Hi all,
I need you help making SmartMeter work with my nodered ...
System
Weidmann Elektronik IR IR Schreib/Lesekopf USB (Optokopf) - Infrarot Sendediode (Tx), Infrarot Phototransistor (Rx) IC: FTDI FT232R / FT230X USB-to-UART Serial Converter
USB adapter found on /dev/ttyUSB1
lsusb
Bus 002 Device 016: ID 0403:6015 Future Technology Devices International, Ltd Bridge(I2C/SPI/UART/FIFO)
- NodeRed v3.0.2 on a docker on ubuntu
using portainer I added to the start of the docker "privileged mode" and the device /dev/ttyUSB1
Test
- tested with Weidmann Elektronik Emolog tool end got data with 300 7E1 bidirectional
- tested with minicom -b 300 -D /dev/ttyUSB1 and got data which looks a little bit strange but I believe it is data
Node-RED
- Installed node-red-contrib-smartmeter
- created new flow with smarmeter node
- configured node
But in the debug window I always get
smartmeter-obis error: Error: Error on Baudrate changeover: Error: Port is not open
Any hint or help is highly appreciated
