Smart Nora + temperature?
I've just started playing with Smart Nora and wondering how to send temperature to a SN sensor node?
I have a test that works but not sure the right way to implement it in a flow. the test inject is like this
    "temperature": 24.1
But how do I get the a payload of temperature into that object form ?
After a dozen or so tries I came up with wish works
var temp = msg.payload
msg.payload = {temperature:temp}
return msg
Do you have the required temperature in msg.payload? If not where is it?
If it is in the payload then you can move it using a Change node configured like this
Feed that into a Debug node and check it is what you want.
Yes the function has msg.payload incoming to it containing the temperature
2022-12-09 11_40_01-Node-RED _ 192.168.2.207
So did my suggestion work for you?
Just tried it and no it didn't work sorry
The two debugs look like this
2022-12-09 11_38_27-Node-RED _ 192.168.2.207
2022-12-09 11_38_04-Node-RED _ 192.168.2.207
You mistyped into the change node
Ahh, well that was embarrassing :grinning_face_with_smiling_eyes: :roll_eyes:
Yes indeed your example worked !
Stopping to think is never a good idea when typing :grinning:
