Simple CRUD with MariaDB
I would like to share here a simple CRUD that I made using the DASHBOARD_UI of NODE-RED.
This code serves as a reference for future colleagues (including myself) who need it.
Insert, show and delete data in a simple table.
Using all dasboard components from node red.
There is still no option to update the field, but this way it helps a lot.
[{"id":"de76bac7029e67af","type":"group","z":"ea86445f05051d5d","name":"View Table","style":{"stroke":"#c8e7a7","label":true,"fill":"#e3f3d3"},"nodes":["acd4288657e0e1e9","dcf0460394397d3b","a87fae56abb17d99","6c44656e0b3661a7","c16f38761aea6e5e","c4d04057b8e30b1f","d19c329f17f15b9b"],"x":34,"y":19,"w":482,"h":222},{"id":"4639c7fae2510b5a","type":"subflow","name":"PrepBD","info":"","category":"","in":[{"x":80,"y":100,"wires":[{"id":"8cc0b55b7d0743c0"}]}],"out":[{"x":1020,"y":100,"wires":[{"id":"4135b832b386a610","port":0}]}],"env":[],"meta":{},"color":"#DDAA99"},{"id":"8cc0b55b7d0743c0","type":"change","z":"4639c7fae2510b5a","name":"copy flow/global to msg","rules":[{"t":"set","p":"payload","pt":"msg","to":"{}","tot":"json"},{"t":"set","p":"payload.ip","pt":"msg","to":"#:(persistent)::IP_vGlobalBD","tot":"global"},{"t":"set","p":"payload.porta","pt":"msg","to":"#:(persistent)::Porta_vGlobalBD","tot":"global"},{"t":"set","p":"payload.usuario","pt":"msg","to":"#:(persistent)::Usuario_vGlobalBD","tot":"global"},{"t":"set","p":"payload.senha","pt":"msg","to":"#:(persistent)::Senha_vGlobalBD","tot":"global"},{"t":"set","p":"payload.nomeBD","pt":"msg","to":"#:(persistent)::NomeBD_vGlobalBD","tot":"global"}],"action":"","property":"","from":"","to":"","reg":false,"x":290,"y":100,"wires":[["effa65099dd2a525"]]},{"id":"4135b832b386a610","type":"mysql2","z":"4639c7fae2510b5a","name":"","server":"","bind":"","topic":"","x":760,"y":100,"wires":[[]]},{"id":"effa65099dd2a525","type":"function","z":"4639c7fae2510b5a","name":"prep_MQTT_Conn","func":"\nconst ip = msg.payload.ip\nconst porta = msg.payload.porta\nconst usuario = msg.payload.usuario\nconst senha = msg.payload.senha\nconst nomeBD = msg.payload.nomeBD\n\nmsg.server = {\n    \"host\": ip,\n    \"port\": porta,\n    \"username\": usuario,\n    \"password\": senha,\n    \"db\": nomeBD\n}\n\nreturn msg;","outputs":1,"noerr":0,"initialize":"","finalize":"","libs":[],"x":550,"y":100,"wires":[["4135b832b386a610"]]},{"id":"eb96b8b79efaea17","type":"change","z":"4639c7fae2510b5a","name":"","rules":[{"t":"set","p":"server","pt":"msg","to":"{'host': $globalContext('IP_vGlobalBD'),\t 'port': $globalContext('Porta_vGlobalBD'),\t 'username': $globalContext('Usuario_vGlobalBD'),\t 'password': $globalContext('Senha_vGlobalBD'),\t 'bd': \"TelemetriaEnervision\"\t }","tot":"jsonata"}],"action":"","property":"","from":"","to":"","reg":false,"x":260,"y":260,"wires":[[]]},{"id":"4a50ea77c5d0ed5b","type":"comment","z":"4639c7fae2510b5a","name":"Quem sabe futuro usar esse Change","info":"Não consegui fazer funcionar com o mysql2, ele diz que o nome do banco de dados não está selecionado.","x":320,"y":220,"wires":[]},{"id":"acd4288657e0e1e9","type":"inject","z":"ea86445f05051d5d","g":"de76bac7029e67af","name":"","props":[{"p":"payload"},{"p":"topic","vt":"str"}],"repeat":"","crontab":"","once":true,"onceDelay":"3","topic":"","payload":"","payloadType":"date","x":150,"y":100,"wires":[["dcf0460394397d3b"]]},{"id":"dcf0460394397d3b","type":"function","z":"ea86445f05051d5d","g":"de76bac7029e67af","name":"f_SQL","func":"\n//msg.topic = \"Select Mergulhador.*, CONCAT('<a  target=_blank href=apagarMergulhador', '', '>Apagar</a>') as Apagar from Mergulhador\"\n//msg.topic = \"Select Mergulhador.*, CONCAT('<a  target=framename href=apagarMergulhador?nMergulhador=', nMergulhador, '>Apagar</a>') as Apagar from Mergulhador\"\n\nmsg.topic = \"Select Mergulhador.*, CONCAT('<a target=xApagar href=apagarMergulhador?nMergulhador=', nMergulhador, '>Apagar</a>') as Apagar from Mergulhador\"\n\n\n\n\nreturn msg;","outputs":1,"noerr":0,"initialize":"","finalize":"","libs":[],"x":430,"y":80,"wires":[["d19c329f17f15b9b"]]},{"id":"a87fae56abb17d99","type":"ui_table","z":"ea86445f05051d5d","g":"de76bac7029e67af","group":"972474baadf22d9f","name":"","order":10,"width":14,"height":11,"columns":[{"field":"Mergulhador","title":"Mergulhador","width":"","align":"left","formatter":"plaintext","formatterParams":{"target":"_blank"}},{"field":"Apagar","title":"Apagar","width":"15%","align":"left","formatter":"html","formatterParams":{"target":"_blank"}}],"outputs":1,"cts":true,"x":430,"y":200,"wires":[[]]},{"id":"6c44656e0b3661a7","type":"link in","z":"ea86445f05051d5d","g":"de76bac7029e67af","name":"Mostra_Tabela","links":["f7cecf442f2f57d9","c7578da38b131f5c"],"x":275,"y":120,"wires":[["dcf0460394397d3b"]]},{"id":"c16f38761aea6e5e","type":"ui_template","z":"ea86445f05051d5d","g":"de76bac7029e67af","group":"972474baadf22d9f","name":"","order":33,"width":3,"height":1,"format":"<iframe name=xApagar style=\"display: none;\"></iframe>","storeOutMessages":true,"fwdInMessages":true,"resendOnRefresh":true,"templateScope":"local","className":"","x":140,"y":200,"wires":[[]]},{"id":"c4d04057b8e30b1f","type":"ui_button","z":"ea86445f05051d5d","g":"de76bac7029e67af","name":"","group":"972474baadf22d9f","order":7,"width":5,"height":1,"passthru":false,"label":"Atualizar","tooltip":"","color":"","bgcolor":"","className":"","icon":"","payload":"","payloadType":"str","topic":"topic","topicType":"msg","x":140,"y":60,"wires":[["dcf0460394397d3b"]]},{"id":"d19c329f17f15b9b","type":"subflow:4639c7fae2510b5a","z":"ea86445f05051d5d","g":"de76bac7029e67af","name":"","x":430,"y":140,"wires":[["a87fae56abb17d99"]]},{"id":"972474baadf22d9f","type":"ui_group","name":"","tab":"657fd39515811ee7","order":1,"disp":true,"width":16,"collapse":false,"className":""},{"id":"657fd39515811ee7","type":"ui_tab","name":"Mergulhadores","icon":"dashboard","order":5,"disabled":false,"hidden":false},{"id":"059f04f0839c5d5a","type":"group","z":"ea86445f05051d5d","name":"Insert Row","style":{"label":true,"stroke":"#0070c0","fill":"#bfdbef"},"nodes":["8757bcd1fc3cb715","8a4d2e4459a0b06e","acce5b075c104af8","167c0a8b5cd79911","aaaf375cf8695f44","ed7226ddb2937935","f7cecf442f2f57d9","376305b879dfdf48"],"x":34,"y":259,"w":812,"h":262},{"id":"8757bcd1fc3cb715","type":"ui_text_input","z":"ea86445f05051d5d","g":"059f04f0839c5d5a","name":"","label":"Mergulhador","tooltip":"","group":"972474baadf22d9f","order":3,"width":9,"height":1,"passthru":true,"mode":"text","delay":300,"topic":"topic","sendOnBlur":true,"className":"","topicType":"msg","x":690,"y":360,"wires":[["167c0a8b5cd79911"]]},{"id":"8a4d2e4459a0b06e","type":"ui_button","z":"ea86445f05051d5d","g":"059f04f0839c5d5a","name":"","group":"972474baadf22d9f","order":4,"width":5,"height":1,"passthru":false,"label":"Inserir","tooltip":"","color":"","bgcolor":"","className":"","icon":"","payload":"","payloadType":"str","topic":"topic","topicType":"msg","x":110,"y":360,"wires":[["aaaf375cf8695f44"]]},{"id":"acce5b075c104af8","type":"function","z":"ea86445f05051d5d","g":"059f04f0839c5d5a","name":"f_SQL","func":"let vMergulhador = msg.payload\n\nmsg.topic = \"Insert INTO Mergulhador (Mergulhador) Values ('\" + vMergulhador + \"')\";\n\nreturn msg;","outputs":1,"noerr":0,"initialize":"","finalize":"","libs":[],"x":470,"y":420,"wires":[["376305b879dfdf48"]]},{"id":"167c0a8b5cd79911","type":"change","z":"ea86445f05051d5d","g":"059f04f0839c5d5a","name":"","rules":[{"t":"set","p":"vMergulhador","pt":"flow","to":"payload","tot":"msg"}],"action":"","property":"","from":"","to":"","reg":false,"x":720,"y":420,"wires":[[]]},{"id":"aaaf375cf8695f44","type":"change","z":"ea86445f05051d5d","g":"059f04f0839c5d5a","name":"","rules":[{"t":"set","p":"payload","pt":"msg","to":"vMergulhador","tot":"flow"}],"action":"","property":"","from":"","to":"","reg":false,"x":320,"y":360,"wires":[["ed7226ddb2937935","acce5b075c104af8"]]},{"id":"ed7226ddb2937935","type":"change","z":"ea86445f05051d5d","g":"059f04f0839c5d5a","name":"","rules":[{"t":"set","p":"payload","pt":"msg","to":"","tot":"str"}],"action":"","property":"","from":"","to":"","reg":false,"x":500,"y":300,"wires":[["8757bcd1fc3cb715"]]},{"id":"f7cecf442f2f57d9","type":"link out","z":"ea86445f05051d5d","g":"059f04f0839c5d5a","name":"link out 1","mode":"link","links":["6c44656e0b3661a7"],"x":685,"y":480,"wires":[]},{"id":"376305b879dfdf48","type":"subflow:4639c7fae2510b5a","z":"ea86445f05051d5d","g":"059f04f0839c5d5a","name":"","x":470,"y":480,"wires":[["f7cecf442f2f57d9"]]},{"id":"b5f89aababd0dc2b","type":"group","z":"ea86445f05051d5d","name":"Delete Row","style":{"stroke":"#6f2fa0","fill":"#b797cf","label":true},"nodes":["5a6a5fd24ca74cfa","965b9fcea32fdc32","6047941a4bcb42c6","f6c496041602c3c0","34d8ce1f4f8b96b1","c7578da38b131f5c","2a1da7bed5e5e333","69f16a8e5cb36462"],"x":554,"y":19,"w":572,"h":202},{"id":"5a6a5fd24ca74cfa","type":"ui_toast","z":"ea86445f05051d5d","g":"b5f89aababd0dc2b","position":"dialog","displayTime":"3","highlight":"","sendall":true,"outputs":1,"ok":"SIM","cancel":"NÃO","raw":false,"className":"","topic":"","name":"","x":810,"y":100,"wires":[["34d8ce1f4f8b96b1"]]},{"id":"965b9fcea32fdc32","type":"change","z":"ea86445f05051d5d","g":"b5f89aababd0dc2b","name":"","rules":[{"t":"set","p":"topic","pt":"msg","to":"Deseja apagar esse registro ?","tot":"str"},{"t":"set","p":"vnMergulhador","pt":"flow","to":"payload","tot":"msg"},{"t":"set","p":"payload","pt":"msg","to":"Esse registro será apagado definitivamente","tot":"str"}],"action":"","property":"","from":"","to":"","reg":false,"x":820,"y":60,"wires":[["5a6a5fd24ca74cfa"]]},{"id":"6047941a4bcb42c6","type":"function","z":"ea86445f05051d5d","g":"b5f89aababd0dc2b","name":"f_SQL","func":"let vnMergulhador = msg.payload\n\nmsg.topic = \"DELETE FROM Mergulhador WHERE nMergulhador = \" + vnMergulhador ;\n\nreturn msg;","outputs":1,"noerr":0,"initialize":"","finalize":"","libs":[],"x":1030,"y":60,"wires":[["69f16a8e5cb36462"]]},{"id":"f6c496041602c3c0","type":"change","z":"ea86445f05051d5d","g":"b5f89aababd0dc2b","name":"","rules":[{"t":"set","p":"payload","pt":"msg","to":"vnMergulhador.nMergulhador","tot":"flow"}],"action":"","property":"","from":"","to":"","reg":false,"x":820,"y":180,"wires":[["6047941a4bcb42c6"]]},{"id":"34d8ce1f4f8b96b1","type":"switch","z":"ea86445f05051d5d","g":"b5f89aababd0dc2b","name":"","property":"payload","propertyType":"msg","rules":[{"t":"eq","v":"SIM","vt":"str"}],"checkall":"true","repair":false,"outputs":1,"x":790,"y":140,"wires":[["f6c496041602c3c0"]]},{"id":"c7578da38b131f5c","type":"link out","z":"ea86445f05051d5d","g":"b5f89aababd0dc2b","name":"link out 2","mode":"link","links":["6c44656e0b3661a7"],"x":1085,"y":160,"wires":[]},{"id":"2a1da7bed5e5e333","type":"http in","z":"ea86445f05051d5d","g":"b5f89aababd0dc2b","name":"Apagar","url":"/ui/apagarMergulhador","method":"get","upload":false,"swaggerDoc":"","x":630,"y":60,"wires":[["965b9fcea32fdc32"]]},{"id":"69f16a8e5cb36462","type":"subflow:4639c7fae2510b5a","z":"ea86445f05051d5d","g":"b5f89aababd0dc2b","name":"","x":1030,"y":100,"wires":[["c7578da38b131f5c"]]}]
Just in case anyone asks what CRUD means, here's a link to an explanation.
