}_|otM\"><value name=\"OBJECT_INPUT\"><shadow type=\"node_msg\" id=\"cgj;Z(kf$c%rC~nXJy*s\"></shadow><block type=\"node_msg\" id=\"p-(^3(C2=Z3).y|-W{,m\"></block></value></block></value></block></next></block></next></block></next></block></next></block></next></block></next></block></statement><next><block type=\"controls_if\" id=\"$,_X=tuX`~bDkr*kunn#\"><mutation else=\"1\"></mutation><value name=\"IF0\"><block type=\"logic_compare\" id=\"[sbxx}=99x;~|60HzYet\"><field name=\"OP\">GT</field><value name=\"A\"><block type=\"node_object_get\" id=\"_%O=~_*u9^S{a0O:Pu.*\"><mutation action=\"GET\"></mutation><field name=\"action\">GET</field><value name=\"object\"><shadow type=\"node_msg\" id=\"`=MhXcRM0i*tFsP{.UWr\"></shadow><block type=\"node_context_memory\" id=\"P/cpN:pw.ZF#:X;Bg@_;\"></block></value><value name=\"field_name\"><shadow type=\"text\" id=\"F!j1.bAMY+NMElIG?PyW\"><field name=\"TEXT\">steps</field></shadow></value></block></value><value name=\"B\"><block type=\"math_number\" id=\"7;13d|%I=j5olY85^.E;\"><field name=\"NUM\">0</field></block></value></block></value><statement name=\"DO0\"><block type=\"node_object_set\" id=\"dt::hx_#rbdVL%RzIV?X\"><value name=\"object_field\"><shadow type=\"node_msg\" id=\"cb(Ks+rWD9[ipqfvwAuC\"></shadow></value><value name=\"field_name\"><shadow type=\"text\" id=\"z)dhAchBqR?6+Uk||=tI\"><field name=\"TEXT\">payload</field></shadow></value><value name=\"value_field\"><shadow type=\"text\" id=\"G$9)Wvrea(9gr@8;?A/^\"><field name=\"TEXT\"></field></shadow><block type=\"node_object_get\" id=\"_[Q5L[mBsP/4q~fEU$rk\"><mutation action=\"GET\"></mutation><field name=\"action\">GET</field><value name=\"object\"><shadow type=\"node_msg\" id=\"`=MhXcRM0i*tFsP{.UWr\"></shadow><block type=\"node_context_memory\" id=\"/O9/)!iVTnH[Swy]fY?^\"></block></value><value name=\"field_name\"><shadow type=\"text\" id=\"*5BT:/L0ICsZ5CwF%wdd\"><field name=\"TEXT\">steps</field></shadow></value></block></value><next><block type=\"node_object_set\" id=\"+/qyDNJ8GL?2Cc:..T7g\"><value name=\"object_field\"><shadow type=\"node_msg\" id=\"D*ZjiPNi@aAPpj?sx+Vr\"></shadow></value><value name=\"field_name\"><shadow type=\"text\" id=\"/caCBwO32zwX_R@mvGtP\"><field name=\"TEXT\">delay</field></shadow></value><value name=\"value_field\"><shadow type=\"text\" id=\"#I?u*`WU*f]YRWV.??M5\"><field name=\"TEXT\"></field></shadow><block type=\"math_arithmetic\" id=\"4_9WL%eP]f?)5f?1jF4`\"><field name=\"OP\">MULTIPLY</field><value name=\"A\"><shadow type=\"math_number\" id=\".?tHLWC`YRRaL8)_eD;[\"><field name=\"NUM\">1</field></shadow><block type=\"node_object_get\" id=\"LQ2J]@OJ~JM5YZctk:#+\"><mutation action=\"GET\"></mutation><field name=\"action\">GET</field><value name=\"object\"><shadow type=\"node_msg\" id=\"`=MhXcRM0i*tFsP{.UWr\"></shadow><block type=\"node_context_memory\" id=\"sNh}[PB`BCk3-WU[m/u`\"></block></value><value name=\"field_name\"><shadow type=\"text\" id=\"hW^G-!{Hn_@$S+{F%mZ4\"><field name=\"TEXT\">delayInterval</field></shadow></value></block></value><value name=\"B\"><shadow type=\"math_number\" id=\"`KiQj@vjzxk4ScTEkxZ}\"><field name=\"NUM\">1000</field></shadow></value></block></value><next><block type=\"node_status\" id=\"Ehn*X,?~Ss]5e-[z3V9|\"><field name=\"COLOUR\">#0000FF</field><field name=\"SHAPE\">RING</field><value name=\"TEXT_INPUT\"><shadow type=\"text\" id=\"%n018j5.TBOnRR7K/KYk\"><field name=\"TEXT\"></field></shadow><block type=\"text_join\" id=\"$w+*pj?YI3cqq`(i*e3!\"><mutation items=\"2\"></mutation><value name=\"ADD0\"><block type=\"math_arithmetic\" id=\"p_(Aj?NNj?%hH7OLEc]/\"><field name=\"OP\">MULTIPLY</field><value name=\"A\"><shadow type=\"math_number\" id=\"o0nGuXmK2EVP%J5:2!e6\"><field name=\"NUM\">1</field></shadow><block type=\"node_object_get\" id=\"#+hU3-=^$ZK`+UY!5,*4\"><mutation action=\"GET\"></mutation><field name=\"action\">GET</field><value name=\"object\"><shadow type=\"node_msg\" id=\"`=MhXcRM0i*tFsP{.UWr\"></shadow><block type=\"node_context_memory\" id=\"Jf$4$-9NI16sCYQ+dly`\"></block></value><value name=\"field_name\"><shadow type=\"text\" id=\"cNrK|Pc:)O-9j,s%xz$B\"><field name=\"TEXT\">steps</field></shadow></value></block></value><value name=\"B\"><shadow type=\"math_number\" id=\"E?q/.UQkETe/OcMac/P`\"><field name=\"NUM\">1</field></shadow><block type=\"node_object_get\" id=\"K3cUV]a}1PtY(?P;EP[,\"><mutation action=\"GET\"></mutation><field name=\"action\">GET</field><value name=\"object\"><shadow type=\"node_msg\" id=\"`=MhXcRM0i*tFsP{.UWr\"></shadow><block type=\"node_context_memory\" id=\"Ox1uT+,*17ej]?/fnq`%\"></block></value><value name=\"field_name\"><shadow type=\"text\" id=\"kbk4,YK3WZ)sqGxjK4d@\"><field name=\"TEXT\">delayInterval</field></shadow></value></block></value></block></value><value name=\"ADD1\"><block type=\"text\" id=\"t,0[D]{;SL^tY3p]0Q4b\"><field name=\"TEXT\">s</field></block></value></block></value><next><block type=\"node_send\" id=\"OKq_oZj2]KAkj@4q,hD!\"><field name=\"OUTPUT_NR\">1</field><value name=\"MESSAGE_INPUT\"><shadow type=\"node_msg\" id=\"|*~76/aTZj]t]l~NSkX6\"></shadow></value><next><block type=\"node_object_set\" id=\"Gt()LE!.!oo]H4XknCfW\" inline=\"true\"><value name=\"object_field\"><shadow type=\"node_msg\" id=\"Mk.GB0YwJODq$bt/UxRO\"></shadow><block type=\"node_context_memory\" id=\"83bbw]W0:Pe+]}KxOL[,\"></block></value><value name=\"field_name\"><shadow type=\"text\" id=\"VHv5~F.:ee7TJO8a)eq;\"><field name=\"TEXT\">steps</field></shadow></value><value name=\"value_field\"><shadow type=\"text\" id=\"po_V@D10s;ziqUpwNq4B\"><field name=\"TEXT\">10</field></shadow><block type=\"math_arithmetic\" id=\"^6r6=+$O;6_5(v/~}5J0\"><field name=\"OP\">MINUS</field><value name=\"A\"><shadow type=\"math_number\" id=\"?[Sm#}bkWPujsJaQ|Ofr\"><field name=\"NUM\">1</field></shadow><block type=\"node_object_get\" id=\"i*s`g!yy7p.C)]T6nidl\"><mutation action=\"GET\"></mutation><field name=\"action\">GET</field><value name=\"object\"><shadow type=\"node_msg\" id=\"`=MhXcRM0i*tFsP{.UWr\"></shadow><block type=\"node_context_memory\" id=\"C;`NvIV2Q/R[)F*;*ZI/\"></block></value><value name=\"field_name\"><shadow type=\"text\" id=\"fo=m@-{sW#w]u{h%CwR|\"><field name=\"TEXT\">steps</field></shadow></value></block></value><value name=\"B\"><shadow type=\"math_number\" id=\"r!8p!R0oE}U{U:nh.|=`\"><field name=\"NUM\">1</field></shadow></value></block></value></block></next></block></next></block></next></block></next></block></statement><statement name=\"ELSE\"><block type=\"variables_set\" id=\"3xRKnr-eW.+cBHGEOW*8\"><field name=\"VAR\" id=\"HKO%Q}Y-f%,]dF#E9bEq\" variabletype=\"\">oldMsg</field><value name=\"VALUE\"><block type=\"node_object_get\" id=\"-xt6^^r3;s=vF{D/`O,~\"><mutation action=\"GET\"></mutation><field name=\"action\">GET</field><value name=\"object\"><shadow type=\"node_msg\" id=\"`=MhXcRM0i*tFsP{.UWr\"></shadow><block type=\"node_context_memory\" id=\"+DY1XMkzsI6@v8,*#H{H\"></block></value><value name=\"field_name\"><shadow type=\"text\" id=\"=oFhI^yQ:b$D*:2[|otB\"><field name=\"TEXT\">oldMsg</field></shadow></value></block></value><next><block type=\"procedures_callnoreturn\" id=\"Xr.6M!!k]%z}U()z]Fz;\"><mutation name=\"deleteAllContextProperties\"></mutation><next><block type=\"node_return_message\" id=\"tj-WzNC^GvrT+APKl{T+\"><field name=\"OUTPUT_NR\">2</field><value name=\"MESSAGE_INPUT\"><shadow type=\"node_msg\" id=\"]Pj{6CuCZ.nC1^%Dz_2d\"></shadow><block type=\"variables_get\" id=\"-h!GtR7:!yi[$jl,3qh(\"><field name=\"VAR\" id=\"HKO%Q}Y-f%,]dF#E9bEq\" variabletype=\"\">oldMsg</field></block></value></block></next></block></next></block></statement><next><block type=\"node_return\" id=\"U[e[3Wg_Qo$:U%Kgqlwi\"></block></next></block></next></block></next></block><block type=\"procedures_defnoreturn\" id=\"pDuj~i9-fmlu%boefdy(\" x=\"12\" y=\"1312\"><field name=\"NAME\">deleteAllContextProperties</field><comment pinned=\"false\" h=\"80\" w=\"160\">Describe this function...</comment><statement name=\"STACK\"><block type=\"node_object_get\" id=\"Q(HxP0aKYatpJT^,L3b-\"><mutation action=\"REMOVE\"></mutation><field name=\"action\">REMOVE</field><value name=\"object\"><shadow type=\"node_msg\" id=\"dgTWtiCgHscFW+C3|vmy\"></shadow><block type=\"node_context_memory\" id=\"6^Bahz4}0T]z$n[T|=~=\"></block></value><value name=\"field_name\"><shadow type=\"text\" id=\"4q8`w{DlQcXG1S3D7RJ|\"><field name=\"TEXT\">steps</field></shadow></value><next><block type=\"node_object_get\" id=\"AxV1DAyo^u/wC%|h{~}t\"><mutation action=\"REMOVE\"></mutation><field name=\"action\">REMOVE</field><value name=\"object\"><shadow type=\"node_msg\" id=\"dgTWtiCgHscFW+C3|vmy\"></shadow><block type=\"node_context_memory\" id=\"OH6ztRyO)M$.2)[;VJcJ\"></block></value><value name=\"field_name\"><shadow type=\"text\" id=\"N!D7():k(JdFm;7L[:AJ\"><field name=\"TEXT\">delay</field></shadow></value><next><block type=\"node_object_get\" id=\"t+7UYy/WHnqYaqWD!9_t\"><mutation action=\"REMOVE\"></mutation><field name=\"action\">REMOVE</field><value name=\"object\"><shadow type=\"node_msg\" id=\"dgTWtiCgHscFW+C3|vmy\"></shadow><block type=\"node_context_memory\" id=\"t/![g)1YN^v$/P8x|xx4\"></block></value><value name=\"field_name\"><shadow type=\"text\" id=\"yzaieJOu@HlR|RgCDPtc\"><field name=\"TEXT\">oldMsg</field></shadow></value><next><block type=\"node_object_get\" id=\"C$u2M_Ag}RW6P,/*F$OI\"><mutation action=\"REMOVE\"></mutation><field name=\"action\">REMOVE</field><value name=\"object\"><shadow type=\"node_msg\" id=\"dgTWtiCgHscFW+C3|vmy\"></shadow><block type=\"node_context_memory\" id=\"SFpY9_;0?7|o.y=P`1xt\"></block></value><value name=\"field_name\"><shadow type=\"text\" id=\".CwVnRIiSRu6nz1)Bm,N\"><field name=\"TEXT\">delayInterval</field></shadow></value><next><block type=\"node_remove_status\" id=\"%P-^Rrw|6?lH%EQ!nU{r\"></block></next></block></next></block></next></block></next></block></statement></block></xml>","outputs":2,"name":"showDelay","x":690,"y":40,"wires":[["9af0b116.40e83"],["58289501.ff66bc"]],"icon":"node-red/timer.png"}]
I'd appreciate a few road tests by others
Note: It only handles one message at a time - if you send it another msg while 1st one is being delayed - very unpredictable results occur!
Couldnt you just use the MyTimeout node and do the same thing - thats how i use it
Craig
I hadn;t heard of this node - I'll go and check it out ta :slight_smile:
As well as wanting the functionality ,this was an exercise to see if I could do it with Blockly
It proved very useful in finding some bugs in the original 1.0.0 release
Aah - more power to you then !!
Mytimeout by Ncherry
Very good - he has based it on the code from Peter Scargills big timer - i have found it invaluable - lets me have a countdown under the node as well as grabbing the countdown in code and displaying it on my dashboard
Craig
Could you post an example of how it can be configured to just delay a msg - I'm getting confused by all the stuff about states!
Aah not so sure on just delay a message - i use it as a timeout - so lets say i want something to run for 1 hour (3600 secs) i fire into it - here is my flow
[{"id":"be23d858.f070d8","type":"debug","z":"a78930fe.ed232","name":"Boiler Fire up - Node 1","active":false,"tosidebar":true,"console":true,"tostatus":false,"complete":"payload","x":930,"y":1180,"wires":[]},{"id":"5bab8b3b.564f94","type":"mqtt out","z":"a78930fe.ed232","name":"","topic":"topic/fireuptheboileroverride","qos":"","retain":"","broker":"389dd264.7716de","x":940,"y":1220,"wires":[]},{"id":"e1483885.249c28","type":"inject","z":"a78930fe.ed232","name":"Turn off Boiler Override","topic":"topic/fireuptheboileroverride","payload":"0","payloadType":"str","repeat":"","crontab":"","once":false,"onceDelay":"","x":180,"y":1260,"wires":[["5f3a7a46.e835c4"]]},{"id":"15a8756f.b0232b","type":"ui_button","z":"a78930fe.ed232","name":"Manual Turn on of Boiler 1hr","group":"4da5d3cb.b9673c","order":1,"width":0,"height":0,"passthru":false,"label":"Manual Boiler 1 Hr Turn on","color":"","bgcolor":"","icon":"","payload":"{     \"payload\": \"on\",     \"timeout\": 3600,     \"warning\": 5 }","payloadType":"json","topic":"topic/fireuptheboileroverride","x":180,"y":1180,"wires":[["5f3a7a46.e835c4"]]},{"id":"d5c02b4c.5620c8","type":"ui_button","z":"a78930fe.ed232","name":"Turn off Manual Boiler Override","group":"4da5d3cb.b9673c","order":3,"width":0,"height":0,"passthru":false,"label":"Turn off Manual Boiler Override","color":"","bgcolor":"","icon":"","payload":"0","payloadType":"str","topic":"topic/fireuptheboileroverride","x":190,"y":1220,"wires":[["5f3a7a46.e835c4"]]},{"id":"23210b71.6a2104","type":"debug","z":"a78930fe.ed232","name":"Boiler Fire up - Node 2","active":false,"tosidebar":true,"console":false,"tostatus":false,"complete":"payload","x":920,"y":1280,"wires":[]},{"id":"e56bee14.2f24b","type":"ui_button","z":"a78930fe.ed232","name":"Manual Turn on of Boiler 2hr","group":"4da5d3cb.b9673c","order":2,"width":0,"height":0,"passthru":false,"label":"Manual Boiler 2 Hr Turn on","color":"","bgcolor":"","icon":"","payload":"{     \"payload\": \"on\",     \"timeout\": 7200,     \"warning\": 5 }","payloadType":"json","topic":"topic/fireuptheboileroverride","x":180,"y":1140,"wires":[["5f3a7a46.e835c4"]]},{"id":"5f3a7a46.e835c4","type":"mytimeout","z":"a78930fe.ed232","name":"Boiler Manual Turn on - New Node","outtopic":"topic/fireuptheboileroverride","outsafe":"1","outwarning":"","outunsafe":"0","warning":"2","timer":"10","debug":false,"ndebug":false,"ignoreCase":false,"repeat":false,"again":false,"x":600,"y":1180,"wires":[["5bab8b3b.564f94","be23d858.f070d8"],["23210b71.6a2104","34467ea3.dbffa2"]]},{"id":"34467ea3.dbffa2","type":"change","z":"a78930fe.ed232","name":"Set Flow Variable - BoilerTimeToRun","rules":[{"t":"set","p":"BoilerTimeToRun","pt":"flow","to":"payload","tot":"msg"}],"action":"","property":"","from":"","to":"","reg":false,"x":610,"y":1280,"wires":[["9cd8ac49.7c2aa"]]},{"id":"9cd8ac49.7c2aa","type":"change","z":"a78930fe.ed232","name":"Take Variable and Put it into Payload","rules":[{"t":"move","p":"BoilerTimeToRun","pt":"flow","to":"payload","tot":"msg"}],"action":"","property":"","from":"","to":"","reg":false,"x":610,"y":1340,"wires":[["fc794523.ba6918"]]},{"id":"fc794523.ba6918","type":"ui_text_input","z":"a78930fe.ed232","name":"","label":"Manual Boiler  - Time to run (Sec)","group":"4da5d3cb.b9673c","order":0,"width":0,"height":0,"passthru":true,"mode":"text","delay":300,"topic":"","x":960,"y":1340,"wires":[[]]},{"id":"389dd264.7716de","type":"mqtt-broker","z":"a78930fe.ed232","broker":"localhost","port":"1883","clientid":"Node-Red","usetls":false,"compatmode":true,"keepalive":"60","cleansession":true,"birthTopic":"","birthQos":"0","birthPayload":"","willTopic":"","willQos":"0","willPayload":""},{"id":"4da5d3cb.b9673c","type":"ui_group","z":"","name":"Boiler Control","tab":"c9d53e06.a95c8","order":5,"disp":true,"width":"5"},{"id":"c9d53e06.a95c8","type":"ui_tab","z":"","name":"CURTIN house main page","icon":"dashboard","order":1}]
SO basically i have a number of buttons on my dashboard - they tell this to run for a certain period (1hr, 2hr etc) and a cancel button - the 1hr button sends in 3600 as its payload and the timout node counts down, when it gets to 0 it then sends out a payload (can also send out a warning payload prior to that)
so in your instance you could send in your message - store it as a variable, fire off the timeout node, when it expires, the next node reads the varaible for the payload and goes on its way
Craig
Got you - my flow is a simple Delay node replacement but just giving the time remaining as well as the standard blue dot triggered info.
Just designed to give slightly enhanced editor information
Fair enough
Craig
