UI Template why did not show data
Please help me to slove dashboard not show details as UI Template Thanks.....
[{"id":"bd597e9e.e430e","type":"tab","label":"Flow 2","disabled":false,"info":""},{"id":"e1d79532.e184a8","type":"inject","z":"bd597e9e.e430e","name":"","props":[{"p":"payload"}],"repeat":"3","crontab":"","once":false,"onceDelay":0.1,"topic":"","payload":"155","payloadType":"num","x":310,"y":200,"wires":[["20468be.1356674"]]},{"id":"20468be.1356674","type":"template","z":"bd597e9e.e430e","name":"cv","field":"template","fieldType":"msg","format":"html","syntax":"mustache","template":"<!DOCTYPE html>\n<html>\n    <head>\n        <title>Arduino Two Temperatures</title>\n        \n       \n       \n        <script>\n        var data_val = 5071;\n        var data_val2 = 112;\n\t\tvar data_int = 20;\n\t\tvar data_tens = 13.6;\n\t\tvar data_pres = 7.2;\n\t\tvar data_fuel =4;\n\t\tvar data_t_mot = 96;\n\t\t\n\t\t\n\t\t\n<!-- Gauge Code Starts -->\nvar Gauge=function(b){function l(a,b){for(var c in b)\"object\"==typeof b[c]&&\"[object Array]\"!==Object.prototype.toString.call(b[c])&&\"renderTo\"!=c?(\"object\"!=typeof a[c]&&(a[c]={}),l(a[c],b[c])):a[c]=b[c]}function q(){z.width=b.width;z.height=b.height;A=z.cloneNode(!0);B=A.getContext(\"2d\");C=z.width;D=z.height;t=C/2;u=D/2;f=t<u?t:u;A.i8d=!1;B.translate(t,u);B.save();a.translate(t,u);a.save()}function v(a){var b=new Date;G=setInterval(function(){var c=(new Date-b)/a.duration;1<c&&(c=1);var f=(\"function\"==\ntypeof a.delta?a.delta:M[a.delta])(c);a.step(f);1==c&&clearInterval(G)},a.delay||10)}function k(){G&&clearInterval(G);var a=I-n,h=n,c=b.animation;v({delay:c.delay,duration:c.duration,delta:c.fn,step:function(b){n=parseFloat(h)+a*b;E.draw()}})}function e(a){return a*Math.PI/180}function g(b,h,c){c=a.createLinearGradient(0,0,0,c);c.addColorStop(0,b);c.addColorStop(1,h);return c}function p(){var m=92*(f/100),h=f-m,c=91*(f/100),e=88*(f/100),d=85*(f/100);a.save();b.glow&&(a.shadowBlur=h,a.shadowColor=\n\"rgba(0, 0, 0, 10)\");a.beginPath();a.arc(0,0,m,0,2*Math.PI,!0);a.fillStyle=g(\"#000\",\"#000\",m);a.fill();a.restore();a.beginPath();a.arc(0,0,c,0,2*Math.PI,!0);a.fillStyle=g(\"#000\",\"#000\",c);a.fill();a.beginPath();a.arc(0,0,e,0,2*Math.PI,!0);a.fillStyle=g(\"#000\",\"#000\",e);a.fill();a.beginPath();a.arc(0,0,d,0,2*Math.PI,!0);a.fillStyle=b.colors.plate;a.fill();a.save()}function w(a){var h=!1;a=0===b.majorTicksFormat.dec?Math.round(a).toString():a.toFixed(b.majorTicksFormat.dec);return 1<b.majorTicksFormat[\"int\"]?\n(h=-1<a.indexOf(\".\"),-1<a.indexOf(\"-\")?\"-\"+(b.majorTicksFormat[\"int\"]+b.majorTicksFormat.dec+2+(h?1:0)-a.length)+a.replace(\"-\",\"\"):\"\"+(b.majorTicksFormat[\"int\"]+b.majorTicksFormat.dec+1+(h?1:0)-a.length)+a):a}function d(){var m=81*(f/100);a.lineWidth=2;a.strokeStyle=b.colors.majorTicks;a.save();if(0===b.majorTicks.length){for(var h=(b.maxValue-b.minValue)/5,c=0;5>c;c++)b.majorTicks.push(w(b.minValue+h*c));b.majorTicks.push(w(b.maxValue))}for(c=0;c<b.majorTicks.length;++c)a.rotate(e(45+c*(270/(b.majorTicks.length-\n1)))),a.beginPath(),a.moveTo(0,m),a.lineTo(0,m-15*(f/100)),a.stroke(),a.restore(),a.save();b.strokeTicks&&(a.rotate(e(90)),a.beginPath(),a.arc(0,0,m,e(45),e(315),!1),a.stroke(),a.restore(),a.save())}function J(){var m=81*(f/100);a.lineWidth=1;a.strokeStyle=b.colors.minorTicks;a.save();for(var h=b.minorTicks*(b.majorTicks.length-1),c=0;c<h;++c)a.rotate(e(45+c*(270/h))),a.beginPath(),a.moveTo(0,m),a.lineTo(0,m-7.5*(f/100)),a.stroke(),a.restore(),a.save()}function s(){for(var m=55*(f/100),h=0;h<b.majorTicks.length;++h){var c=\nF(m,e(45+h*(270/(b.majorTicks.length-1))));a.font=20*(f/200)+\"px Arial\";a.fillStyle=b.colors.numbers;a.lineWidth=0;a.textAlign=\"center\";a.fillText(b.majorTicks[h],c.x,c.y+3)}}function x(a){var h=b.valueFormat.dec,c=b.valueFormat[\"int\"];a=parseFloat(a);var f=0>a;a=Math.abs(a);if(0<h){a=a.toFixed(h).toString().split(\".\");h=0;for(c-=a[0].length;h<c;++h)a[0]=\"0\"+a[0];a=(f?\"-\":\"\")+a[0]+\".\"+a[1]}else{a=Math.round(a).toString();h=0;for(c-=a.length;h<c;++h)a=\"0\"+a;a=(f?\"-\":\"\")+a}return a}function F(a,b){var c=\nMath.sin(b),f=Math.cos(b);return{x:0*f-a*c,y:0*c+a*f}}function N(){a.save();for(var m=81*(f/100),h=m-15*(f/100),c=0,g=b.highlights.length;c<g;c++){var d=b.highlights[c],r=(b.maxValue-b.minValue)/270,k=e(45+(d.from-b.minValue)/r),r=e(45+(d.to-b.minValue)/r);a.beginPath();a.rotate(e(90));a.arc(0,0,m,k,r,!1);a.restore();a.save();var l=F(h,k),p=F(m,k);a.moveTo(l.x,l.y);a.lineTo(p.x,p.y);var p=F(m,r),n=F(h,r);a.lineTo(p.x,p.y);a.lineTo(n.x,n.y);a.lineTo(l.x,l.y);a.closePath();a.fillStyle=d.color;a.fill();\na.beginPath();a.rotate(e(90));a.arc(0,0,h,k-0.2,r+0.2,!1);a.restore();a.closePath();a.fillStyle=b.colors.plate;a.fill();a.save()}}function K(){var m=12*(f/100),h=8*(f/100),c=77*(f/100),d=20*(f/100),k=4*(f/100),r=2*(f/100),l=function(){a.shadowOffsetX=2;a.shadowOffsetY=2;a.shadowBlur=10;a.shadowColor=\"rgba(188, 143, 143, 0.45)\"};l();a.save();n=0>n?Math.abs(b.minValue-n):0<b.minValue?n-b.minValue:Math.abs(b.minValue)+n;a.rotate(e(45+n/((b.maxValue-b.minValue)/270)));a.beginPath();a.moveTo(-r,-d);a.lineTo(-k,\n0);a.lineTo(-1,c);a.lineTo(1,c);a.lineTo(k,0);a.lineTo(r,-d);a.closePath();a.fillStyle=g(b.colors.needle.start,b.colors.needle.end,c-d);a.fill();a.beginPath();a.lineTo(-0.5,c);a.lineTo(-1,c);a.lineTo(-k,0);a.lineTo(-r,-d);a.lineTo(r/2-2,-d);a.closePath();a.fillStyle=\"rgba(255, 255, 255, 0.2)\";a.fill();a.restore();l();a.beginPath();a.arc(0,0,m,0,2*Math.PI,!0);a.fillStyle=g(\"#f0f0f0\",\"#ccc\",m);a.fill();a.restore();a.beginPath();a.arc(0,0,h,0,2*Math.PI,!0);a.fillStyle=g(\"#e8e8e8\",\"#f5f5f5\",h);a.fill()}\nfunction L(){a.save();a.font=40*(f/200)+\"px Led\";var b=x(y),h=a.measureText(\"-\"+x(0)).width,c=f-33*(f/100),g=0.12*f;a.save();var d=-h/2-0.10*f,e=c-g-0.04*f,h=h+0.20*f,g=g+0.07*f,k=0.025*f;a.beginPath();a.moveTo(d+k,e);a.lineTo(d+h-k,e);a.quadraticCurveTo(d+h,e,d+h,e+k);a.lineTo(d+h,e+g-k);a.quadraticCurveTo(d+h,e+g,d+h-k,e+g);a.lineTo(d+k,e+g);a.quadraticCurveTo(d,e+g,d,e+g-k);a.lineTo(d,e+k);a.quadraticCurveTo(d,e,d+k,e);a.closePath();d=a.createRadialGradient(0,c-0.12*f-0.025*f+(0.12*f+0.045*f)/\n2,f/10,0,c-0.12*f-0.025*f+(0.12*f+0.045*f)/2,f/5);d.addColorStop(0,\"#000\");d.addColorStop(1,\"#000000\");a.strokeStyle=d;a.lineWidth=0.05*f;a.stroke();a.shadowBlur=0.012*f;a.shadowColor=\"rgba(0, 0, 0, 1)\";a.fillStyle=\"#000000\";a.fill();a.restore();a.shadowOffsetX=0.04*f;a.shadowOffsetY=0.004*f;a.shadowBlur=0.012*f;a.shadowColor=\"rgba(0, 0, 0, 0.3)\";a.fillStyle=\"#888\";a.textAlign=\"center\";a.fillText(b,-0,c);a.restore()}Gauge.Collection.push(this);this.config={renderTo:null,width:200,height:200,title:!1,\nmaxValue:100,minValue:0,majorTicks:[],minorTicks:10,strokeTicks:!0,units:!1,valueFormat:{\"int\":1,dec:0},majorTicksFormat:{\"int\":1,dec:0},glow:!0,animation:{delay:10,duration:250,fn:\"cycle\"},colors:{plate:\"#000000\",majorTicks:\"#000000\",minorTicks:\"#000000\",title:\"#888\",units:\"#888\",numbers:\"#888\",needle:{start:\"rgba(240, 0, 0, 1)\",end:\"rgba(255, 160, 122, .9)\"}},highlights:[{from:20,to:60,color:\"#eee\"},{from:60,to:80,color:\"#ccc\"},{from:80,to:100,color:\"#999\"}]};var y=0,E=this,n=0,I=0,H=!1;this.setValue=\nfunction(a){n=b.animation?y:a;var d=(b.maxValue-b.minValue)/100;I=a>b.maxValue?b.maxValue+d:a<b.minValue?b.minValue-d:a;y=a;b.animation?k():this.draw();return this};this.setRawValue=function(a){n=y=a;this.draw();return this};this.clear=function(){y=n=I=this.config.minValue;this.draw();return this};this.getValue=function(){return y};this.onready=function(){};l(this.config,b);this.config.minValue=parseFloat(this.config.minValue);this.config.maxValue=parseFloat(this.config.maxValue);b=this.config;n=\ny=b.minValue;if(!b.renderTo)throw Error(\"Canvas element was not specified when creating the Gauge object!\");var z=b.renderTo.tagName?b.renderTo:document.getElementById(b.renderTo),a=z.getContext(\"2d\"),A,C,D,t,u,f,B;q();this.updateConfig=function(a){l(this.config,a);q();this.draw();return this};var M={linear:function(a){return a},quad:function(a){return Math.pow(a,2)},quint:function(a){return Math.pow(a,5)},cycle:function(a){return 1-Math.sin(Math.acos(a))},bounce:function(a){a:{a=1-a;for(var b=0,\nc=1;;b+=c,c/=2)if(a>=(7-4*b)/11){a=-Math.pow((11-6*b-11*a)/4,2)+Math.pow(c,2);break a}a=void 0}return 1-a},elastic:function(a){a=1-a;return 1-Math.pow(2,10*(a-1))*Math.cos(30*Math.PI/3*a)}},G=null;a.lineCap=\"round\";this.draw=function(){if(!A.i8d){B.clearRect(-t,-u,C,D);B.save();var g={ctx:a};a=B;p();N();J();d();s();b.title&&(a.save(),a.font=24*(f/200)+\"px Arial\",a.fillStyle=b.colors.title,a.textAlign=\"center\",a.fillText(b.title,0,-f/4.25),a.restore());b.units&&(a.save(),a.font=22*(f/200)+\"px Arial\",\na.fillStyle=b.colors.units,a.textAlign=\"center\",a.fillText(b.units,0,f/3.25),a.restore());A.i8d=!0;a=g.ctx;delete g.ctx}a.clearRect(-t,-u,C,D);a.save();a.drawImage(A,-t,-u,C,D);if(Gauge.initialized)L(),K(),H||(E.onready&&E.onready(),H=!0);else var e=setInterval(function(){Gauge.initialized&&(clearInterval(e),L(),K(),H||(E.onready&&E.onready(),H=!0))},10);return this}};Gauge.initialized=!1;\n(function(){var b=document,l=b.getElementsByTagName(\"head\")[0],q=-1!=navigator.userAgent.toLocaleLowerCase().indexOf(\"msie\"),v=\"@font-face {font-family: 'Led';src: url('fonts/digital-7-mono.\"+(q?\"eot\":\"ttf\")+\"');}\",k=b.createElement(\"style\");k.type=\"text/css\";if(q)l.appendChild(k),l=k.styleSheet,l.cssText=v;else{try{k.appendChild(b.createTextNode(v))}catch(e){k.cssText=v}l.appendChild(k);l=k.styleSheet?k.styleSheet:k.sheet||b.styleSheets[b.styleSheets.length-1]}var g=setInterval(function(){if(b.body){clearInterval(g);\nvar e=b.createElement(\"div\");e.style.fontFamily=\"Led\";e.style.position=\"absolute\";e.style.height=e.style.width=0;e.style.overflow=\"hidden\";e.innerHTML=\".\";b.body.appendChild(e);setTimeout(function(){Gauge.initialized=!0;e.parentNode.removeChild(e)},250)}},1)})();Gauge.Collection=[];\nGauge.Collection.get=function(b){if(\"string\"==typeof b)for(var l=0,q=this.length;l<q;l++){if((this[l].config.renderTo.tagName?this[l].config.renderTo:document.getElementById(this[l].config.renderTo)).getAttribute(\"id\")==b)return this[l]}else return\"number\"==typeof b?this[b]:null};function domReady(b){window.addEventListener?window.addEventListener(\"DOMContentLoaded\",b,!1):window.attachEvent(\"onload\",b)}\ndomReady(function(){function b(b){for(var e=b[0],d=1,g=b.length;d<g;d++)e+=b[d].substr(0,1).toUpperCase()+b[d].substr(1,b[d].length-1);return e}for(var l=document.getElementsByTagName(\"canvas\"),q=0,v=l.length;q<v;q++)if(\"canv-gauge\"==l[q].getAttribute(\"data-type\")){var k=l[q],e={},g,p=parseInt(k.getAttribute(\"width\"),10),w=parseInt(k.getAttribute(\"height\"),10);e.renderTo=k;p&&(e.width=p);w&&(e.height=w);p=0;for(w=k.attributes.length;p<w;p++)if(g=k.attributes.item(p).nodeName,\"data-type\"!=g&&\"data-\"==\ng.substr(0,5)){var d=g.substr(5,g.length-5).toLowerCase().split(\"-\");if(g=k.getAttribute(g))switch(d[0]){case \"colors\":d[1]&&(e.colors||(e.colors={}),\"needle\"==d[1]?(d=g.split(/\\s+/),e.colors.needle=d[0]&&d[1]?{start:d[0],end:d[1]}:g):(d.shift(),e.colors[b(d)]=g));break;case \"highlights\":e.highlights||(e.highlights=[]);g=g.match(/(?:(?:-?\\d*\\.)?(-?\\d+){1,2} ){2}(?:(?:#|0x)?(?:[0-9A-F|a-f]){3,8}|rgba?\\(.*?\\))/g);for(var d=0,J=g.length;d<J;d++){var s=g[d].replace(/^\\s+|\\s+$/g,\"\").split(/\\s+/),x={};\ns[0]&&\"\"!=s[0]&&(x.from=s[0]);s[1]&&\"\"!=s[1]&&(x.to=s[1]);s[2]&&\"\"!=s[2]&&(x.color=s[2]);e.highlights.push(x)}break;case \"animation\":d[1]&&(e.animation||(e.animation={}),\"fn\"==d[1]&&/^\\s*function\\s*\\(/.test(g)&&(g=eval(\"(\"+g+\")\")),e.animation[d[1]]=g);break;default:d=b(d);if(\"onready\"==d)continue;if(\"majorTicks\"==d)g=g.split(/\\s+/);else if(\"strokeTicks\"==d||\"glow\"==d)g=\"true\"==g?!0:!1;else if(\"valueFormat\"==d)if(g=g.split(\".\"),2==g.length)g={\"int\":parseInt(g[0],10),dec:parseInt(g[1],10)};else continue;\ne[d]=g}}e=new Gauge(e);k.getAttribute(\"data-value\")&&e.setRawValue(parseFloat(k.getAttribute(\"data-value\")));k.getAttribute(\"data-onready\")&&(e.onready=function(){eval(this.config.renderTo.getAttribute(\"data-onready\"))});e.draw()}});window.Gauge=Gauge;\n<!-- Gauge Code Ends -->\n        \n    </script>\n</head>\n    <body onload=\"GetArduinoInputs()\" bgColor=#000000>\n\t\t<div align = \"center\">\n\t\t<canvas id=\"an_gauge_2\" data-title=\"Vitesse\" data-units=\"Km/h\" width=\"50\" height=\"50\" data-major-ticks=\"0 10 20 30 40 50 60 70 80 90 100 110 120 130\" data-type=\"canv-gauge\" data-min-value=\"0\" data-max-value=\"130\" data-highlights=\"0 130 #222222\" data-onready=\"setInterval( function() { Gauge.Collection.get('an_gauge_2').setValue(data_val2);}, 200);\"></canvas>\n        <canvas id=\"an_gauge_1\" data-title=\"Regime\" data-units=\"Tr/min\" width=\"50\" height=\"50\" data-major-ticks=\"0 1000 2000 3000 4000 5000 6000 7000\" data-type=\"canv-gauge\" data-min-value=\"0\" data-max-value=\"7000\" data-highlights=\"0 600 #222222, 600 3750 #0BB950, 3750 5200 #cc5, 5200 6000 #ff9900, 6000 7000 #f33\" data-onready=\"setInterval( function() { Gauge.Collection.get('an_gauge_1').setValue(data_val);}, 200);\"></canvas>\n\t\t<BR>\n\t\t<canvas id=\"an_gauge_4\" data-title=\"Tension\" data-units=\"V\" width=\"20\" height=\"20\" data-major-ticks=\"9 10 11 12 13 14 15 16 17\" data-type=\"canv-gauge\" data-min-value=\"9\" data-max-value=\"17\" data-highlights=\"9 11 #222222, 11 12 #f33, 12 14 #0BB950, 14 15 #f33, 15 17 #222222\" data-onready=\"setInterval( function() { Gauge.Collection.get('an_gauge_4').setValue(data_tens);}, 200);\"></canvas>\n\t\t<canvas id=\"an_gauge_5\" data-title=\"Intensite\" data-units=\"A\" width=\"20\" height=\"20\" data-major-ticks=\"-25 -20 -15 -10 -5 0 5 10 15 20 25\" data-type=\"canv-gauge\" data-min-value=\"-25\" data-max-value=\"25\" data-highlights=\"-25 25 #222222\" data-onready=\"setInterval( function() { Gauge.Collection.get('an_gauge_5').setValue(data_int);}, 200);\"></canvas>\n\t\t<canvas id=\"an_gauge_6\" data-title=\"Pression\" data-units=\"bar\" width=\"20\" height=\"20\" data-major-ticks=\"0 1 2 3 4 5 6 7 8 9 10\" data-type=\"canv-gauge\" data-min-value=\"0\" data-max-value=\"10\" data-highlights=\"0 6 #f33, 6 8 #0BB950, 8 10 #f33\" data-onready=\"setInterval( function() { Gauge.Collection.get('an_gauge_6').setValue(data_pres);}, 200);\"></canvas>\n\t\t<canvas id=\"an_gauge_7\" data-title=\"T moteur\" data-units=\"&deg;C\" width=\"20\" height=\"20\" data-major-ticks=\"40 50 60 70 80 90 100 110 120 130 140\" data-type=\"canv-gauge\" data-min-value=\"40\" data-max-value=\"140\" data-highlights=\"40 120 #222222, 120 140 #f33\" data-onready=\"setInterval( function() { Gauge.Collection.get('an_gauge_7').setValue(data_t_mot);}, 200);\"></canvas>\n\t\t<canvas id=\"an_gauge_8\" data-title=\"Carburant\" data-units=\"L\" width=\"20\" height=\"20\" data-major-ticks=\"0 5 10 15 20 25\" data-type=\"canv-gauge\" data-min-value=\"0\" data-max-value=\"25\" data-highlights=\"0 3 #f33, 3 25 #222222\" data-onready=\"setInterval( function() { Gauge.Collection.get('an_gauge_8').setValue(data_fuel);}, 200);\"></canvas>\n\t\t</div>\n\t\n\t</body>\n</html>\n\n","output":"str","x":490,"y":200,"wires":[["2fa49b99.be8b54"]]},{"id":"2fa49b99.be8b54","type":"ui_template","z":"bd597e9e.e430e","group":"48190cbf.587d84","name":"reds","order":3,"width":0,"height":0,"format":"","storeOutMessages":true,"fwdInMessages":true,"resendOnRefresh":false,"templateScope":"local","x":630,"y":200,"wires":[[]]},{"id":"48190cbf.587d84","type":"ui_group","z":"","name":"Default","tab":"711389cf.7d4e18","order":1,"disp":true,"width":"25","collapse":false},{"id":"711389cf.7d4e18","type":"ui_tab","z":"","name":"Home1","icon":"dashboard","disabled":false,"hidden":false}]
I'm not sure what the deal is, but my NR doesn't like that JSON for some reason. I even deleted the part it was complaining about and re-typed it, and still couldn't get it to import.
I assume this isn't the root cause of your problem.
Maybe put it in code/"Preformatted text" mode and it will go through correctly?
Thanks. tymarbut try my code again
[{"id":"bd597e9e.e430e","type":"tab","label":"Flow 2","disabled":false,"info":""},{"id":"e1d79532.e184a8","type":"inject","z":"bd597e9e.e430e","name":"","props":[{"p":"payload"}],"repeat":"","crontab":"","once":false,"onceDelay":0.1,"topic":"","payload":"155","payloadType":"num","x":310,"y":200,"wires":[["20468be.1356674"]]},{"id":"20468be.1356674","type":"template","z":"bd597e9e.e430e","name":"cv","field":"template","fieldType":"msg","format":"html","syntax":"mustache","template":"\n\n \n Arduino Two Temperatures\n \n \n \n \n\n <body onload="GetArduinoInputs()" bgColor=#000000>\n\t\t<div align = "center">\n\t\t<canvas id="an_gauge_2" data-title="Vitesse" data-units="Km/h" width="50" height="50" data-major-ticks="0 10 20 30 40 50 60 70 80 90 100 110 120 130" data-type="canv-gauge" data-min-value="0" data-max-value="130" data-highlights="0 130 #222222" data-onready="setInterval( function() { Gauge.Collection.get('an_gauge_2').setValue(data_val2);}, 200);">\n <canvas id="an_gauge_1" data-title="Regime" data-units="Tr/min" width="50" height="50" data-major-ticks="0 1000 2000 3000 4000 5000 6000 7000" data-type="canv-gauge" data-min-value="0" data-max-value="7000" data-highlights="0 600 #222222, 600 3750 #0BB950, 3750 5200 #cc5, 5200 6000 #ff9900, 6000 7000 #f33" data-onready="setInterval( function() { Gauge.Collection.get('an_gauge_1').setValue(data_val);}, 200);">\n\t\t
\n\t\t<canvas id="an_gauge_4" data-title="Tension" data-units="V" width="20" height="20" data-major-ticks="9 10 11 12 13 14 15 16 17" data-type="canv-gauge" data-min-value="9" data-max-value="17" data-highlights="9 11 #222222, 11 12 #f33, 12 14 #0BB950, 14 15 #f33, 15 17 #222222" data-onready="setInterval( function() { Gauge.Collection.get('an_gauge_4').setValue(data_tens);}, 200);">\n\t\t<canvas id="an_gauge_5" data-title="Intensite" data-units="A" width="20" height="20" data-major-ticks="-25 -20 -15 -10 -5 0 5 10 15 20 25" data-type="canv-gauge" data-min-value="-25" data-max-value="25" data-highlights="-25 25 #222222" data-onready="setInterval( function() { Gauge.Collection.get('an_gauge_5').setValue(data_int);}, 200);">\n\t\t<canvas id="an_gauge_6" data-title="Pression" data-units="bar" width="20" height="20" data-major-ticks="0 1 2 3 4 5 6 7 8 9 10" data-type="canv-gauge" data-min-value="0" data-max-value="10" data-highlights="0 6 #f33, 6 8 #0BB950, 8 10 #f33" data-onready="setInterval( function() { Gauge.Collection.get('an_gauge_6').setValue(data_pres);}, 200);">\n\t\t<canvas id="an_gauge_7" data-title="T moteur" data-units="°C" width="20" height="20" data-major-ticks="40 50 60 70 80 90 100 110 120 130 140" data-type="canv-gauge" data-min-value="40" data-max-value="140" data-highlights="40 120 #222222, 120 140 #f33" data-onready="setInterval( function() { Gauge.Collection.get('an_gauge_7').setValue(data_t_mot);}, 200);">\n\t\t<canvas id="an_gauge_8" data-title="Carburant" data-units="L" width="20" height="20" data-major-ticks="0 5 10 15 20 25" data-type="canv-gauge" data-min-value="0" data-max-value="25" data-highlights="0 3 #f33, 3 25 #222222" data-onready="setInterval( function() { Gauge.Collection.get('an_gauge_8').setValue(data_fuel);}, 200);">\n\t\t\n\t\n\t\n\n\n","output":"str","x":470,"y":200,"wires":[["2fa49b99.be8b54","87ae9adf.09e488"]]},{"id":"2fa49b99.be8b54","type":"ui_template","z":"bd597e9e.e430e","group":"48190cbf.587d84","name":"reds","order":3,"width":0,"height":0,"format":"","storeOutMessages":true,"fwdInMessages":true,"resendOnRefresh":false,"templateScope":"local","x":630,"y":200,"wires":[]},{"id":"87ae9adf.09e488","type":"debug","z":"bd597e9e.e430e","name":"","active":true,"tosidebar":true,"console":false,"tostatus":false,"complete":"false","statusVal":"","statusType":"auto","x":680,"y":100,"wires":},{"id":"48190cbf.587d84","type":"ui_group","z":"","name":"Default","tab":"711389cf.7d4e18","order":1,"disp":true,"width":"25","collapse":false},{"id":"711389cf.7d4e18","type":"ui_tab","z":"","name":"Home1","icon":"dashboard","disabled":false,"hidden":false}]
You need to highlight all the code and click the little button that looks like </> at the top of the composer box.
I didn't see Dave's post in time, I was just about to say the same thing, and that I have edited the post so that it should now be importable.
Ah! I can import it now. @chawana, I believe the reason is that you don't have anything inside the template node.
Just swap out your UI template node for a new one with the default text inside it, and then replace "payload" with "template" in the default text (since that's what you're calling the code you set up in the template node).
Or put this in there (the default, with "template" in place of "payload"):
<div ng-bind-html="msg.template"></div>
inside the UI template. Of course, I wasn't able to see the gauge you're making, but I'm not plugged into your Arduino :wink:
tymarbut thanks..
after change but still not working ,please send back you code?after you fix it
Well... I'm sorry to tell you that I don't think I "fixed it" per se - I can just see that the template node isn't set up to show anything. So it'll be blank until you give it some sort of input, like it's set up to take by default. Somehow, your msg.template needs to be mentioned in the UI template node.
@chawana The reason you are not seeing anything is that the ui_template node works within tehdashboards framework. i.e. you are not building a complete web page but just a chunk of the webpage the dashboard builds. (@dceejay could explain this better)
So instead of trying to build a complete new web page why not see if the tools that NR provides can solve your issue?
With that in mind, it looks like you want to display a series of guages. If that is the case, why not use a number of ui_guage nodes?
If that is not the case, what do you want to show on the dashboard?
@ zenofmud i want to show my custom gauges in template in dashboard
You are building an entire web in the template node. That is not what the dashboard does. You could try creating an http endpoint. Look thru the cookbook for examples https://cookbook.nodered.org/#http-endpoints:
