Show seconds on last trigger time
Hi all,
During debugging it's always nice to see which end-node is triggered based on the entire flow.
For this, the small info-text below a Node is very usefull, as it shows what/when happened.
The only caveat with this is that it only shows time in HH:mm format, so everything that triggers within the same minute looks the same. To me it would be very usefull to have this as HH:mm:ss format.
Anyone knows if this is possible to set somewhere?
For further clarification, it's about the circled text in this image:
That is down to the author fo that node, so you will need to contact them directly as it doesn't look like one of the core ones.
