Simple dashboard template graphic
@Paul-Reed I really like your temperature graphic I saw on another topic.
I am reading temperature using some DS18B20 temp probes and currently using the std Gage node, but to simplify the dashboard i was wondering if you could help me with the template to display a graphic similar to your Temperature/ Feels Like/ Humidity etc.
Normally I would have glady shared the flow with you, but I no longer use the ui-dashboard, and have deleted that dashboard flow.
I'm currently in the process of building a new weather dashboard using Flexdash for my main dashboards.
But if you have any specific questions about using/formatting the ui-dashboard nodes, I'm sure you'll get some help in the forum.
Thanks @Paul-Reed
Having never used CSS before I have managed to make some similar formats using the template node.
