Simple show awesome icon on screen
...am i stupid or not awake ????
i want to have a awesome font ( or icon ) on my screen, i puzzled but did find the correct way.
i just want a simple text box NOT A BUTTON !( in a template) that shows me a awesome font ( icon) doesn't matter which one. Played with and fa-xxxx and fa-2x .. but did not find any workable way.
can you please help me out here ? it cant be that hard ??
many thanks in advance
m
In text, at Label : <font color = "black" i class="fa fa-barcode fa-2x"> </i><font size=5 font color ="blue"> Scan
thx this worked .. i can now play around
many many thanks
That is some pretty screwed up mismatched html
...where on earth did you copy that from haha. Browsers are so forgiving.
This is more sensible...
<span style="color:black;"> <i class="fa fa-barcode fa-2x"> scan</i></span>
Or simply let the font colour be inherited...
Edit...
I haven't tried this so YMMV.
You might need to take the text outside of the <i> tag
@menno I would NOT use that html snippet - it has 2 unclosed font tags. God knows what quirks will surface across the rest of your dashboard.
Most html <tags> require an equal close </tag> and the random i makes no sense (but I do know where it's from - font-awsome is almost always demonstrated using the <i> tag
The ui_template node will likely strip off any style attributes it sees because that's just what Angular likes to do. This is why the <font> tag is commonly used rather than <span>.
So the fixed html will be:
<font color="black"><i class="fa fa-barcode fa-2x"></i></font><font size=5 color="blue">Scan</font>
Thanks for the info Nick. I wasn't aware of this.
You should be able to use the Angular equivalents.
There is an example here:
